Old Mar 05, 2012, 04:22 AM
argo-2 is offline
Find More Posts by argo-2
Maiden>Confident>Cocky>Crash!
argo-2's Avatar
New Zealand
Joined Feb 2010
Originally Posted by SkylineFlyer View Post
Holy Cow! 1 minute? That sounds like my Habu32. I kill the power in that and do one complete circuit around my field and I still come in too hot sometimes. Anyways, enough about my plane. Again, that was really cool. I hope to maybe get one when they are back in stock. What size servos, esc and motor are you using?
Anyone tried reverse-thrust? Works pretty well on my AXN CloudsFly e-glider. Only change required is to re-program the ESC (can only do with certain brands of ESC though).
Hey Opt (fellow Kiwi) where did you bring your X8 in from?
argo-2 is offline Find More Posts by argo-2
Old Mar 05, 2012, 04:27 AM
austin.laws is offline
Find More Posts by austin.laws
Night flier
United Kingdom, England, Bromyard
Joined Mar 2008
For the price of this model plus shipping i would rather go for a large glider and FPV it. Just smacks a bit of a rip off to me. Its only foam and a bit of wood. I can get a 3M glider plus motor and folding prop for Ģ149 shipped in 2 days. I like the X8 dont get me wrong but i rather just go for the glider plus you can easy get over a hours flying if you know wot ur doing.
austin.laws is offline Find More Posts by austin.laws
Old Mar 05, 2012, 04:46 AM
D-OCHO is offline
Find More Posts by D-OCHO
The Netherlands, OV, Oldenzaal
Joined Jul 2010
So why do you think the X8 will not glide.
BIG wing, light (remember made of foam and a few pieces of wood),
install a folding prop and a vario and have fun with it.
Much easier to install stuff then a small glider fuselage.
D-OCHO is offline Find More Posts by D-OCHO
Old Mar 05, 2012, 06:00 AM
realtimerecon is offline
Find More Posts by realtimerecon
Real Time Recon
realtimerecon's Avatar
smith mt. lake VA.
Joined Jan 2007
How about a Ballistic chute inside that big fuse,as seen here. If deployed at 100 ft. or so That would allow for landing in a tighter spot >>> http://www.flyingmag.com/brs-parachute-recovery-systems
realtimerecon is offline Find More Posts by realtimerecon
Old Mar 05, 2012, 06:26 AM
Carlos230023 is offline
Find More Posts by Carlos230023
um.. yeah, I can make that fly
Carlos230023's Avatar
United Kingdom, Milton Keynes
Joined Jun 2007
Just whack a couple of but glider style air brakes on the wings. That'll let you drop it where you want. It'd be an easier mod than a parachute. And you could abort the landing safely should you need to.
CJ
Carlos230023 is offline Find More Posts by Carlos230023
Old Mar 05, 2012, 06:50 AM
jet72 is offline
Find More Posts by jet72
Austria, Wien, Vienna
Joined Feb 2012
Originally Posted by Psionic001 View Post
Any chance of seeing installation photos of the FY31 with batteries and all other gear in place? We had to throw our FY31 in front of the front bulkhead as 24 amps of battery took up almost entirely the whole central payload area.
FY31AP position should be near the C of G - otherwise it will not work efficient
jet72 is offline Find More Posts by jet72
Old Mar 05, 2012, 07:26 AM
jet72 is offline
Joined Feb 2012
hereīs the chance to see a photo
Old Mar 05, 2012, 08:43 AM
Gary Evans is offline
Find More Posts by Gary Evans
FPV Desert Beta Test Center
Mesa, Arizona
Joined Nov 2006
Why would that be the case?
It has no idea where it is located in the plane just how much it is tilted in any given direction and the degree of tilt is the same regardless of location.
Gary Evans is offline Find More Posts by Gary Evans
Old Mar 05, 2012, 08:50 AM
jet72 is offline
Joined Feb 2012
the guys from feiyu tech told me that....think they know how their products work
Old Mar 05, 2012, 09:41 AM
saabguyspg is offline
Find More Posts by saabguyspg
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
FY does not HAVE to be at c of g... yes it will peform better at c of g but really it atually performs quite well of c of g in the front back direction.
Steve
saabguyspg is offline Find More Posts by saabguyspg
Old Mar 05, 2012, 11:17 AM
jet72 is offline
Joined Feb 2012
Steve
Old Mar 05, 2012, 12:53 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Every part of the fuse rotates exactly the same as every other part of the fuse at the same time, near the CG or not.
ian
Daemon is online now Find More Posts by Daemon
Old Mar 05, 2012, 01:07 PM
Ian Davidson is offline
Find More Posts by Ian Davidson
Old Blighty
Joined Apr 2010
I don't own an FY31AP (or any of that family), but from what I understand it has integrated accelerometers as well as gyros? If this is the case and it's using the accelerometer inputs to base it's stabilisation on, then it would seem to follow that it could make a difference where you place it.
e.g. putting an accelerometer on the outside of a bicycle wheel would read different than were it closer to the rotational centre/axle.
Ian Davidson is offline Find More Posts by Ian Davidson
Old Mar 05, 2012, 01:12 PM
mille is offline
Find More Posts by mille
Belgium
Joined Aug 2005
ian
Indeed. That's relatively straightforward to understand for the mathematically inclined, but absolutely counter-intuitive for the mathematically declined.
Still, accelerations and vibrations are different in different parts of the fuse, and they can adversely affect the performance of a gyro and the control system built around it to some extent. As it happens, the smallest extremes typically occur near the CG.
mille is offline Find More Posts by mille
Old Mar 05, 2012, 03:13 PM
jet72 is offline
Joined Feb 2012
ian
21. FY-31AP installation: Orientation, Position and level
a) The FY-31AP has an arrow printed on the top of it. Orientate the
arrow towards the front of the craft (i.e. direction of flight).
b) When installing, please keep the FY-31AP horizontal and as close as
possible to the "Centre of gravity" (COG) of the aircraft.(as the
following diagram)
so point 21.b. in the feiyutech manual is just for fun?
New Product X8---new 2.4GHz Radio System ASSAN Radios 5733 Yesterday 01:23 PM
For Sale Assan 2.4 ghz X8 6ch receiver Brand New Scooter33 Aircraft - General - Radio Equipment (FS/W) 2 Oct 12, 2011 10:34 AM
Discussion Any info regarding this x8 setup?Better than coax x8? sjak Multirotor Talk 11 Aug 14, 2011 09:33 AM
Sold New Assan Module X8 2.4 for JR Tx norstaroption Aircraft - General - Radio Equipment (FS/W) 6 Nov 21, 2009 06:42 AM
Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 EyeFlyPlanes Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2008 03:39 AM
