Old Sep 03, 2012, 10:07 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Oh, OK. Yeah trying to cut the little spring is probably a bad thing to do, it is quite sensitive in its tension. If you go that route, it may be better to try different springs from a Walbro carb rebuild kit instead. I haven't seen a need to mess with the spring tension. But yeah a little tiny piece of debris getting stuck in the fuel inlet valve does mess up the works good causing the engine to run too rich or flood out even. When it happened to me, I took the regulator apart and didn't see anything causing it. But when I re-assembled it, the regulator worked fine since. So I must have flushed the tiny spec of something out when I cleaned it.
earlwb is offline Find More Posts by earlwb
Old Sep 03, 2012, 10:46 AM
Capt. Quirk is offline
Find More Posts by Capt. Quirk
Riverside Calif.
Joined Apr 2008
I will post a picture of the spring I am using later in the day.
After you install the spring, the factory settings no longer work. Currently
I have the throttle in a normal idle position, the low speed screw is 1 turn
out, and the high speed is 1 1/2 turns out.
Next weekend I will post pictures and results of testing with a APC 10-6,
11-7, and 12-6 propellers.
I am also planing on testing the engine sometime in the next few weeks at
San Diego's Mission Bay. That way I can test the engine in the best atmospheric
conditions possible for this time of the year.
Bill M.
Capt. Quirk is offline Find More Posts by Capt. Quirk
Old Sep 03, 2012, 03:24 PM
Gary Cee is offline
Find More Posts by Gary Cee
The best stuff is higher up
Gary Cee's Avatar
Joined Apr 2010
Just fired up another brand new YS 63 . Man it is so easy . Set the main needle right at 2 turns like all the others , flip the prop . Perfect fuel delivery . The thing runs greeeat ! Any time of year
But all of this has been fun too
Gary Cee is offline Find More Posts by Gary Cee
Old Sep 03, 2012, 06:55 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Did you convert that YS-63 to gas and spark ignition?
Old Sep 03, 2012, 07:55 PM
Gary Cee is offline
Gary Cee's Avatar
Joined Apr 2010
Not a chance
Old Sep 03, 2012, 08:49 PM
GadgetEric is offline
Find More Posts by GadgetEric
A few Models is not enough Hon
GadgetEric's Avatar
Australia, WA, Noranda
Joined Mar 2007
Also I have found the needle to be a bit sticky. Seems to be the arm from the needle to the diaphram binding in the slot on the needle
GadgetEric is offline Find More Posts by GadgetEric
Old Sep 03, 2012, 08:57 PM
Riverside Calif.
Joined Apr 2008
The WYJ spring part # 98-3160-7
Costs about .50 cents, same as jmaderoy predicted.
Old Sep 03, 2012, 09:28 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Thanks for the information. I appreciate it and I am sure others do too.
I flew the NGH 9cc engine equipped Escapade today as well as the Ugly Stick with the modified NGH 9cc engine. Both for several flights too.
I had to replace the regulator diaphragm as it softened up and stretched out over time and stopped regulating, same thing for the pump diaphragm too, as it got all stretched out too. So I suspect the stock NGH rubber diaphragms are made from a rubber compound that doesn't do well with our American pump gasoline over time. If you use SEF or TRU-Fuel the rubber parts might last longer. Anyway it was easy to swap out some Walbro carb diaphragms to fix the problem from a Walbro carb repair kit This might be what makes people think that the fuel inlet valve is stuck or something, when it may really be the diaphragm has softened up and stretched out on them. I had swapped out a second pump/regulator unit that worked well previously and it did the same thing. That was what prompted me to replace the diaphragms then.
I'll post a another video later. But I put a little brace on the pump/regulator on the Escapade to stop the unit from moving too much in loops and other maneuvers and that cured the lean out condition that would kill the engine. So it worked well today after the simple fix.
Old Sep 03, 2012, 09:36 PM
Riverside Calif.
Joined Apr 2008
Your welcome Earl,
The spring makes the biggest difference, but I will post some other details on fixing
the vacuum leaks too.
Old Sep 03, 2012, 09:52 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Cool thanks again. If it helps anyone else, the spring is found in a carb like the Walbro WYJ-250, there are several others too, like the WYJ-192, WYJ-322 and so on.
http://www.ereplacementparts.com/wal...61_142036.html
Old Sep 04, 2012, 12:14 AM
GadgetEric's Avatar
Joined Mar 2007
Pump Spring
I just went down the mower shop. He is out of 98-3160-7 but he had a grab kit with about 20 other types. Where do you start.
Old Sep 04, 2012, 01:07 AM
Boostoman is offline
Find More Posts by Boostoman
Boostoman's Avatar
Oman, Masqat
Joined Apr 2010
Originally Posted by GadgetEric View Post
Well I squeezed mine in to. I am pretty happy with the way it looks.
Had to make a muffler extention and a few right angle nipples
Pitty I cant get it to run
Hi Eric,
thanks looks like a really nice plane. what plane is it?
Boostoman is offline Find More Posts by Boostoman
Old Sep 04, 2012, 01:47 AM
Riverside Calif.
Joined Apr 2008
As far as I can tell, there is only one spring used in the WYJ series. You may need
to order it. My spring kit does not include that #, but there are several that may work.
If you can verify a 30 psi pop-off pressure, that will get you in the ball park. I will test my
spring kit next weekend.
In the mean time, the standard spring appears to be 10.5 mm long, and the 98-3160-7
is approximately 7.5 mm long.
I also include two other pics; one of the fuel pump with the extra nipple for measuring
fuel pump pressure. And the second one with an extra nipple on the carb for measuring
venturi pressure.
Bill M.
Old Sep 04, 2012, 02:00 AM
Riverside Calif.
Joined Apr 2008
I have noticed a difference in the diaphragms manufactured in China vs Japan. I am
testing with 87 octane unleaded regular, and Yamalube 2R oil. I will keep an eye on
the rubber parts. In fact, I think I'll incorporate an hr meter into my data acquisition
system.
Bill M.
Note: Does anybody know what California adds to our fuel blends that may harm rubber parts
faster than other states?
Old Sep 04, 2012, 05:11 AM
GadgetEric's Avatar
Joined Mar 2007
Originally Posted by Boostoman View Post
Hi Eric,
Its a Supersportster 40
For Sale Prop Chart and Thread finder for any Glow or Gas Engine unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 2 Dec 10, 2011 11:31 AM
For Sale Prop Chart and Thread finder for any Glow or Gas Engine unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 2 Oct 14, 2011 11:44 AM
For Sale Prop Chart and Thread finder for any Glow or Gas Engine unclegeorge Aircraft - General - Miscellaneous (FS/W) 0 Oct 07, 2011 10:46 AM
For Sale Prop Chart and Thread finder for any Glow or Gas Engine unclegeorge Aircraft - General - Miscellaneous (FS/W) 3 Sep 23, 2011 11:25 PM
Sold NGH GT17cc gas engine NIB ibcinyourc.com Aircraft - Fuel - Engines and Accessories (FS/W) 4 Jun 30, 2011 10:35 AM
