Old Feb 05, 2013, 07:21 AM
Oso M is offline
Find More Posts by Oso M
Keep calm and carry on.
Oso M's Avatar
United States, VA, Falls Church
Joined Jan 2012
Quick vid of my electronics set up. Still haven't placed antennas for optimal. But I wanted to show Dragonlink with APM2 and RFD900 telemetry.
UAV/FPV Setup (3 min 47 sec)
Oso M is offline Find More Posts by Oso M
Old Feb 05, 2013, 07:25 AM
chillybee is offline
Find More Posts by chillybee
Plainfield, New Jersey, United States
Joined Mar 2003
So what exactly makes these parts worth $75? Is it the ability to disassemble the wings and wingtips using screws? Couldn't these parts be made from some other light material that costs a little bit less?
chillybee is offline Find More Posts by chillybee
Old Feb 05, 2013, 10:22 AM
xviper is offline
Find More Posts by xviper
Canada
Joined Jul 2009
Originally Posted by williamjames View Post
$75 is almost half the price of the plane. Isn't that quite a bit? I know some people are gonna say, "it's a small price to pay if your sending up a thousand dollars worth of fpv gear up"... but really, don't you think that's over priced?
Originally Posted by Pattaya01 View Post
That was exactly the same thought I had when I saw that.
While I agree that's a lot of money for what seems like a few little pieces, one has to consider that almost anything made for a limited aftermarket is going to be pricey. Of course, we all have the choice to not buy it if we think it's poor value for the money.
This same philosophy applies to specialty car aftermarket. Years ago, I came up with a simple device that cost me less than a buck in materials to make and 5 minutes of my time, yet people were willing to pay me $20.00+ for it.
xviper is offline Find More Posts by xviper
Old Feb 05, 2013, 02:47 PM
wep is offline
wep
Find More Posts by wep
wep
https://vimeo.com/wep800
wep's Avatar
Joined Dec 2006
Originally Posted by ttucker View Post
How does that setup effect the aerodynamics when lowered?
It is even gonna effect in a positive way when you compare it with placing a camera on top talking about an X8.
I haven't seen this plane in a windtunnel but when you look at this plane you can imagine that the body itself also has the shape of a wing and thus will produce some lift.(maybe more then we think)
Placing a Gopro on top is like placing a spoiler in the up position, removing all lift for the width of the Gopro.
By placing the camera on the bottom you only have parasite drag which you always will have
Parasitic drag is drag caused by placing an object in streaming air.
To reduce that is streamlining.
The parasite drag stays the same is the same when you place it on top or below.
Another trick to reduce this loosing lift problem is to place the Gopro a lot higher on a pole so most air can flow freely beneath the GoPro.
The MAIN reason I am building the retractable camera is because then I have full free 360 view and down.
wep is offline Find More Posts by wep
Old Feb 06, 2013, 05:46 AM
Pattaya01 is offline
Find More Posts by Pattaya01
When a hobby gets a passion
Thailand, Chon Buri, Pattaya
Joined Sep 2012
Just the fact that so many people loose the hatch already indicates the body gives considerable lift. If the hatch is being sucked away, it means there is quite some low-pressure on the surface of the fuselage.
Pattaya01 is offline Find More Posts by Pattaya01
Old Feb 06, 2013, 06:13 AM
Oso M is offline
Oso M's Avatar
Joined Jan 2012
Sometimes I wonder if losing the hatch is caused both by the lift, but by the positive pressure created from the forward inlets. If that air didn't exhaust fully it's definitely creating an extra outward push on that thing.
Old Feb 06, 2013, 06:22 AM
satgod is offline
Find More Posts by satgod
satgod's Avatar
United States, KY, Hardin
Joined Jun 2011
I was thinking the same thing Oso M
in fact I was thinking about replacing the 2 front magnets with to small nylon screws
satgod is offline Find More Posts by satgod
Old Feb 06, 2013, 07:26 AM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
I dont trust magnets. I just use gaffa tape
ommadawn is offline Find More Posts by ommadawn
Old Feb 06, 2013, 09:23 AM
xviper is offline
Canada
Joined Jul 2009
I made a lip out of balsa ply and hot glued it to the front of the hatch in the middle. I continue to use all the magnets supplied. That hatch has never come off, even in high velocity conditions or in a lengthy dive.
The trouble with magnets may be in the installation. If the two opposing magnets at each point aren't lined up or if they don't touch when put together, the hold is a weaker. Rare earth magnets are strong. It's the installation that may be weak.
Old Feb 06, 2013, 04:14 PM
crash goodly is offline
Find More Posts by crash goodly
Joined Apr 2009
Originally Posted by Oso M View Post
Sometimes I wonder if losing the hatch I'd caused both by the lift, but by the positive pressure created from the forward inlets. If that air didn't exhaust fully it's definitely creating an extra outward push on that thing.
did you find that your hatch sat high when you installed it? mine needed me to shave a 1/3 of an inch off the tabs for it to sit flush. though the magnets hold well i to believe the pressure build up could pop the canopy. i've had this happen before with large canopy models.
crash goodly is offline Find More Posts by crash goodly
Old Feb 06, 2013, 05:07 PM
KiwiKid is offline
Find More Posts by KiwiKid
RCGroups - my happy place
KiwiKid's Avatar
Hamilton, New Zealand
Joined Jun 2005
Here's what I did on mine: http://www.rcgroups.com/forums/showp...postcount=6498
KiwiKid is offline Find More Posts by KiwiKid
Old Feb 06, 2013, 08:17 PM
Zedtwitz is offline
Find More Posts by Zedtwitz
United States, NY
Joined Jan 2012
Funky winding on stock AX2820?
Hey everyone,
I've got an X8 with a few improvements that I'd like to share, but it's crunch time for my research and I need to get it back in the air ASAP. Here it is anyway:
AX2820 customized for X8, stock from BEVRC
70A AX ESC from BEVRC, internal BEC powers servos.
6S 5000mAh Zippy Flightmax, 30C
Prop was 12x7 or so, whatever came stock with the power kit.
ZD-FLY T6A transmitter with custom mixing, ZD-FLY 6ch receiver with stock single whip antenna
915MHz 3DRadio clone as 3DR was out of stock
APM2.0 with onboard GPS disabled, 2.5 case modified to fit
3DR LEA-6H, have yet to update firmware
3DR airspeed kit
HK ~3.6KG standard servos mounted through top of wing. Note: I got 3 as obviously HK quality is not that good, one malfunctioned during maiden flight leading to crash.
Thunder Power 5V 3A linear BEC (just for APM/telemetry)
BEC battery: Custom 2S 5500mAh NCR18650 pack
So, my problem today is that the stock BEVRC motor burned out while flying, due to a combination of one of its wires being pulled out and possibly overdone ground testing. W/E; I took a few pictures and then unwound it, whereupon I discovered something strange.
The AX2820 780Kv motor that comes stock with the X8 isn't wound thread-by-thread; it is wound with 8-strand strands wrapped ~5-7 times around each of the 12 stators. At least, that was the only way I could unwind it. It appears to be 26-28AWG wire, but it could be as small as 30AWG -- I'm not quite sure as it was blackened and my caliper is missing.
So am I supposed to take 6 strands of ~26 gauge wire, twist them together, and start winding? Or am I missing something? Is it possible this is what SW was talking about when they said "customed [sic] for X8"?
Thanks for any help, especially from the pros. It'll be blizzarding around here for the next few days, so I won't be flying anyway
P.S. I hand launch with the motor off. Running with it and then hurling it into the wind may look a little silly, but it's a lot simpler than a catapult/winch and avoids pretty much all of the danger of launching with the motor on.
Zedtwitz is offline Find More Posts by Zedtwitz
Old Feb 06, 2013, 08:35 PM
xviper is offline
Canada
Joined Jul 2009
6S 5000mAh Zippy Flightmax, 30C.
Isn't that motor meant for 4S? How did you "customize" it to be run on 6S? I would think 6S would fry that thing.
I have a HobbyKing 1000kv motor. I started using 4S and it got extremely hot. I backed off to 3S and it's been running great since.
Old Feb 06, 2013, 08:53 PM
Zedtwitz is offline
United States, NY
Joined Jan 2012
Upon re-coiling the unwound wire based on the bends left in the metal, I counted approximately 91 (+/- 8 for rounding error) loops. That means seven (84 loops) or eight (96 loops) loops per stator. I should ask BEVRC if they know anything about the motor's construction, but odds are they won't be very helpful.
If you're curious, the total length of 22-28AWG wire needed to rewind this motor is 1440 inches, or about 120 feet. Not including bullet connector wires. (1 180in strand of 8 separate wires equates to 1 1440 inch long wire). Maybe that will help with calculations?
This is certainly going to be a task to rewind.
Old Feb 06, 2013, 08:55 PM
Zedtwitz is offline
United States, NY
Joined Jan 2012
Oh, I didn't customize anything. BEVRC says that their motor is customized for the X8, and the (BEVRC) ESC is rated for up to 6s. I haven't had any problems up to now. I think the main problem was the control wire ripping out, causing a temporary lockup/short, rather than the higher voltage. The ESC still works fine, though.
Alternatively, maybe I could rewind it differently to handle the higher voltage. Hmmm... anybody from the Power forum here?
New Product X8---new 2.4GHz Radio System ASSAN Radios 5740 Mar 06, 2016 01:21 PM
For Sale Assan 2.4 ghz X8 6ch receiver Brand New Scooter33 Aircraft - General - Radio Equipment (FS/W) 2 Oct 12, 2011 09:34 AM
Discussion Any info regarding this x8 setup?Better than coax x8? sjak Multirotor Talk 11 Aug 14, 2011 08:33 AM
Sold New Assan Module X8 2.4 for JR Tx norstaroption Aircraft - General - Radio Equipment (FS/W) 6 Nov 21, 2009 05:42 AM
Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 EyeFlyPlanes Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2008 02:39 AM
