I took a closer look at the NGH 9cc carb. That small set screw below the main needle is quite interesting. But I am not so sure it is really adjustable. It seems a little loose to me when it is adjusted in more, but maybe it will stay put like that, if someone does use it.
Basically the normal setting is to screw the set screw out until it just stops, do not force it. It does not screw out farther than where it stops, at approximately 3 turns out. That is the default setting for it. As you screw it out or in, the main needle outer tube will move in or out accordningly. Screwing the set screw in causes the needle to go in deeper towards the middle of the bore and screwing it out will move the needle towards the outside more. So theoretically one could adjust the low and midrange with that adjustment. But on my carb it felt a little too loose for my comfort, so I think it might move when the engine is running, but I could be mistaken. The carb does use a rotating barrel arrangement for the throttle. The low speed needle is adjusted through the center of the barrel like many glow engines use. The needle taper controls how much fuel flows as the barrel is rotated in a spiral in and out fashion. Now the carb does have a adjustment needle for metering the fuel into the needle and seat in the throttle barrel. So we have, sort of, two needles then. Glow carbs usually combine the main needle with the needle and seat in the carb. In this design they are separate but work together in conjunction with each other to meter the fuel into the engine. The carb throttle barrel open shows the needle in the center. ![]() The outer needle shown on the inside with the barrel spring too. ![]() default screw setting where the set screw is screwed out until it stops. ![]() with the set screw turned in until it is flush or level with the carb body.
Latest blog entry: My Low Wing plane
The Netherlands
Joined Nov 2009
The heli is old (and as heli's go, not the prettiest) and the engine is even older....
But the liquid cooling is pretty unique, I think.... In the fuel heli section there's a thread going on about .50 size glow engines in helicopters being converted to gassers: http://www.rcgroups.com/forums/showthread.php?t=1476259 They tend to have heat issues along with carburation issues, but the latter seems not to be the biggest problem: most of them get away with using the original carb, if needed with heat insulation. I am not occupying myself with glow-to-gas conversion, but have a heat-challenged fourstroke (glow fuel, spark ignition) in a helicopter that I am intending to convert to liquid cooling. From that point of view, I experimented with liquid cooling and got it working. Picked up a thing or two about gasser conversion along the way. Brgds, Bert |
The Netherlands
Joined Nov 2009
I have read the red lines, and they just don't make sense....
I am an engineer, and as such I would say (no offense intended) you are not fully understanding the design-philosophy of the rotating drum valve design. If the spraybar is centered in the rotating drum valve, the valve not only closes above the spray bar, but also below, closing off the spray bar from the suction of the crankcase. That is the whole idea behind the rotary drum valve with its dual variable orifice: the area between the upper and lower throttle area is supposed to be subjected to only a change in air-velocity, not a change in pressure (that is in reality not completely true because you get a dual pressure drop, which necessitates the airbleed screw on older designs and the LSN on more modern designs, but the idea is there) Therefore, at closed throttle, what you describe simply does not happen, as the LSN is closing off the spraybar opening, at least partly, and the lower throttle opening is closing off the spraybar from the crankcase suction. You can test this principle quite easy with a normal glow engine: just fuel the plane, but leave the fuel hose to carb empty. Apply the starter with open throttle, and repeat the same with throttle in idle position, and with fully closed throttle. You will not notice a big difference in fuel draw between full open and idle, and with the throttle fully closed, there is NO fuel draw, because the lower throttle opening closes off the spraybar completely from the crankcase pressure. No offence, but what you are saying is simply NOT happening, otherwise glow engines could not work either: they have the same working principle but no fuel pressure regulator to start with.... If there is a problem with the profile of the LSN as you describe in post #1010, that is a design flaw that has nothing to do with fuel pressure regulator, and also nothing with suction pressure in the carb throttle, but just with.... the design of the LSN profile.... Brgds, Bert |
I have to admit Turk1 I too am some what confused. the fuel flow is adjusted by the combination of crankcase pressure and the slot in the crankshaft. On a standard gasser there is usually a reed valve preventing back pressure from escaping the crank on this it is the same as a glow with a slotted crankshaft. As you know change in crankcase pressure is created by the piston moving and this pulse is what pumps the fuel at the pump/regulator and draws in the fuel through the carb. As the piston moves faster the pulses increase in speed and the suction through the carb increases. This works in reverse as well. I can only guess that you are missing the point of having a slot in the crankshaft as it is not only there to provide fuel to the crankcase but also to minimise positive pressure in the crankcase blowing back through the carb thus acting in the same way as a reed valve. Where I see the main problem is that the fuel/air mix is too close to the top of the carb and so can be disturbed making the engine run lean at times, we compensate that by running it extra rich which of course makes it idle poorly and spit fuel. this is why I am still exploring the velocity stack idea.
The Netherlands
Joined Nov 2009
It does not work that way AT ALL....
The pressure pulses in the crank operate a pump. That is true. but the pressure of the fuel, as delivered by that pump, is completely independant on engine speed or anything else, it is (should be, if the pump is functioning correct) ONLY determined by the atmospheric pressure. That is what the small hole in the pump body is for: to give atmospheric pressure access to the pressure regulating membrane. The exact pressure is not even that relevant, but the fuel pressure should have (within a range) a fixed overpressure compared to atmospheric pressure. That sets fuel pressure before the HSN orifice. Now the engine starts drawing in air, and this air movement creates a local low pressure at the spray bar opening. The vacuum at the spray bar opening is determined by 3 factors: atmospheric pressure, air velocity and throttle opening. Variations in atmospheric pressure is cancelled out by the fuel pump delivering at a set pressure above atmospheric. Variations in throttle opening should be compensated by the co-operation of HSN and LSN needles and the LSN needle profile, so there remains only the air velocity to draw in the correct amount of fuel. That is in theory. In reality, things are always a bit different of course, but in order to solve possible carburation problems, making sure your pressure regulator works OKand is not influenced by for example airspeed or propwash, is the biggest factor, as the carb is just similar to any glow carb, the only difference being that gas is much more sensitive to small changes in mixture strenght, compared to Methanol, and this is complicated by the fact that gas requires much smaller volume flow of fuel in relation to air, compared to methanol. The fuel pressure regulator is nothing more, than a device that makes it possible to achieve the desired accuracy and consistency, as the carb would for example function without too much problems on methanol without the regulator. So, if you have any mixture problems, and your carb is not leaking/faulty, your problem is 99% sure located in the functioning of the pressure regulator. Brgds, Bert |
I guess you used to use nitro blended fuel on your glows so it compansate some problems I met repeatedly.On many glow engines(mostly Chinese built) in years, I always met adjustment problems(especially .90 and bigger size) if low speed adj. doing well then engine stops during take off or even at nose up tests independent of how much HSN open.If WOT adjust put well then idling bogs engine down eventually to stop.This is only because LSN profile isnt appropriate with LSN travel to restrict enough and to allow enough fuel needed by engine.When I remake LSN profile to block enough at idling but to pull out fully at WOT from spray bar,then engine gets running like a champion.So unfortunately I cant agree with you,barrel keeps spray bar from engine vacuum.There is big pressure difference at spray bar mouth (maybe a little venturi effect at WOT but certainly a big vacuum at idle position).In GT 9 if LSN profile/travel designed properly then that vacuum would be ignored.But now simply we cant.
Proof is simple.Please adjust your GT9 well for idling then you will have a great low speed adjustment but impossible to have WOT. Maybe engine seems run good but at the very first second you take plane nose up,engine will immediately stop. Contrarily,if you adjust it to have good run at WOT then you will see its impossible to have a proper idle mixture(because LSN cant block enough now and regulator also allows more fuel).This is because barrel cant prevent vacuum as you think. But to change LSN profile more aggressive then may give you a good working system. |
The Netherlands
Joined Nov 2009
Proof you are wrong, is even simpeler.
Remember the old carbs with the air blee screw? They have a main needle, that is adjusted at full throttle, and there is NO LSN that is closing the spray bar.... the full spray bar is subject to the "vacuum" you claim there to be.... still, a very small bore of mostly only 1 to 1.5 mm, partly closed off by the adjustment screw, is sufficient to relese that "vacuum", and the fuel flow through that wide open spray bar is just sufficient for that engine at idle.... I am very sorry, but the vacuum at closed throttle that you speak of, does not exist!!!!! If that was true, an air bleed carburettor could never have worked properly. Of course there is a lower pressure than at WOT, but that is logic, the air has to pass two restrictions, so there are two pressure drops. But the crankcase vacuum is NOT present at the spray bar, not by far. What ever might be wrong with the chinese engines you have worked on, it is NOT that vacuum. Needle profiles, wrong fuel choice (some engines will not allow good adjustment with for example some synthetic oils due to their viscosity) I don't know, but it is NOT the vacuum. Personally, I couldn't care less, I find my way around any engine I have met so far, but if you are making wrong presumptions, you will come up with the wrong solutions, and that would be a shame.... Brgds, Bert |
![]() ....Here we mostly use no nitro,full castor homebrew fuels. If you have spare time,pls check this loonngg thread.The problem was only wrong LSN profile.They tried many ways except it. http://www.rcuniverse.com/forum/m_22...tm.htm#2308584 |
Joined Jun 2009
Spark plug
Hi all, may i know that this GT9 using spark plug: 1/4 x 32 Rcexl. is it same as this
CM-6?? http://www.hobbyking.com/hobbyking/s...idproduct=8867 Small gasoline engine look interesting. Wonder anyone try it on Raptor 50? and Will it direct 'drop-in' into the Raptor 50??
Yes, I beleive it would be a drop in replacement. But you have to keep the drive washer as it has the timing magnet on it. That might cause a problem with the flywheel, fan unit spacing though. The crankshaft has two flats machined on it to match the drive washer, so you could have a problem trying to get the flywheel farther back on the engine, plus the timing magnet won't work right if the flywheel is steel either. But you might be able to adjust the timing more to compensate. You would then need to shift the timing sensor to pickup the magnet properly then too. But some heli's may allow you to move the engine back farther to fit the flywheel on the engine with the drive washer attached. You would also need to come up with a larger head with more cooling fins on it as well. But that could be a clamp on head cooling fin extension too. |
I'd expect a 9cc gas engine made to run 10-2kRPM to fall far short of the power made by glow engines for 50 size helicopters.
Greg |
Latest blog entry: A tiny diesel engine AE 0.1CC
| Thread Tools | |
| For Sale Prop Chart and Thread finder for any Glow or Gas Engine | unclegeorge | Aircraft - Fuel - Engines and Accessories (FS/W) | 2 | Dec 10, 2011 11:31 AM |
| For Sale Prop Chart and Thread finder for any Glow or Gas Engine | unclegeorge | Aircraft - Fuel - Engines and Accessories (FS/W) | 2 | Oct 14, 2011 11:44 AM |
| For Sale Prop Chart and Thread finder for any Glow or Gas Engine | unclegeorge | Aircraft - General - Miscellaneous (FS/W) | 0 | Oct 07, 2011 10:46 AM |
| For Sale Prop Chart and Thread finder for any Glow or Gas Engine | unclegeorge | Aircraft - General - Miscellaneous (FS/W) | 3 | Sep 23, 2011 11:25 PM |
| Sold NGH GT17cc gas engine NIB | ibcinyourc.com | Aircraft - Fuel - Engines and Accessories (FS/W) | 4 | Jun 30, 2011 10:35 AM |
