Old Dec 13, 2011, 01:37 PM
texas
Joined May 2005
which edf jet sounds like turbine ? and good choice for first Jet plane ?
hi , so many choices ...
trying to decide on my first jet plane , and i have seen video of like the
stumax edf unit and dynamax edf unit on various jets.
really like the sound and performance i saw in video , sounds like a turbine jet !
so with that said ,,, and i am on a lower end budget,
what would be some suggestions to look at ?
for instance ,,, if i could easily put a great sounding EDF unit in the parkzone Habu that would be great ...
i am not a builder though, so plug and play type projects would be first choice.
any thoughts would be great , thanks
rcfun2005 is offline Find More Posts by rcfun2005
Old Dec 13, 2011, 01:40 PM
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
http://www.rcgroups.com/forums/showthread.php?t=1521248
Michael Paxton is online now Find More Posts by Michael Paxton
Old Dec 13, 2011, 01:46 PM
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
I think this might be what you want for a Habu
http://www.rcgroups.com/forums/showthread.php?t=1549350
Gaz-b is offline Find More Posts by Gaz-b
Old Dec 13, 2011, 01:55 PM
texas
Joined May 2005
note: i have not purchased my first edf jet yet ,,, so really looking at trying to put together off the shelf , easy to put together proven package . not spending huge $$$
if habu parkzone is good choice then i would purchase this ,
if another model already better setup for a turbine like sounding EDF unit , then that works also ...
thanks for all the comments
Old Dec 13, 2011, 02:18 PM
Nashville TN.
Joined Mar 2006
He said "Parkzone" Habu...Not E-flite Habu!
The thread on the fan I posted is for a $15 10 blade 70mm fan which will take a 28mm motor....so lots of options.
You're NOT gonna get cheaper than that for "Turbine like sound".
Old Dec 13, 2011, 02:37 PM
Joined Nov 2005
The 10blade CS fan mentioned above is the ticket for turbine sound especially if you have a plane with twin intakes like the habu.
HK sells a 2900kv 2858 motor that is prolly a great match for this fan
erh7771 is offline Find More Posts by erh7771
Old Dec 13, 2011, 03:14 PM
Nashville TN.
Joined Mar 2006
Just try to stick with 3.2 mm shafts if possible. Some (myself as well) have found the 4mm adapter you get in addition to the 3.2 to be quite loose on most motor shafts and hard to center.
Old Dec 13, 2011, 05:23 PM
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
the 4mm shaft adapter is for 4mm shaft motors, you should never try to use that on a motor that has a 3.17mm shaft. use the right adapter for the right application and it will work fine
jcdfrd is offline Find More Posts by jcdfrd
Old Dec 13, 2011, 05:30 PM
Nashville TN.
Joined Mar 2006
Really? Are you used to working with stupid people or something?
The 4mm adapters I got with all four of the fans I bought were way over sized for 4mm shafts. I have several Eflite motors with 4mm shafts and they were very wobbly on them as well as ALL the other motors with 4mm shafts I tested them on.
Old Dec 13, 2011, 05:35 PM
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
ok ok relax...your post made it sound like you were trying to use them incorrectly. some folks need things spelled out very clearly for them, obviously your not one of them......my apologies
I hope there not all that way we have two motors with 4mm shafts comming specifically for the cs70/10 fan
Old Dec 13, 2011, 05:41 PM
Nashville TN.
Joined Mar 2006
I'm hoping the issue has been addressed as "was" a common problem a few weeks ago.
Sorry about my reaction...No harm no worries..
Old Dec 13, 2011, 09:02 PM
Where's my minigun!!!
torque roll's Avatar
Joined Oct 2011
+1 CS 70mm 10 blade
torque roll is offline Find More Posts by torque roll
Discussion Free Dynamic Balancer (good for turbine, EDF or prop balancing). dwalsh62 Jet Turbines 13 Nov 24, 2011 06:40 AM
Discussion Free Dynamic Balancer (good for turbine, EDF or prop balancing). dwalsh62 DIY Electronics 9 Nov 11, 2011 06:22 PM
Build Log F-19 AURORA Project, first EDF plane for 120 fan or a Turbine Zyklotron Electric Ducted Fan Jet Talk 144 Jul 03, 2011 01:11 PM
Discussion Plane ID Help…Looks like a good choice for PSS. DWA Slope 19 Feb 05, 2011 01:19 PM
Discussion Your choice for a first EDF jet Loopnot Foamy EDFs 28 Mar 20, 2010 08:17 PM
