Old Oct 05, 2013, 06:38 PM
xviper is online now
Find More Posts by xviper
Canada
Joined Jul 2009
Originally Posted by Kenneth Eriksson View Post
Thanks, I´ll go and order one.
Many say the wings are the weak point on it, how if I install the fins closer to the fuselage, whould that help to stabilise the wing, what do you think?
Or any other way to stabilise the wings on?
Ken
"Many"??? Are these people the "Charlie Brown" types who have only bad luck when flying a kite (X8 in this case)? I've flipped my X8 upside down during landings and flew it into a lamp post. The wings are NOT the weak point on this plane. You're over thinking this thing.
xviper is online now Find More Posts by xviper
Old Oct 05, 2013, 08:08 PM
Zedtwitz is offline
Find More Posts by Zedtwitz
United States, NY
Joined Jan 2012
Ken
Can someone explain that emoticon to me? It seems half-sarcastic, half-determined, but I don't see any use for it in forums.
Zedtwitz is offline Find More Posts by Zedtwitz
Old Oct 06, 2013, 12:05 AM
crash goodly is online now
Find More Posts by crash goodly
Joined Apr 2009
[QUOTE=Zedtwitz;26295721]Can someone explain that emoticon to me? It seems half-sarcastic, half-determined, but I don't see any use for it in forums.[/QUOTE
the emoticon means COOL. how could that you?
crash goodly is online now Find More Posts by crash goodly
Old Oct 07, 2013, 08:05 AM
Kenneth Eriksson is offline
Find More Posts by Kenneth Eriksson
Sweden, Skåne County, Malmö
Joined Feb 2013
Do you have problems with me asking questions that I think is important for me, if so then you can directly PM me. Others don´t have to read this.
This is a good way to scare away people from forums and this hobby. But I know there are nuts in all hobbies and after my 37 years of model flying it takes more to scare me of. At least am I strong enough to write where I´m from.
I get so pissed of comments like that.
Ken
Kenneth Eriksson is offline Find More Posts by Kenneth Eriksson
Old Oct 07, 2013, 09:20 AM
Zedtwitz is offline
United States, NY
Joined Jan 2012
I don't have a problem. There's just no need to assert your "coolness" in a forum - it's awkward and strange.
The only problem people have had with the wings is that they can flap at high speeds (greater than 50 mph), but reinforcing them negates the issue. Just embed carbon spars in the wings with CA.
Old Oct 07, 2013, 09:26 AM
boopidoo is offline
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
@Kenneth
If you're interested in the X8 I would suggest you buy it. All airframes have cons and pros but the X8 has by now a long list of mods that can make it suitable for many purposes.
I guess it would be easier to say if the airframe is suitable if you list what you want to get out of it. It is VERY different then the Cap in almost everything except both being wings and have a pusher prop.
Cheers
Simon
boopidoo is offline Find More Posts by boopidoo
Old Oct 07, 2013, 09:33 AM
Zedtwitz is offline
United States, NY
Joined Jan 2012
I should add that the wings are the strongest part of the airframe, and the nose is the weakest. If you're used to the Caip's ability to withstand a nose-on collision with the ground, you'll have to change your landing style or it won't last long.
Old Oct 07, 2013, 09:54 AM
JoshW24 is offline
Find More Posts by JoshW24
aka JoshW, damightyj
JoshW24's Avatar
United States, CA, San Diego
Joined Jun 2013
Agreed. I've had a single nose-in at low speed (but nasty AoA) and had to re-glue the seams and sort of un-scruntch some of the foam up front. The wings, while flexible, hold ok. You just need to make sure you don't have high-performance/high-speed expectations of the airframe and you should be fine with the few common mods listed in this thread (extra carbon spars and reinforcement, extreme packing tape and possibly a covering like laminate or vinyl wrap, etc)
JoshW24 is offline Find More Posts by JoshW24
Old Oct 07, 2013, 03:24 PM
Joined Feb 2013
Exactly what I have done, I waiting for it to arrive.
Ken
Originally Posted by boopidoo View Post
@Kenneth
Cheers
Simon
Old Oct 07, 2013, 03:50 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
The reason the X8 has a reputation for "weak" wings, has nothing to do with
their ability to take a crash. It's all about high speed flex and twist. Stock
wings with stock wing joiner will flap at high speeds, especially if you try to go fast
low level bumpy air. It can be quite dramatic, and can lead
to total destruction of the airframe. It wouldn't be an issue if the plane
wasn't naturally pretty fast. Loaded up with fpv gear and a couple batteries,
if you pitch it over into a medium angle dive with the motor off, it will easily accelerate
to it its flutter speed, if you don't reinforce the wings. Mine will dive at 70+mph,
power off.
I would never build an X8 without at least increasing the size of the stock joiner
and reinforcing the wings in some way. My current X8 has carbon ribbons
top and bottom to stop flex, and 3mil laminating on the forward half to 2/3rd of
the wing (wrapped around the leading edge), to reduce twist.
I addressed the weak nose with Kevlar cloth (detailed earlier in the thread).
ian
Daemon is offline Find More Posts by Daemon
Old Oct 09, 2013, 05:52 AM
Joined Feb 2013
Exactly what I needed to hear.
What kind of Laminate do you use, and do you also know where to buy it? How do you stick it to the wing?
Kevlar do I use first then the first crash is done.
Ken
power off.
ian
Old Oct 09, 2013, 03:42 PM
dtiansio is offline
Find More Posts by dtiansio
Daniel
dtiansio's Avatar
France, IDF, Versailles
Joined Jun 2012
ian
Could you show us pictures of your X8
dtiansio is offline Find More Posts by dtiansio
Old Oct 09, 2013, 04:17 PM
galaxiex is offline
Find More Posts by galaxiex
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
Look here >>> http://www.rcgroups.com/forums/showp...postcount=1146
galaxiex is offline Find More Posts by galaxiex
Old Oct 10, 2013, 05:38 AM
Gatos is offline
Find More Posts by Gatos
www.eahk.gr at Iraklion Grete
Gatos's Avatar
Greece, Crete
Joined Jun 2012
My opinion is that X8 is to fast wing for FPV
I think this from HK SkyEye
http://www.rcgroups.com/forums/showt...ighlight=skyey
is better platform for FPV. Lower speed and gliding
Gatos is offline Find More Posts by Gatos
Old Oct 10, 2013, 05:55 AM
Pattaya01 is offline
Find More Posts by Pattaya01
When a hobby gets a passion
Thailand, Chon Buri, Pattaya
Joined Sep 2012
Are you flying the X8?? Do you have any experience with it? The X8 is as slow or as fast as you want it to be. It cruises very happy at 60Km/H which is a perfect speed for FPV. You can slow it to 45-50Km/H without any problem.
Pattaya01 is offline Find More Posts by Pattaya01
New Product X8---new 2.4GHz Radio System ASSAN Radios 5740 Mar 06, 2016 01:21 PM
For Sale Assan 2.4 ghz X8 6ch receiver Brand New Scooter33 Aircraft - General - Radio Equipment (FS/W) 2 Oct 12, 2011 09:34 AM
Discussion Any info regarding this x8 setup?Better than coax x8? sjak Multirotor Talk 11 Aug 14, 2011 08:33 AM
Sold New Assan Module X8 2.4 for JR Tx norstaroption Aircraft - General - Radio Equipment (FS/W) 6 Nov 21, 2009 05:42 AM
Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 EyeFlyPlanes Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2008 02:39 AM
