Jason, thanks for starting the thread. It only took you a couple hours from getting the model in your hands to posting pics
![]() I suppose I should have started a new thread myself, and I may do it later when the "proper" models arrive. This first batch was made in prototype MDF molds as a proof of concept. Aluminum molds are being made right now for full production. The model was well received by the few test pilots in Russia. I test flew it one day before the Archdale contest and liked it enough to use in the contest. Unfortunately, damaged it too soon and finished the contest with another model.This is my own design. Airfoils are a refinement of the Taboo GT foils. The tail areas are very generous, especially the vertical tail, to aid in launch performance and handling. The name is from a popular/classic medication used in Russia. Here is more data for you to make fun of while you are waiting for the next batch of Validols ![]() Quote:
Vilnius, LITHUANIA
Joined Sep 2005
And this is my medicine for the next season's treatment.
Kevlar wing -138,2g Fuselage - 48,4g Vertical tail -7,0g Stab - 7,0g It seems there is no chance for DS285 to take place inside the fuse. Maybe DS188. But optimized for D47 or 5035. As for a wing, it is thick enough for even 11mm servo. |
hi guys!
i should make the note that at russian market this Plane have different name - The Falidol! its from the validol like has mean Oleg and the first letter from...... you knows this word very well but i cant write it ![]() im very happy and thankful to Oleg and Andrey for the great Plane Andrey has forced me to use the Validol at russian big contest without any tests and setup and i had some success i did use 2 d47, 2d60 and lipo 2|370 without any bec and the weight about 280gr |
I will do a build-log. Although most of the building part should be much like an Akcent2 but with different POD configuration. Oleg, do you have suggestions for starting CG location? Also, can you confirm the location of the wire routing channels in the wing: 45mm from leading edge, extending slightly forward out to 65mm from center? Thanks! Jason |
| Thread Tools | |
| Discussion Photos, Test Flight/Test Flight, Photos? | Mode One | The Builders Workshop | 15 | Dec 19, 2011 10:16 AM |
| Sold Genie #13 Built by Harley PHOTOS ADDED | EBerris | Aircraft - Sailplanes (FS/W) | 4 | Sep 18, 2011 08:34 AM |
| Discussion Astronauts' tracks, trash seen in new moon photos | aerogel | Life, The Universe, and Politics | 30 | Sep 07, 2011 09:56 PM |
| Discussion BMFA Nats 2011 - couple of photos | MCarlton | Fuel Jet Talk | 0 | Sep 05, 2011 01:15 PM |
