Old May 04, 2013, 09:19 AM
jimcartin is offline
Find More Posts by jimcartin
Joined Jan 2009
parachute for x8
This is the description of a parachute system for x8 skywalker wing. decided to upload this video because there were many questions about how the system worked, I hope this video respunda many of your questions for x8 users
parachute for x8 (4 min 11 sec)
jimcartin is offline Find More Posts by jimcartin
Old May 06, 2013, 05:35 AM
gtlavin56 is offline
Find More Posts by gtlavin56
Joined Oct 2011
I love it, try this one excelent plane and glider deleted dear friends thanks for your support
gtlavin56 is offline Find More Posts by gtlavin56
Old May 06, 2013, 04:51 PM
AlfaHeli is offline
Find More Posts by AlfaHeli
AlfaHeli's Avatar
Joined Nov 2009
checking CG
Would appreciate any post references or suggestions about an easy/practical method to verify CG. Is there a special or home made tool?
AlfaHeli is offline Find More Posts by AlfaHeli
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Finger tips work for me.
Daemon is offline Find More Posts by Daemon
Old May 06, 2013, 05:01 PM
xviper is online now
Find More Posts by xviper
Canada
Joined Jul 2009
Yup, same here. I did buy one of these a while back ...................
http://www.snhobbies.com/product_inf...5c1c26c22c03f2
However, for a big plane like this one, using your finger tips is much easier, quicker does the job. For smaller planes where a precise balance is important, I'll use the balancer.
xviper is online now Find More Posts by xviper
Old May 06, 2013, 05:53 PM
Zedtwitz is offline
Find More Posts by Zedtwitz
United States, NY
Joined Jan 2012
Challenge ya to find a reversible ESC that'll turn a 3 phase motor at the Kv rating you want.
Couldn't just take a normal ESC and put a couple MOSFETs (or relays) in to switch the two terminals? Shouldn't take more than an Arduino.
Zedtwitz is offline Find More Posts by Zedtwitz
Old May 07, 2013, 04:13 AM
King_Ice_Flash is offline
Find More Posts by King_Ice_Flash
King_Ice_Flash's Avatar
WI
Hopefully that isn't for a folding prop.
King_Ice_Flash is offline Find More Posts by King_Ice_Flash
Old May 07, 2013, 12:00 PM
AlfaHeli is offline
AlfaHeli's Avatar
Joined Nov 2009
Thank you guys..
Old May 10, 2013, 06:03 AM
techspy is offline
Find More Posts by techspy
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Well I maidened my X8 yesterday. I was able to successfully wing launch it. It took a couple tries to figure out the best technique. The first 3 attempts were with 4s 8000mah and while holding it about 6 inches from the wing tip. It didn't work but I was launching over about 4 feet tall wheat so it just ended up with a bent nose that can be fixed.
I finally got it in the air by holding it about a foot from the center of the fuse for launch and using a 4s 5300mah battery. I also am running a smaller prop that I think I need (11x10) but it is producing about 700 watts. I have a larger prop on the way which my help with some static thrust to get it in the air even easier. I will try the 4s 8000 with the new prop.
Otherwise it flies great, takes a mile to land and flutters at top speed.
I will be looking for something to help slow it down. Split ailerons, air brake or something.
techspy is offline Find More Posts by techspy
Latest blog entry: My Esprit Saga
Old May 10, 2013, 07:44 AM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
HK airbrakes work well
ommadawn is offline Find More Posts by ommadawn
Old May 10, 2013, 07:56 AM
techspy is offline
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
The ones that pop straight up? I remember seeing that being a possibility but there was a question of it causing unintentional pitch. Has it been tested and shown to work correctly?
Old May 10, 2013, 08:02 AM
Pattaya01 is offline
Find More Posts by Pattaya01
When a hobby gets a passion
Thailand, Chon Buri, Pattaya
Joined Sep 2012
Follow Deamons guide for wing enforcement. No flutter.
Pattaya01 is offline Find More Posts by Pattaya01
Old May 10, 2013, 09:34 PM
ommadawn is offline
The Flying Circus
ommadawn's Avatar
Joined Sep 2007
These work just fine
http://www.hobbyking.com/hobbyking/s...Search=spoiler
I use flight stabilization so pitch is not a problem, but without stabilization I get nose dropping a bit on deployment, which isnt a problem.
She comes down quite quickly.http://www.rcgroups.com/forums/showa...8&d=1358658441
http://www.rcgroups.com/forums/showa...9&d=1358658441
Old May 10, 2013, 10:57 PM
iskess is offline
Find More Posts by iskess
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
Has anyone tried twin rudders on the winglets? If so, has anyone tried to use them opposing each other to act as speed brakes?
iskess is offline Find More Posts by iskess
Old May 11, 2013, 01:04 AM
HawkHunter is offline
Find More Posts by HawkHunter
Psalm 37:4
HawkHunter's Avatar
Litchfield Park, AZ.
Joined Jun 2006
Here is one on YouTube:
X8 drag-rudder/brake (left wing) (0 min 50 sec)
HawkHunter is offline Find More Posts by HawkHunter
New Product X8---new 2.4GHz Radio System ASSAN Radios 5743 Sep 01, 2016 11:51 AM
For Sale Assan 2.4 ghz X8 6ch receiver Brand New Scooter33 Aircraft - General - Radio Equipment (FS/W) 2 Oct 12, 2011 09:34 AM
Discussion Any info regarding this x8 setup?Better than coax x8? sjak Multirotor Talk 11 Aug 14, 2011 08:33 AM
Sold New Assan Module X8 2.4 for JR Tx norstaroption Aircraft - General - Radio Equipment (FS/W) 6 Nov 21, 2009 05:42 AM
Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 EyeFlyPlanes Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2008 02:39 AM
