Old Dec 13, 2011, 02:39 PM
kickythekick is offline
Find More Posts by kickythekick
kickythekick's Avatar
Joined Sep 2011
Just so I don't blow anything up....
I have read the forums and just want to make sure that I'm not going to mess my esc or battery up. I own the p51-d by parkzone (specs can be found here). It came standard with a 3s 1300 mah battery. I bought an adapter that will allow me to plug in a deans connector and would like to try it out. I own This battery and want to know if it will damage my plane in any way.
Also... The plane came with a car charger that goes into the cigarette lighter. Can I use a wall adapter that has an inlet for the cigarette lighter to go in one side and then plug directly into the wall.
Thanks!!!!
kickythekick is offline Find More Posts by kickythekick
Old Dec 13, 2011, 02:53 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
You can use that battery.
It is the same voltage just more mAh.
You should get longer flight time.
Just re-balance the plane and you should be good to go.
As for a charger, does the one you have balance charge?
That battery is should be balance charged.
If you have a wall adapter that outputs 12V DC at high enough current it will work.
Your charger should have an input current printed somewhere. That should be less than the wall adapter output.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Dec 13, 2011, 03:02 PM
Joined Sep 2011
Thanks!
It does balance. I will have to buy the 12v adapter but it will save me some money on an actual charger.
Old Dec 13, 2011, 03:09 PM
RC Helicopter Pilot
Joined Mar 2010
I think what you need is a 12V power supply.
An old lap top PS will sometime work.
You may have a little trouble finding adapters if you don't make some yourself.
Old Dec 13, 2011, 03:14 PM
frovello is offline
Find More Posts by frovello
United States, CT, Danbury
Joined May 2007
One fly in the ointment, you stated that you purchased and adapter for a Deans connector, however the battery you linked to does not have a Deans connector.
frovello is offline Find More Posts by frovello
Old Dec 13, 2011, 08:38 PM
Joined Sep 2011
Sorry if I wasn't clear.... I bought an adapter with the park zone connector on one end and the deans on the other.
Old Dec 13, 2011, 11:39 PM
KC is offline
KC
Find More Posts by KC
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
The HK battery has the XT60 connector on it. It's totally different from the Park Zone's EC3's and Deans.
Unless you changed out the XT60 to Deans on the lipo, what you need is the EC3 to XT60 adapter cable.
KC is offline Find More Posts by KC
Old Dec 14, 2011, 06:01 PM
Joined Sep 2011
Haha, Im sorry to confuse things, I DID change it to deans. Flew today and it went great! It feels faster although it drops a lot faster when it's unpowered.
Discussion It's like they don't learn or just don't care... logan5 Life, The Universe, and Politics 23 Aug 25, 2011 03:47 PM
Discussion I really don't want to blow up the airplane. (The one I fly home on tomorrow) The L Batteries and Chargers 7 Dec 04, 2006 07:09 PM
Discussion Ok, someone let me know if this is right so I don't blow myself up _Pattern_Man Batteries and Chargers 5 Mar 27, 2006 03:23 PM
New Saphion cells that don't blow up, perfect for hummingbird! hairy_llama Micro Helis 5 Apr 19, 2004 09:01 PM
Whoops! CYBER BIRD PARTS ARE HARD TO COME BY??? .So don,t break anything countmonk Ornithopters 1 Dec 08, 2003 07:58 AM
