Old Dec 13, 2011, 07:56 AM
Mikarro is offline
Find More Posts by Mikarro
M$ Security
Joined Jun 2010
Rave
NGH 9cc gas engine thread
NGH is almost ready to deliver new gas engine... http://www.rcuniverse.com/forum/m_10..._1/key_/tm.htm
Specifications
* Type: 2 Cycle Air Cooled Gasoline Engine for Airplane Use Only
* Displacement (cc): 9.07cc
* Bore x Stroke (mm): 23.35 x 21.2
* Carburetor: NGH made 60G needle with pump membrane
* Maximum Output: 0.8HP@15000RPM
* RPM Range: 2600-15000RPM
* Ignition: Auto advanced RCEXL DC-CDI (RoHS and CE Certified) with special spark plug cap
* Spark plug type: 1/4 x 32 Rcexl
* Ignition Power DC 4.8 Volts (4 cell NiCad or NiMh battery
* Lubrication Oil: 2 cycle Engine Oil API TC / JASO FD or better specs. (Mobil + M2T)
* Break-in fuel oil ratio: 25:1 (4%)
* General use fuel: 20:1 - 25:1
* Recommended Propellers: 10x6 - 12x6 (two blades)
* Weight: 425g (without Ignition) 545g complete
Mikarro is offline Find More Posts by Mikarro
Reply With Quote  (Disabled)
Old Dec 13, 2011, 08:06 AM
TimBle is offline
Find More Posts by TimBle
South Africa, WC, Cape Town
Joined Dec 2009
Faaaaaantastic!
TimBle is offline Find More Posts by TimBle
Old Dec 14, 2011, 08:19 PM
chemnut842 is offline
Find More Posts by chemnut842
United States, MD, North East
Joined Apr 2011
So does this engine have needle bearings? I see it has an oil injection system yet still recommends ~20:1 mix in the fuel. I guess that means no needle bearings in the conrod? idk, if I wanted an oil thirsty motor I would just stick with glow... But I need more info.
chemnut842 is offline Find More Posts by chemnut842
Old Dec 14, 2011, 11:39 PM
turk1 is offline
Find More Posts by turk1
turk1's Avatar
Istanbul, Turkey
Joined Aug 2004
Yes no needle bearings for small engines because manufacturer(NGH) says there is no such small,reliable,good needle bearings.So he uses needle bearings on over 17CC engines.It is Chinglish so that "oil" word must be gasoline.So no oil injection but gas pump to carb..
turk1 is offline Find More Posts by turk1
Old Dec 15, 2011, 01:45 PM
Joined Apr 2011
Oh - well if it can safely run ~ 20:1 then I would be willing to give it a try even without a needle bearing. 5% oil beats 18-20 % Oil I am running in my glow motors... I wonder how the fuel economy will compare to the Saito 14 FG.
Old Dec 16, 2011, 12:40 AM
turk1 is offline
turk1's Avatar
Istanbul, Turkey
Joined Aug 2004
If I would be in your shoes,I would take it safe side and no worry to use more oil.(Unless you mean to involve racing ).Only will be needed to clean carbon time to time.
Old Dec 16, 2011, 10:33 AM
SpaceCowboy is offline
Find More Posts by SpaceCowboy
Brentwood ; Ontario
Joined Dec 2003
The engine has a FUEL PUMP operated off crankcase pressure.
NOT an "oil supply" or "oil filter" or "oil box" .
This a bad case of Chinglish .
It is always hard to translate technical language.
SpaceCowboy is offline Find More Posts by SpaceCowboy
Old Dec 17, 2011, 08:27 AM
Mikarro is offline
M$ Security
Joined Jun 2010
Neither GT17 nor GT25 have a needle bearing on the con-rod...
but you can install it yourself http://www.rcuniverse.com/forum/fb.asp?m=9643869
Old Dec 17, 2011, 01:50 PM
turk1 is offline
turk1's Avatar
Istanbul, Turkey
Joined Aug 2004
As I am informed directly from manufacturer(Michael Chow),NGH 25 and upper sizes have needle bearing conrod.(You can have bushing type conrod if you want,optional only for NGH 25 also)
Old Dec 18, 2011, 02:42 PM
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
Interesting. Is the the smallest gas engine out now? What size plane would it be for? I don't know much about gas power plants but want to learn more. I am assuming more torque at low RPM than glow since it has less top end HP (but similiar RPM)
seeingeyegod is offline Find More Posts by seeingeyegod
Old Dec 18, 2011, 09:59 PM
Joined Apr 2011
It is the smallest one I know of - I would put it in my senior telemaster. It really beats the price (I am only assuming this based on the price of their other engines - not sure what this one will cost) of the saito 14 cc gasser 4 stroke and the BME .90 ci conversion.
Old Dec 19, 2011, 06:59 AM
Mikarro is offline
M$ Security
Joined Jun 2010
the BME 90 is a 15cc engine of course it's a Super Tiger (chinese glow engine) converted to gas and they want 400 bucks for it.. What a huge margin profit!
it runs just fine because the Walbro carb however I cannot tell you the same about the FG14 and its glow carb issues.
the lowest price of the GT9 I have found online it's here VAT included 149€ http://www.modelpascher.com/catalog/...u6jhh1jqd08s26
Old Dec 19, 2011, 11:48 AM
turk1 is offline
turk1's Avatar
Istanbul, Turkey
Joined Aug 2004
Lowest price I think at Hi Model.http://www.himodel.com/sort.php?brand=228
165,5 $
Old Dec 19, 2011, 01:09 PM
Mikarro is offline
M$ Security
Joined Jun 2010
turk1 they added it this afternoon because in the morning it was not advertised there yet.
about the price if you live in Europe you have to add 20% - 25% for taxes and customers fees + shipping from HiModel so it's a bit cheaper from the link I posted above. NGH does not have any MSRP and some dealers are crying because they cannot beat that great price..
Old Dec 19, 2011, 04:35 PM
Joined Apr 2011
It's hard to resist.... Any speculation on the stability of that price? It is so much cheaper than the other engines from that manufacturer....
For Sale Prop Chart and Thread finder for any Glow or Gas Engine unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 2 Dec 10, 2011 11:31 AM
For Sale Prop Chart and Thread finder for any Glow or Gas Engine unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 2 Oct 14, 2011 11:44 AM
For Sale Prop Chart and Thread finder for any Glow or Gas Engine unclegeorge Aircraft - General - Miscellaneous (FS/W) 0 Oct 07, 2011 10:46 AM
For Sale Prop Chart and Thread finder for any Glow or Gas Engine unclegeorge Aircraft - General - Miscellaneous (FS/W) 3 Sep 23, 2011 11:25 PM
Sold NGH GT17cc gas engine NIB ibcinyourc.com Aircraft - Fuel - Engines and Accessories (FS/W) 4 Jun 30, 2011 10:35 AM
