Old Feb 09, 2012, 03:02 AM
Psionic001 is offline
Find More Posts by Psionic001
Psionic001's Avatar
Australia, NSW, Sydney
Joined Apr 2006
Photos people....
Please post lots of photos....
Camera Bays, bellies, places to install retracts!!!!
Psionic001 is offline Find More Posts by Psionic001
Old Feb 09, 2012, 03:11 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I've got a lot of big 3S batteries so am less interested in the stock low Kv motor meant to be run
at 4S voltage. Scorpion motors have been good to me (reliable, efficient, cool running, good power to
weight ratio, under rated max amps) so I picked up the last one of these
http://www.rcdude.com/servlet/the-12...ushless/Detail
SII-3020-1110Kv and plan to run it with a 12x8.5 folding prop.
Prop specs chart http://www.rcdude.com/servlet/the-te...1110Chart/Page
doesn't list that exact combo, but APC 12x8E maxes out at 82oz of thrust with highest
efficiency of any 3S prop combo in the chart. Hard to say how that'll play out at
lower cruising revs, but I don't have a lot of choices in folding prop sizes.
ian
Daemon is online now Find More Posts by Daemon
Old Feb 09, 2012, 03:14 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Originally Posted by Psionic001 View Post
Photos people....
I haven't been posting fuse detail photos because they were all covered a few pages ago.
Start here and step through em http://www.rcgroups.com/forums/attac...mentid=4579837
And as I said above, the lower pocket is designed for a GoPro, so it's 60mm wide inside, and angled down 35mm.
Upper pocket is designed for flight camera, and it's 40mm wide inside.
If there's something not covered by those photos then tell us what specifically you need.
ian
Old Feb 09, 2012, 05:17 AM
Funky Diver is offline
Find More Posts by Funky Diver
Look Sideways at Polarisation
Funky Diver's Avatar
United Kingdom, England, Darlington
Joined Jun 2011
Wing mounting detail. You can see the additional spar inside the wing in the second photo. That runs the length of the entire wing.
You can also see that there are in fact two ply plates for location, there's also a hole through the wing. I'm going to be fitting a locking dowel into that to lock wings.
Funky Diver is offline Find More Posts by Funky Diver
Old Feb 09, 2012, 05:31 AM
Angelos is offline
Find More Posts by Angelos
Angelos's Avatar
Didcot, UK, OX11
Joined Sep 2003
Do you plan to use the glue that comes in the kit? I am considering using UHU Por instead as I have previously used it to glue ply to EPP and held really well.
Anyone else has views on this? Does UHU Por hold as good on EPO as it does on EPP?
Cheers,
Angelos
Angelos is offline Find More Posts by Angelos
Old Feb 09, 2012, 05:57 AM
Joined Jun 2011
I'm using UHU Por Angelos. It does a fabby job on EPO, it's what's holding my SkyWalker together.
Old Feb 09, 2012, 05:58 AM
jamied is offline
Find More Posts by jamied
australia
Joined Apr 2009
HI all
Are the wing tips mounted vertical or off to a out side angle
Thanks Jamie
jamied is offline Find More Posts by jamied
Old Feb 09, 2012, 06:13 AM
Carlos230023 is offline
Find More Posts by Carlos230023
um.. yeah, I can make that fly
Carlos230023's Avatar
United Kingdom, Milton Keynes
Joined Jun 2007
uhu por is the only glue i use for foam these days, it grips well, is solid but allows for a bit of flex under stress, has a little expansion and grips like the best of them, two of my wings are held together with nothing but uhu por. highly recommended.
CJ
Carlos230023 is offline Find More Posts by Carlos230023
Old Feb 09, 2012, 06:23 AM
heinduplessis is offline
Find More Posts by heinduplessis
Foam Snow
South Africa, WC, Cape Town
Joined Aug 2011
Can I be a pain and ask for a more zoomed out version of the pictures?
Are those wings ok to be detached and re-attached at flight time?
heinduplessis is offline Find More Posts by heinduplessis
Old Feb 09, 2012, 06:32 AM
Angelos is offline
Angelos's Avatar
Didcot, UK, OX11
Joined Sep 2003
Yes, they can be detached. Remove a pin (or plastic nylon screw that I will probably use) and slide the wing out. The pin locks two piece of ply together one of which is glued on the wing and the other on the fuselage.
The servo will obviously need to disconnect together with any other FPV gear that may be sitting on the wing (VTX, UHF receiver etc).
-Angelos
Old Feb 09, 2012, 06:35 AM
Psionic001's Avatar
Joined Apr 2006
Thanks for those photos.
Is the spar quality any good? Or would you consider some solid spars in there?
What's the spar diameter?
Old Feb 09, 2012, 07:16 AM
Bauf is offline
Find More Posts by Bauf
Norway
Joined Aug 2011
Just got my X8 today, only missing the motor. I think i'll wait with the build until i see some buildblogs :P i think maybe i'll use quick epoxy instead of uhu por. oh, and 1 thing.. i cant figure out where the 2 small square balsa is going..
Bauf is offline Find More Posts by Bauf
Old Feb 09, 2012, 07:33 AM
fpvnick is offline
Find More Posts by fpvnick
My other vehicle is unmanned
fpvnick's Avatar
Joined Jan 2010
I will probably use ca on her as i have with all my funjets and previous wings. Its light and quick setting when used with kicker making lining up parts easy. I never had any problems with it in the past. I have a tube of uhu por as well ill keep it handy incase i need some.
i didn’t notice that the carbon spar ran the hole length of the wing great.
fpvnick is offline Find More Posts by fpvnick
Old Feb 09, 2012, 07:38 AM
Joined Jun 2011
Which balsa? I never received any in mine.
Old Feb 09, 2012, 07:43 AM
Bauf is offline
Norway
Joined Aug 2011
im sorry, plywood :P
New Product X8---new 2.4GHz Radio System ASSAN Radios 5740 Mar 06, 2016 01:21 PM
For Sale Assan 2.4 ghz X8 6ch receiver Brand New Scooter33 Aircraft - General - Radio Equipment (FS/W) 2 Oct 12, 2011 09:34 AM
Discussion Any info regarding this x8 setup?Better than coax x8? sjak Multirotor Talk 11 Aug 14, 2011 08:33 AM
Sold New Assan Module X8 2.4 for JR Tx norstaroption Aircraft - General - Radio Equipment (FS/W) 6 Nov 21, 2009 05:42 AM
Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 EyeFlyPlanes Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2008 02:39 AM
