Old Mar 18, 2012, 11:12 PM
gravityking is offline
Find More Posts by gravityking
Demonstrations on Saturdays!
gravityking's Avatar
United States, TX, Arlington
Joined Jan 2012
As I discussed earlier I decided to get a test plane instead of messing with the test stand further.
Got a Seagull Decathlon .40. As a side note, great ARF & the NGH fits perfectly.
Anywho I ran it up & down the street taxi testing without a wing for 10 to 12 minutes burning quarter of a tank on 20 to 1 petroleum oil mix. No issues!! Using 10X7 MAS prop I got 14000 rpm at top end (surprise!) but could not get under 3000 for idle. And as stated above at idle throttle is near or at half open. Don't know when I'll get to maiden, back to work tomorrow. Will keep you informed.
Also can not hand start this gasser even primed & warm. A starter seems mandatory.
Thought some good news would raise some hopes! The problems can be ironed out!
gravityking is offline Find More Posts by gravityking
Last edited by gravityking; Mar 28, 2012 at 10:49 PM. Reason: prop size correction
Old Mar 19, 2012, 12:23 AM
fiery is offline
Find More Posts by fiery
fiery's Avatar
Hervey Bay, Queensland, Australia
Joined Mar 2008
Use a 32:1 mix and you will void any warranty.
Manufacturer specifies 20:1 for running in, after that no less oil than 25:1.
Oil must be full synth JASO FD spec.
fiery is offline Find More Posts by fiery
Old Mar 19, 2012, 10:25 AM
Joined Jan 2012
I would never use synthetic to wear in an engine. Just doesn't happen on synthetic but will be switching after the first gallon is run through.
Old Mar 19, 2012, 02:08 PM
flavinn is offline
Find More Posts by flavinn
Joined Jan 2012
Today I flew GT9 - First flight of 10 minutes and all normal - suddenly shut down with less than 3 minutes
Something called me a note, and she turned a propeller loose ... had no compression - a propeller spun free - How was no spark
Edit/Delete Message
flavinn is offline Find More Posts by flavinn
Old Mar 19, 2012, 07:03 PM
Mikarro is offline
Find More Posts by Mikarro
M$ Security
Joined Jun 2010
Originally Posted by the pope View Post
Wheres Mr Chow when you need him ? I hope hes not busy making his next line of engines . Cheers the pope
that's the job of chinese engine manufacturers, FAST CASH and bye bye
what did you expect of the ex JBA owner ? CRAP engines and buy the version 2 if you wanna keep it running.
Mikarro is offline Find More Posts by Mikarro
Reply With Quote  (Disabled)
Old Mar 20, 2012, 05:49 AM
Lifer is offline
Find More Posts by Lifer
Kansas City
Joined Apr 2010
This is sounding familiar........
Lifer is offline Find More Posts by Lifer
Old Mar 20, 2012, 06:52 AM
michael chow is offline
Find More Posts by michael chow
Joined Dec 2011
if that prefer CNC, Sir
michael chow is offline Find More Posts by michael chow
Old Mar 20, 2012, 06:55 AM
flavinn is offline
Joined Jan 2012
Problems with NGH engine 9cc (0 min 19 sec)
Problem???? what is???
Old Mar 20, 2012, 07:12 AM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Might pull the head and see if it blew a head gasket if it has one, or popped a hole in the piston.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Mar 20, 2012, 09:31 AM
Bpar4 is online now
Find More Posts by Bpar4
Virginia
Joined Jan 2004
Gord.
Gord, Bet that you broke the con rod. Since you noted something while flying, I'm thinking this is the problem. I had the same problem w/ my JBA. This usually is attributed to insufficient lubrication. However, I had it happen twice and when looking at the rod, the first time it look like a casting defect.
Bob
Bpar4 is online now Find More Posts by Bpar4
Old Mar 20, 2012, 09:59 AM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
If he takes the muffler off, which would be simpler, it would show the broken rod. As you say, if the piston don't move, it's the rod.
Gord.
Old Mar 20, 2012, 10:04 AM
Bpar4 is online now
Virginia
Joined Jan 2004
Fly/Gord: Also switched to Stihl HP. No problem since and the engine has pop-over compression just like a new glow engine. Can't wait to get my hands on this little jewel. Bob
Old Mar 21, 2012, 05:58 AM
Lifer is offline
Kansas City
Joined Apr 2010
My JBA 15cc broke the conrod. It was repaired under warranty and the tech said there was NO indication of a lack of lubrication. This is a quality issue, period.
Old Mar 21, 2012, 08:08 AM
flavinn is offline
Joined Jan 2012
Interestingly, the piston is going up normal, just very free
Old Mar 21, 2012, 08:17 AM
Mikecam is offline
Find More Posts by Mikecam
Mikecam's Avatar
Canada, MB, Winnipeg
Joined Apr 2008
My vote is you broke your ring. Pull the head off and make another video.
Mikecam is offline Find More Posts by Mikecam
For Sale Prop Chart and Thread finder for any Glow or Gas Engine unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 2 Dec 10, 2011 11:31 AM
For Sale Prop Chart and Thread finder for any Glow or Gas Engine unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 2 Oct 14, 2011 11:44 AM
For Sale Prop Chart and Thread finder for any Glow or Gas Engine unclegeorge Aircraft - General - Miscellaneous (FS/W) 0 Oct 07, 2011 10:46 AM
For Sale Prop Chart and Thread finder for any Glow or Gas Engine unclegeorge Aircraft - General - Miscellaneous (FS/W) 3 Sep 23, 2011 11:25 PM
Sold NGH GT17cc gas engine NIB ibcinyourc.com Aircraft - Fuel - Engines and Accessories (FS/W) 4 Jun 30, 2011 10:35 AM
