Old Dec 13, 2011, 01:17 PM
Genaro Solé is offline
Find More Posts by Genaro Solé
Genaro Solé
Genaro Solé's Avatar
Caracas, Venezuela
Joined Nov 2007
Question
Spektrum receiver on fiber fuse/carbon wing sailplane
I've searched the forum in many ways but I can't find an answer:
Can I use a Spektrum receiver (AR6200 /AR7000) on a sailplane with glass fiber fuse, but carbon wing?
I want to buy an F5B/F - Orion 2.4 E-Carbon, and want to use my AR6200 /AR7000 receivers, without exposing the wires trough holes (if possible).
Vendor claims "The Fuselage is 2.4ghz friendly", but I don't know if the wing may interfere somehow with the spektrum signal.
Thanks in advance,
Genaro Solé is offline Find More Posts by Genaro Solé
Old Dec 13, 2011, 03:45 PM
R.M. Gellart is offline
Find More Posts by R.M. Gellart
R.M. Gellart's Avatar
Joined Nov 2005
Yes you can, I am using non carbon specific Spectrum RX's in glass nosed Tragi 801's with full carbon wings and fuses that use hybrid carbon fabic for the fuse past the front end.
Marc
R.M. Gellart is offline Find More Posts by R.M. Gellart
Old Dec 13, 2011, 03:53 PM
mlee8249 is online now
Find More Posts by mlee8249
Fly R/C writer
Redlands, Ca
Joined Dec 2004
Hi Genaro,
Absolutely you can do that and no problem. What you need to do is make sure the antennas are in the fiberglass section of the fuselage and not touching other wires. It's normally pretty crowded in the nose of a sailplane and so keeping other wires away is sometimes a chore.
Also, if you want to see some installations and experiments we have conducted using 2.4 technology, check out the 2-Point-4 Chronicles at this website:
http://mysite.verizon.net/respri94/
The 2-Point-4 Chronicles documents the things we have done to prove how good 2.4 works, plus dispell myths and hearsay about what works and what doesn't. We found that things that were supposed to be disaster were absolutely fine, while things that were said to be solid really were not. The Chronicles is yours for free, no fees, no commercials or ads, not even your email address. Just down load and enjoy. You will see photo of installations just like you describe, without whiskers hanging out. Check it out and you will help the Chronicles become an international document.
Sincerely,
Mike Lee
mlee8249 is online now Find More Posts by mlee8249
Old Dec 13, 2011, 04:03 PM
spotterone is offline
Find More Posts by spotterone
Can you DS it??
spotterone's Avatar
Australia, NSW, Berowra
Joined Aug 2008
I used the information in the 2.4 chronicles to do my installs. I've had no problems so far out of 50 odd spektrum receivers of all sizes in all types of planes.
I mostly fly DS planes that are fibreglass/kevlar fuselages with heavily laid up carbon wings. No problems for me whatsoever.
spotterone is offline Find More Posts by spotterone
Old Dec 14, 2011, 12:31 PM
Genaro Solé
Caracas, Venezuela
Joined Nov 2007
Thanks to all for your fast answer!
Originally Posted by mlee8249 View Post
Hi Genaro,
... Also, if you want to see some installations and experiments we have conducted using 2.4 technology, check out the 2-Point-4 Chronicles at this website:
The 2-Point-4 Chronicles documents the things we have done to prove how good 2.4 works, plus dispell myths and hearsay about what works and what doesn't. We found that things that were supposed to be disaster were absolutely fine, while things that were said to be solid really were not. The Chronicles is yours for free, no fees, no commercials or ads, not even your email address. Just down load and enjoy. You will see photo of installations just like you describe, without whiskers hanging out. Check it out and you will help the Chronicles become an international document...
Awesome work and document! You should publish it as a separate web page!
Regards,
Old Dec 14, 2011, 02:01 PM
Fly R/C writer
Redlands, Ca
Joined Dec 2004
Hi Genaro,
Thank you for your compliments!
Old Dec 14, 2011, 02:49 PM
efowlerpreston is offline
Find More Posts by efowlerpreston
Valdosta, GA
Joined May 2006
My Orion has carbon fiber strips running longitudinally to reinforce the fuselage. Sort of like a Zebra. Consequently, there is some Carbon in the nose.
efowlerpreston is offline Find More Posts by efowlerpreston
Old Dec 14, 2011, 05:02 PM
Lenny970 is online now
Find More Posts by Lenny970
Lenny970's Avatar
Greeley, Colorado, USA
Joined Feb 2000
Agreed. I've seen several Orions and they have all had carbon tow in the fuselage.
I would suggest an external antenna.
Lenny
Lenny970 is online now Find More Posts by Lenny970
Old Dec 14, 2011, 06:55 PM
Fly R/C writer
Redlands, Ca
Joined Dec 2004
I would have to agree with Lenny and efowlerpreston on this. Mostly because the actual amount of CF in the strips is not uniform nor in the same position from one plane to the next. So, it is better to error on the side of being safe with the whiskers, than to risk the possible loss of the model due to CF blocking. The whiskers might not look good and might cause drag, but crashing a plane due to a loss of signal truly sucks.
(Did ya ever notice how a modern fighter looks clean and aerodynamic when it's in prototype, and then by the time it becomes operational, it has junk popping out all over the place? Go figure)
Old Dec 15, 2011, 07:18 AM
Genaro Solé
Caracas, Venezuela
Joined Nov 2007
Well, whiskers will be then.
Thanks to all!
Gerry
Old Dec 15, 2011, 05:57 PM
FULLSCALE is offline
Find More Posts by FULLSCALE
United States, OR, Bend
Joined Nov 2004
orion with 2.4
I have one of the Orions that Lenny built, it has the carbon strips longitudinally in the fuse from the factory. Bought it used, I couldn't my remote rx antennas back through the holes he drilled and so I just have it inside the fuse. I have not had any problems, but this is just results based. Simple range checks indicated no problems so I flew it. Probably crazy but it has worked, I've had the thing absolutely specked out many, many times, and flown it low many times as well. I'd like to know if the new carbon fuse rx's are allowing for complete worry free, hole free installs?
FULLSCALE is offline Find More Posts by FULLSCALE
Old Dec 15, 2011, 11:45 PM
Fly R/C writer
Redlands, Ca
Joined Dec 2004
Hi Fullscale,
The carbon fuselage rx's are really no different in use than the other receivers, save for the longer antennas. This is to allow the antenna to exit the fuselage in a convenient location that won't expose the wire to damage from landing, being handled, etc. You still have to poke the last 32-mm of antenna outside. In producing the 2-Point-4 Chronicles, we did not find a single rx that claimed to be carbon compatible and could pass a range check with the antenna inside the carbon fuselage. Virtually all of them happily passed range check when the antenna was exposed ala whisker.
Mike Lee
Old Dec 28, 2011, 12:22 PM
Joined Nov 2004
I think you wrote the 2.4 chronicles before the latest carbon Rx's were made. I'm wondering if the new receivers are any different. Thx.
Old Dec 29, 2011, 10:14 AM
Fly R/C writer
Redlands, Ca
Joined Dec 2004
Hi Fullscale,
While it is true that a majority of the text within the Chronicles was written prior to 2010, you might notice on my website that I write updates every 6-months or so, as new products come on to the scene. And then I add that update stuff to main article at least every 15 months. But , just in case you may have missed that, I have done testing on newer receivers made for the carbon fiber fuselages. In particular, the AR9300, AR9310, AR600, and AR6255 units. In my testing and usage, (and YMMV), the last 32-mm of antenna still needed to be outside for best performance. I thought the same as you when these receivers first appearred...oh cool! No more whiskers! Sorry, but that was not the case. They simply made the antenna lead longer so that you could poke the tips out somewhere in a place that the antenna was outside but not prone to being disturbed by your hand, landing on the wire, or anything else that might break the wire. I still don't know why the manufacturers still use the rather brittle antenna wire, other than the fact that finding a super-flexible, shielded wire is mission: "impossible".
Now, if you decide to place one of the new carbon friendly receivers into a carbon fuselage and it works as advertised, please let us know. And don't forget that we need to see the model, the receiver, and what testing or procedures you performed to make it work....you might be on to something we can all use! (And if it doesn't work, let us know, too!)
Thanks!
Discussion Spektrum receiver on glass fiber fuse-wing carbon sailplane Genaro Solé Radios 1 Dec 13, 2011 02:41 PM
Sold Spektrum DSMX Carbon Fuse Remote Receiver SPM9646 aquaanox Aircraft - General - Radio Equipment (FS/W) 4 Nov 13, 2011 05:37 PM
Sold NIP, Spektrum 6255 carbon fiber fuselage receiver davecee Aircraft - General - Radio Equipment (FS/W) 0 Jul 16, 2011 02:16 PM
Sold TWO SPEKTRUM AR6255 RX's (CARBON FIBER FUSE) NIB burke757 Aircraft - General - Radio Equipment (FS/W) 2 Sep 27, 2010 04:35 PM
Sold AR9300 Spektrum 2.4 Carbon Fiber Fuse Full Range Receiver burke757 Aircraft - Sailplanes (FS/W) 5 Sep 10, 2010 11:06 PM
