Old Dec 17, 2012, 06:50 AM
kentli22 is offline
Find More Posts by kentli22
Joined May 2012
I need to get the feeler gauges. they look useful for checking the needles gap too. the hall sensor, doesn't it has 2 screws to hold them in position, to prevent it from moving?
kentli22 is offline Find More Posts by kentli22
Old Dec 17, 2012, 07:03 AM
kentli22 is offline
Joined May 2012
My NGH's rpm seems improved after I used a smaller spiner. Now it idles from at the top of the 2000 ranch. Up to 9500rpm is still fine, but above that, it will quit. I adjust the hsn either direction about 1/4 turns from the 2 turns out, but didn't seem to help, it will quit ealier when I closed about 1/2 turns. Might be I need to run in longer to have a better high end, I remember it wasn't able to make it over 5500rpm in the beginning.
I exchanged the muffler with an OS .46 stock muffler, it makes the engine much quieter, much easier to bear.
Old Dec 17, 2012, 07:04 AM
kentli22 is offline
Joined May 2012
"Now it idles fine at the top of the 2000 ranch, up to 9500rpm is still fine."
Old Dec 17, 2012, 07:14 AM
DarZeelon is offline
Find More Posts by DarZeelon
DarZeelon's Avatar
Israel, Center District, פ"ת
Joined Nov 2003
By all likelihood the ignition advance is properly adjusted. But if it can be adjusted and needs to be, the holding screws are in slots (not round holes).
You need to loosen the screws, move the holding plate and then re-tighten them.
The top of the 2K range is a bit high.
DarZeelon is offline Find More Posts by DarZeelon
Old Dec 17, 2012, 09:17 AM
kentli22 is offline
Joined May 2012
after further run in, idle at 2500 till 6000 is smooth and stable. Above 6500 is not nice but doesn't die. it starts every time, just need to prime plenty.
Old Dec 17, 2012, 09:19 AM
kentli22 is offline
Joined May 2012
OK, I will look at the hall sensor to see if I could mess up anything or not.
Old Dec 17, 2012, 09:42 AM
DarZeelon's Avatar
Joined Nov 2003
Originally Posted by kentli22 View Post
After further run in, idle at 2,500 and to 6,000 it is smooth and stable. Above 6,500 it is not nice but doesn't die. It starts every time, just need to prime plenty.
Perhaps the low-speed needle is set a bit too lean.
Try opening it of a turn and see if it improves the running quality. And also if it can hot-start with no priming, or just a little.
Old Dec 17, 2012, 10:16 AM
kentli22 is offline
Joined May 2012
OK, I will try open up LSN more to see if it improves.
Old Dec 17, 2012, 10:56 AM
kentli22 is offline
Joined May 2012
Opened up 1/4 turn LSN, resulted huge improvement. idle 2200, Carb intake fully open reached 9200rpm, whole ranch really smooth and stable, run like a real good engine. adjusting the HSN 2clicks leaner kills the engine. riches it 2 kicks made no difference. now LSN 7 turns out, HSN 2 turns and 2clicks out.
Cesco is offline
Find More Posts by Cesco
Cesco's Avatar
Joined Dec 2007
Kentli if you could retard the timing and post the experience i could know if i have to advance mine again. I have the pickup rotated as much as possible in rotation direction. Just loosen the screws a little and it can be moved. My idle seems quite good.
Cesco is offline Find More Posts by Cesco
Old Dec 17, 2012, 10:58 AM
kentli22 is offline
Joined May 2012
hot start is not possible, but could start with less prime.
Old Dec 17, 2012, 11:00 AM
kentli22 is offline
Joined May 2012
cesco, how to retard the timing? what procedures do u want me to do exactly?
Old Dec 17, 2012, 11:04 AM
kentli22 is offline
Joined May 2012
I feel that this engine needs many many hours of break in.
Old Dec 17, 2012, 11:15 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Well I am wondering if you have setup the engine wrong somehow.
First is the carb is different. Idle is about 1/2 open on the carb. I tried getting it to close in the past and it didn't work right when I did that. The default low speed needle setting worked for me on several different engines, not just my own either. The high speed seems to be about right at 1.5 turns out. I start at about two and work my way in while fine tuning it.
The engine spits fuel at low speed so it appears to be too rich, when in fact it isn't. The engine runs well with props you would normally use on a .60 or 10cc engine. So using a 11x7 or 11x8 prop works well on it.
The pump may not be pumping enough fuel to the engine, which would explain you not being able to lean it out more. So you may need the larger fittings for the pump pressure pulses on the pump side of the pump/regulator. Of course there should not be any air bubbles going into the pump from the fuel tank.
earlwb is offline Find More Posts by earlwb
Old Dec 17, 2012, 11:42 AM
kentli22 is offline
Joined May 2012
I am using 11*6 APC, idle is 1/3 open at the Carb at about 2500rpm. how to make the fittings larger for the pump? what are the fittings of the pump?
For Sale Prop Chart and Thread finder for any Glow or Gas Engine unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 2 Dec 10, 2011 12:31 PM
For Sale Prop Chart and Thread finder for any Glow or Gas Engine unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 2 Oct 14, 2011 12:44 PM
For Sale Prop Chart and Thread finder for any Glow or Gas Engine unclegeorge Aircraft - General - Miscellaneous (FS/W) 0 Oct 07, 2011 11:46 AM
For Sale Prop Chart and Thread finder for any Glow or Gas Engine unclegeorge Aircraft - General - Miscellaneous (FS/W) 3 Sep 24, 2011 12:25 AM
Sold NGH GT17cc gas engine NIB ibcinyourc.com Aircraft - Fuel - Engines and Accessories (FS/W) 4 Jun 30, 2011 11:35 AM
