Old Jan 01, 2013, 08:29 PM
Nelapaty is offline
Find More Posts by Nelapaty
KK4NZS
Nelapaty's Avatar
Virginia
Joined Sep 2006
Originally Posted by Pisces View Post
Hmmm... seems your calculations give a different answer than the formula given by IBCrazy in post #1.. quote
"SWR is calculated as follows:
p = Vr/Vf
SWR = 1+p/1-p "
Then
p = 0.29/4.35 = 0.0666
VSWR = 1+0.066 /1-0.066 = 1.066/0.934 = 1.14
VSWR = 1.14
IBCrazy of course is the correct way to calculate VSWR. Voltage Standing Wave Ratio
Efficiency for VSWR 1.14 is > 99%.
PS..the IBCrazy method as with most VSWR meters measures Voltage not Power. The direct power reading is unknown but of course is related by the formula Power = Voltage^2/Ohm ( P=E^2/R )
Hope this helps
Thanks that really clear things out.. Keep it simple
Nelapaty is offline Find More Posts by Nelapaty
Old Jan 06, 2013, 09:18 AM
Nelapaty is offline
KK4NZS
Nelapaty's Avatar
Virginia
Joined Sep 2006
Pisces,
Is there a chart that shows efiiciency?
Whats the efficency for 1.71 VSWR
Old Jan 06, 2013, 04:07 PM
Pisces is offline
Find More Posts by Pisces
The Dreamer
Pisces's Avatar
Sydney, Australia
Joined Dec 2010
Originally Posted by Nelapaty View Post
Pisces,
Is there a chart that shows efficiency?
Whats the efficiency for 1.71 VSWR
There are charts and if I come across it on-line I will post the link. I have the link saved here somewhere but cant find where i have saved the link in my favorites folder.
But, you can DIY using a on-line VSWR efficiency calculator.
http://www.csgnetwork.com/vswrlosscalc.html
Example,
Enter VSWR 1.14
The Loss in power W = 0.428%
Therefore the Forward Power = 100 - 0.428 = 99.57%
Also on interest in the calculator is Input power 100W
Shows Loss in Power = 0.428W
Therefore the Forward Power radiated by the antenna is 99.57W.
PS..Enter VSWR 1.5 and the calculator gives Power forward = 96%.
This is why a VSWR of < 1.5 is considered a good antenna. 4% of input Power W is lost due to impedance mismatch. Impedance mismatch is measured as VSWR. One and the same.
Hope this helps
Lindsay
Pisces is offline Find More Posts by Pisces
Old Jan 16, 2013, 03:54 PM
DriesRC is offline
Find More Posts by DriesRC
Joined Aug 2011
I bought Coaxial cable from ebay, but the smalest I could find was 2.5m long.
It has SMA male on both sides. Can I cut the cable, shorten it, and resolder it so I get the short coax cable for the SWR meter? Or will the solder point ruin the whole calculation system?
If so, does anyone have an ebaylink to a short RG316 jumper?
thanks in advance
DriesRC is offline Find More Posts by DriesRC
Old Jan 16, 2013, 04:01 PM
Nobert is offline
Find More Posts by Nobert
Nobert's Avatar
Tucson Avra Valley, Arizona, United States
Joined Jul 2002
Why not use a SMA Male to male connector like this one:
http://www.ebay.com/itm/SMA-male-To-...item2576bda426
Nobert is offline Find More Posts by Nobert
Old Feb 07, 2013, 06:22 PM
gazzzz is offline
Find More Posts by gazzzz
Norway, Oslo
Joined Feb 2012
DIY SWR meter
can i use this coupler
http://www.ebay.com/itm/Mini-Circuit...item4839f26993
for 1.3 ghz. diy swr meter.
or if you have a link to on that work better '
gazzzz is offline Find More Posts by gazzzz
Old Feb 08, 2013, 10:14 AM
Nobert is offline
Nobert's Avatar
Joined Jul 2002
Gazz
That will work great and the price is right.
Neal
Old Feb 08, 2013, 02:20 PM
a9amg is offline
Find More Posts by a9amg
a9amg's Avatar
Manchester, UK
Joined Sep 2008
Just build the smallest Diode, Resister & Capacitor circuit...
But think I shorted out pins 4 & 5 on the Diode, will this matter?
a9amg is offline Find More Posts by a9amg
Old Feb 08, 2013, 03:08 PM
Martin7182 is online now
Find More Posts by Martin7182
Wallop!
Martin7182's Avatar
Bussum, Netherlands
Joined Oct 2009
If you have the K-package of HSMS-286 then it shouldn't matter (pins 2 and 5 are just for isolation between the two diodes). But it introduces a little extra capacitance.
Martin
Martin7182 is online now Find More Posts by Martin7182
Old Feb 08, 2013, 08:13 PM
gazzzz is offline
Norway, Oslo
Joined Feb 2012
Originally Posted by Nobert View Post
Gazz
Neal
thanks Neal
Old Feb 13, 2013, 03:52 PM
Wallop!
Martin7182's Avatar
Bussum, Netherlands
Joined Oct 2009
Finally my SWR meter has been completed. It has everything I wished for; usable for 2 - 8Ghz, sensitive; good response with only 14dBm signal, analog scale, small; about the size of a pack of cigarettes.
My printer is really horrible, so the scale is unreadable. I don't mind as I'm the only user and I know what's printed. The little green led is what takes most current, I should solve that later .
Thank you Alex for your great ideas!
Martin
Old Feb 22, 2013, 11:18 PM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
Martin
Ok... im confused, how are you getting SWR from a single reading? doesnt it need forward and reverse?
chanyote66 is offline Find More Posts by chanyote66
Old Feb 22, 2013, 11:26 PM
chanyote66's Avatar
Joined Dec 2011
Hey IB... or anyone reading...
If i get the below results is there any problems with the setup?
Description:
Meter built from:
HSMS-286k
1k resistor
0.01mF 50v capacitor
Multimeter used: Fluke 77IV
Readings:
Stock antenna
Vf=131mv
Vr=-3.1mv
P=-0.023664122
SWR=0.953765846
LHCP Mad Mushroom (Self built)
Vf=121mv
Vr=-.9mv
P=-0.007438017
SWR=0.985233798
RHCP Crosshair
Vf=131mv
Vr=-1.1mv
P=-0.008396947
SWR=0.98334595
DIY SWR (7 min 19 sec)
Old Feb 23, 2013, 08:03 AM
Wallop!
Martin7182's Avatar
Bussum, Netherlands
Joined Oct 2009
You're right, in principle it needs Vf and Vr. But Vf is quite stable, it varies about 10% for different loads (antennas, resistors) if I remember correctly. So given the formula VSWR = (1 + Vr/Vf) / (1 - Vr/Vf), my VSWR reading is just a little bit off. But when calibrating the meter with a known load, it is spot on. So this is what I normally do: I connect a 6dB attenuator as load and set the reading to VSWR = 1.66. Then I replace the attenuator by the antenna and try to tune it at or below VSWR 1.30. Then I verify the reading with my DIY 60Ω dummy load.
I think for low VSWR values, the error in the diode's non-linear region is bigger than the error you make by assuming that Vf is constant. So theoretically you're absolutely right, but practically there's nothing wrong. Calibrating the meter with known dummy loads cancels out all errors, provided your measured antennas give about equal readings on the meter.
More details can be found here: http://www.rcgroups.com/forums/showthread.php?t=1718928
Martin
Old Feb 23, 2013, 12:47 PM
chanyote66's Avatar
Joined Dec 2011
Ok, Ill see if i can find a Dummy load for 1280/1258 and see what that gives me. I roughly based my tests off the factory antenna, but we all know they aren't always the best...
Chris
Link A SWR Meter to build yourself jdm66 FPV Talk 0 Oct 20, 2011 02:00 PM
Discussion 5.8 Ghz SWR meter radialmind DIY Electronics 12 Jul 16, 2011 05:26 AM
Help! Lawmate: SWR meter showing low forward power but good SWR (low reflected power) ecampos FPV Talk 8 Jul 06, 2011 09:32 AM
Question Afordable SWR meter, low input power, 430Mhz freq ecampos FPV Talk 0 Jul 01, 2011 10:37 PM
For Sale Professional DIGITAL 40W FM BOOSTER+ with SWR meter anhtuanb Non R/C Items (FS/W) 0 Apr 30, 2011 01:53 AM
