This thread is privately moderated by Tim Marks, who may elect to delete unwanted replies.
Old Dec 13, 2011, 09:07 PM
Tim Marks is offline
Find More Posts by Tim Marks
President, FMA, Inc.
Tim Marks's Avatar
Joined Mar 2008
Help!
My FMA Software no longer updates or launches
Hi:
On December 1, 2011, the FMA Direct site was consolidated with our partner website www.revolectrix.com
If you had previously installed PC software for your FMA Direct or Revolectrix product, you will need to re-install the software from the Revolectrix website.
Steps:
1) Go to the Revolectrix home page.
2) On the main navigation bar, click the product category for the type of product you own; e.g. "Chargers".
3) Click on the image of the product you own.
4) Click on the product's "Resources" tab. Here you will find a link to the PC Software Install page for your product.
5) Follow the instructions on the Software Install page to re-install the software.
Tim Marks
Tim Marks is offline Find More Posts by Tim Marks
Old Dec 13, 2011, 10:35 PM
SteveM732 is offline
Find More Posts by SteveM732
SteveM732's Avatar
United States, OR, Beaverton
Joined Feb 2008
It's almost like you are reading my e-mails to Nathan...
SteveM732 is offline Find More Posts by SteveM732
Old Dec 13, 2011, 10:48 PM
Tim Marks's Avatar
Joined Mar 2008
Can't say as I am, but I guess you mentioned this to him?
I've requested with RCG that this thread be made into a sticky.
Tim Marks
Old Dec 22, 2011, 01:06 AM
bob_nj is online now
Find More Posts by bob_nj
bob_nj's Avatar
Vineland, N.J.
Joined Sep 2003
Re-Install
Why is it necessary to reinstall software?
bob_nj is online now Find More Posts by bob_nj
Old Dec 22, 2011, 01:33 AM
a1pcfixer is offline
Find More Posts by a1pcfixer
Counter agent of B.S.
United States, IN
Joined Aug 2003
Because the update feature USED to point itself to an FMA Direct update address, and now they point to a Revolectrix IP address.
Actually it should have been possible for them to institute a re-direct and we'd not even known about it, but maybe there's an issue with doing that?
a1pcfixer is offline Find More Posts by a1pcfixer
Old Dec 22, 2011, 01:36 AM
bob_nj's Avatar
Vineland, N.J.
Joined Sep 2003
OK, I get it.
So it looks like there are no software of firmware updates available for the 4S?
You take care, and Happy Holidays!
Bob
Old Dec 22, 2011, 07:08 AM
United States, IN
Joined Aug 2003
As Tim puts it, IF yours is a.....
"Cellpro 4s (the original in the clear heat shrink with the red label)"
...No.
Old Dec 22, 2011, 07:17 AM
bob_nj's Avatar
Vineland, N.J.
Joined Sep 2003
I'll have to take a look at mine when I get home.
I do know that it has the port for the interface cable though.
Old Sep 21, 2013, 06:54 AM
Edgar Perez is offline
Find More Posts by Edgar Perez
Joined Aug 2005
What is the latest version?
My CCS reports 'Version 1.11 (10-10-12) - Allowed higher safety charge voltage diff. for A123."
Given its date, im wondering if my setup is not picking updates automatically.
I tried to re-install, but ended in the same version. Maybe its ok...
Edgar Perez is offline Find More Posts by Edgar Perez
Old Sep 21, 2013, 10:54 AM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
That's the latest version of the CCS. Also check the firmware version on your charger. It should be 3.31.
Gregor99 is offline Find More Posts by Gregor99
Old Jul 04, 2014, 05:43 PM
paracanary is offline
Find More Posts by paracanary
paracanary's Avatar
La Habra, California
Joined May 2004
charging 40 ah life battery
Can't find a A123 balanced preset that will charge my 40 ah LIFE prismatic storage battery at a rate higher that 10 amps. The optimum charge rate is 15 amps but the battery is capable of a 40 amp charge. How do I increase the A123 preset to 15 amps? The battery is wired for an FMA balance connector. Or can I use a lipo preset and change the termination voltage.
paracanary is offline Find More Posts by paracanary
Old Jul 04, 2014, 06:33 PM
Gregor99 is offline
Seattle
Joined Sep 2007
Preset #10 A123 High Power. That preset supports up to 40 amps. On the fuel tab change the pack capacity to match the size of your pack. Its not required, but will help the fuel gauge accuracy.
Old Jul 05, 2014, 12:32 AM
paracanary's Avatar
Joined May 2004
Thanks, don't know how I missed it
Old Oct 14, 2014, 09:07 AM
BrownOut is offline
Find More Posts by BrownOut
Chasing dreams not d competion
uk
Joined Feb 2009
I am trying to set up my cellpro multi 4 on my laptop using windows 8.1.
The ccs seems to work but I can't get it to recognise the charger.
I have updated the USB driver but it only lists up to xp or 32bit vista.
Can this be done or have I got to the end of the chargers life (it's only been used a handful of times since I've had it).
I want to set the presets and find it a pain doing it with the mode button on the unit.
BrownOut is offline Find More Posts by BrownOut
Old Oct 14, 2014, 12:44 PM
Gregor99 is offline
Seattle
Joined Sep 2007
If you are using the FUIM2, you will need to upgrade to the FUIM3.
Question Futaba Software updates / Manuals grenflyer Radios 3 Nov 10, 2011 06:33 AM
Question Solder or use bullet connectors when making my ESC wires longer justy g Power Systems 4 Sep 29, 2011 08:02 PM
Discussion MY Favorite Horizon Will NO LONGER SHIP TO ME pulsery2k1 Vendor Talk 4 Sep 22, 2011 03:22 PM
Found DX 7, Dx6i, or Futaba7c. Reasonable no longer need skillyl Aircraft - General - Radio Equipment (FS/W) 4 Jul 24, 2011 01:46 PM
Discussion Log veiw no longer valid on my I-charger? Heliwrecker Batteries and Chargers 1 Apr 25, 2011 03:55 AM
