Old Dec 14, 2011, 11:18 AM
crezzee is offline
Find More Posts by crezzee
Build Fly Crash Repeat
crezzee's Avatar
Worcester UK
Joined Nov 2004
If anyone in the UK is building one of these, how about swaping some SMA patch cables in return for a couple of these detector diodes.
http://uk.rs-online.com/web/p/produc...633D4E4F4E4526
PM me if interested
Cheers Ian
crezzee is offline Find More Posts by crezzee
Old Dec 14, 2011, 11:32 AM
GregSilver is offline
Find More Posts by GregSilver
GregSilver's Avatar
United States, FL, Plantation
Joined Nov 2005
Anyone willing to contribute and make a PCB layout for this?
I might be willing to contribute and CNC the boards for people. I have time to cut about 10-20 boards a week.
GregSilver is offline Find More Posts by GregSilver
Old Dec 14, 2011, 12:12 PM
GliderLover is offline
Find More Posts by GliderLover
Joined Apr 2008
i think i found the cheapest source for the coupler, but only for 900-1200, at 12 shipped worldwide:
http://www.ebay.com/itm/310209833363...fvi%3D1&_rdc=1
GliderLover is offline Find More Posts by GliderLover
Old Dec 14, 2011, 02:00 PM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Too big the price to abandon 5.8Ghz.
renatoa is online now Find More Posts by renatoa
Old Dec 14, 2011, 04:00 PM
Hugeone is offline
Find More Posts by Hugeone
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Originally Posted by Martinba77 View Post
I am just wondering now if I found a Dual Directional Coupler for my Frequency, then can I have a double (vF/vR) reading and attach directly into two voltage displayers and have the two numbers simultaneously? And then make a nice wood box and have put toghether nicely inside with the two displays facing outside to the front of the box?
Mmmm, maybe this make no sense at all!
Martin
Yes, it make lot of sense
-Hugo
Hugeone is offline Find More Posts by Hugeone
Old Dec 14, 2011, 04:30 PM
Devonboy is offline
Find More Posts by Devonboy
SW England
Joined Aug 2009
If you are not interested in frequencies above 2.4GHz, than you can make something like this
http://pe2er.nl/wifiswr/
or this
http://www.frars.org.uk/cgi-bin/render.pl?pageid=1085
Nigel.
Devonboy is offline Find More Posts by Devonboy
Old Dec 14, 2011, 11:44 PM
Leszek_K is offline
Find More Posts by Leszek_K
Leszek_K's Avatar
United Arab Emirates, Dubai, Dubai
Joined Jul 2007
I have built this one : http://pe2er.nl/wifiswr/ with just RF head PCB modified to fit into the square made of 3 SMA panel connectors soldered together. Works great on 5.8GHz too. I think it is not as accurate as power coupler based but good enough for home use.
EDIT: also - I used only 3 OpAmps - didn't use the one with NULL pot on it.
Leszek_K is offline Find More Posts by Leszek_K
Old Dec 15, 2011, 12:29 AM
Joined Sep 2007
Any issue if the components are soldered in the air without PCB, if skills permits ?
Old Dec 15, 2011, 02:22 AM
Devonboy is offline
SW England
Joined Aug 2009
It can be done with good soldering skills...
Old Dec 15, 2011, 02:34 AM
Leszek_K is offline
Leszek_K's Avatar
Joined Jul 2007
Renatoa - I assume your question was directed to me - didn't try that. PCB is double-sided as in a picture. Still needed a little vane capacitor to balance the bridge..
Old Dec 15, 2011, 02:37 AM
Leszek_K is offline
Leszek_K's Avatar
Joined Jul 2007
-Hugo
In that case it would be easier to add some differential amplifier and show SWR directly.
Old Dec 15, 2011, 04:34 AM
piopio is offline
Find More Posts by piopio
Joined Mar 2009
I see that someon use a 50ohm resistor for port 4 ( coupler )....why ?
When you buy a coupler....Isnt port 4 terminated ?
piopio is offline Find More Posts by piopio
Old Dec 15, 2011, 07:35 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
@renatoa - You can also build a wheatstone bridge circuit with 3 X 50 Ohm resistors on a PCB board and tap between the measurement junction for the reading. In any case you need a ground plane for reference or the circuit will resonate. So a backed PCB board makes it easy.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Dec 15, 2011, 09:41 AM
Jsutherland8 is offline
Find More Posts by Jsutherland8
ELECTRIC R/C
Jsutherland8's Avatar
Canada, ON, Woodstock
Joined Feb 2006
Mini-HowTo SWR meter - A DIY project
Originally Posted by piopio View Post
Is this diode OK for swr-meter ?
http://www.rs-components.co.id/diode..._from_store=id
The Max forward voltage is very low for this item.!
Jsutherland8 is offline Find More Posts by Jsutherland8
Old Dec 15, 2011, 09:51 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
^yes it is. It's a Schottky diode. It's supposed to be low. That is the voltage drop when working in the forward mode.
-Alex
Link A SWR Meter to build yourself jdm66 FPV Talk 0 Oct 20, 2011 01:00 PM
Discussion 5.8 Ghz SWR meter radialmind DIY Electronics 12 Jul 16, 2011 04:26 AM
Help! Lawmate: SWR meter showing low forward power but good SWR (low reflected power) ecampos FPV Talk 8 Jul 06, 2011 08:32 AM
Question Afordable SWR meter, low input power, 430Mhz freq ecampos FPV Talk 0 Jul 01, 2011 09:37 PM
For Sale Professional DIGITAL 40W FM BOOSTER+ with SWR meter anhtuanb Non R/C Items (FS/W) 0 Apr 30, 2011 12:53 AM
