Old Jan 31, 2013, 02:56 AM
EdenSmith123 is offline
Find More Posts by EdenSmith123
Joined Aug 2012
What are the chances that I will break a blade if I use a fixed (non-folding) blade?
EdenSmith123 is offline Find More Posts by EdenSmith123
Old Jan 31, 2013, 03:33 AM
RolandS888 is offline
Find More Posts by RolandS888
Outta Sight
Australia, WA, Joondalup
Joined Jul 2008
Likely, and probably rip out the whole motor and bend a shaft
RolandS888 is offline Find More Posts by RolandS888
Old Jan 31, 2013, 10:02 AM
xviper is offline
Find More Posts by xviper
Canada
Joined Jul 2009
If your motor mount is good and solid, as in having bolts that run through the foam barrier with a solid plate of some kind on the other side and blind nuts, I'd say about 25% or less. I have a Funjet Ultra and rarely does anyone use a folding prop on those and I've never broken a blade on a normal landing with it. Just make sure the power is off just prior to touch down. Now, having said that, the X8 is much bigger and heavier and it uses a much bigger prop so more of it can dig into the ground when you touch down and if it just happens to be in the right position, it could dig in. It might snap off or it might just rotate out of the way. Depends on the terrain you're landing in.
If you're mounting the motor without nuts and bolts, then NO, don't use a solid prop.
xviper is offline Find More Posts by xviper
Old Jan 31, 2013, 12:44 PM
satgod is offline
Find More Posts by satgod
satgod's Avatar
United States, KY, Hardin
Joined Jun 2011
i've seen videos of ALOT of people using stock (non-folding props)
in theory the airflow will turn the prop but when it comes horizontal to the wing airflow on the prop is minimum and will not turn
Dont hold me to this is just what others have said
satgod is offline Find More Posts by satgod
Old Jan 31, 2013, 12:46 PM
satgod is offline
satgod's Avatar
Joined Jun 2011
I was looking at possibly using real (low profile wing servos) on my X-8 the ones i'm looking at are 6kg @4.8v and 7kg @6v
this should be plenty from what i've read, correct
Old Jan 31, 2013, 12:49 PM
jtprouty is offline
Find More Posts by jtprouty
Inherent Tinkerer
Wichita, Kansas, USA
Joined Jul 2003
I never use folding props on flying wigs and rarely break one. If you leave your ESC's brake function off the spinning prop helps slow the plane down. With the brake turned on it will stop the prop's rotation and reduce drag.
Jimmy
jtprouty is offline Find More Posts by jtprouty
Old Jan 31, 2013, 01:28 PM
xviper is offline
Canada
Joined Jul 2009
With the brake OFF, the prop will spin all the way to the ground.
Old Jan 31, 2013, 01:44 PM
jtprouty is offline
Inherent Tinkerer
Joined Jul 2003
That's correct as stated in my post. I do it all the time and rarely break a prop. Just slow down your approach.
Jeff Watt is offline
Find More Posts by Jeff Watt
Joined Dec 2004
Links please! I've seen two people using regular props on the X8 and one posted video of the motor being pulled off. One had screws, one with bolts. The one with bolts was at our field. He tore off the entire motor bulkhead on his third flight. He also flies smaller wings with fixed props, usually without major damage.
Jeff Watt is offline Find More Posts by Jeff Watt
Old Jan 31, 2013, 02:22 PM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
How about using 3mm nylon screws or threaded rod to mount the motor, through a bulkhead on both sides. The plastic will shear off in times of crisis. Remember, a pusher tends to holds itself in place by pushing against the firewall, so the screws are there to stop it rotating.
They are not under much load.
ommadawn is offline Find More Posts by ommadawn
Old Jan 31, 2013, 02:29 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I did run a fixed prop on my Foamaroo and as long as it wasn't spinning when it
touched down (brake must be set) it was almost always fine. But that was only a 10x7.
Running a 12" or bigger prop on the X8, I'm sure would lower the odds of success.
I kinda doubt it'll rip the motor off, unless you try to run it after half the prop is missing.
It's a lot easier for the prop to turn out of the way on contact than to pry the motor off
its mount.
ian
Daemon is online now Find More Posts by Daemon
Old Jan 31, 2013, 04:57 PM
jcarff is offline
Find More Posts by jcarff
United States, FL, Pensacola
Joined Jul 2012
I had to take a few months off from my x8 build, but i am back to it in full force. Pictures to come later. I have a couple question for the community that i hope i can get some feedback on.
1) What alternatives can you come up with instead of gluing the 2 half's of the body together. I saw a build thread a little while ago where they simple wrapped tape around key parts of the body, allowing them to open it back up later for mode mods. I was thinking about creating some inserts and bolting the 2 halves together with about 14 bolts. i don't mind if it takes time to separate the 2 halves, i just want the option to make modifications easier.
2) And also how important do you feel it is to have a belly plate on the plane, my thermal former is not quite large enough for this body, but i have a coworker who has offered to carbon fiber the bottom for me.
jcarff is offline Find More Posts by jcarff
Old Jan 31, 2013, 05:00 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
It's a big heavy plane that sometimes lands hard. Trying to fly it without
the halves glued together is a bad idea. There's no part of the plane you
can't reach from the monster hatch. Can't imagine what mods you could make
where you'd need to separate it again. Bolting it together would only great
a bunch of stress risers where it will crack.
Kevlar protection on nose and bottom is very useful. Carbon is strong, but brittle.
ian
Old Jan 31, 2013, 07:51 PM
williamjames is offline
Find More Posts by williamjames
United States, FL, Miami
Joined Jun 2011
ian
Any particular kevlar that you would recommend? And from any specific vendor? I've never worked with kevlar but would love to beef up my bird.
williamjames is offline Find More Posts by williamjames
Old Jan 31, 2013, 08:07 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I use 1.7oz Kevlar I purchased from ACP Composites. Someone posted
a cheaper source in this thread a while back. Search for Kevlar and you may find it.
Here are my mods.
http://www.rcgroups.com/forums/showt...9#post22195044
New Product X8---new 2.4GHz Radio System ASSAN Radios 5740 Mar 06, 2016 01:21 PM
For Sale Assan 2.4 ghz X8 6ch receiver Brand New Scooter33 Aircraft - General - Radio Equipment (FS/W) 2 Oct 12, 2011 09:34 AM
Discussion Any info regarding this x8 setup?Better than coax x8? sjak Multirotor Talk 11 Aug 14, 2011 08:33 AM
Sold New Assan Module X8 2.4 for JR Tx norstaroption Aircraft - General - Radio Equipment (FS/W) 6 Nov 21, 2009 05:42 AM
Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 EyeFlyPlanes Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2008 02:39 AM
