Wichita, Kansas, USA
Joined Jul 2003
What's the best tow hook position ion relation to the CG for an X8 for bungee launching?
Jimmy |
Latest blog entry: Ultrabatic BD-5J
Croatia
Joined Aug 2010
one more X8 vid
regarding this: http://www.rcgroups.com/forums/showt...1#post22995456 and all those hd cameras have lower sensitivity than small fpv cameras. at the end there is a comparison of an cheap FPV cam (30$ Sony 0.1 lux 520 TVL gfrom HobbyKing) and GoPro HD on the right |
Ya, HD and H2 live out has extra contrast added for no apparent reason.
The Hero3 Black's live out (especially in Protune mode) can see in the dark as well as any security camera (excluding low-lux lenses), but the H3 is still a little too flaky to trust as a primary flight cam. ian |
Latest blog entry: My 2012 FPV year in Review
Joined Aug 2006
All of my EDFs that are bungee launch have the tow hook 50% - 60% from the nose to the CG ( 60% being closer to the CG)
This gives A LOT of forward velocity with a gentle rise. My bungee sailplanes are about 10 % - 15% from the CG ( closer to the nose ) this sends the sailplane almost straight up, with very little forward velocity. To get some altitude and start thermal hunting. Cheers, Brian |
Joined Jul 2003
Thanks, Brian. I'm having a hard time wrapping my mind around the "50-60%" Are you measuring the nose and then putting the hook 60% back (if the distance from the nose to the CG is 100mm you put it at 60mm) or using another measurement to calculate the distance?
Thanks again, Jimmy Quote:
Joined Aug 2006
Jimmy,
You are correct. Measure the distance from the nose to the CG. This will be X Take X multiply that by the percentage back 60% ( 0.60 ) If we take your example of 100mm from nose to CG. 100 x 0.60 = 60mm back from the nose Or 300mm for my Maxi Swift 300 x 0.60 = 180mm back from the nose. I don't recall off hand what the actual measurement of my X8 is, but I'll measure it when I get back home. (Business Trip) that should be Thursday evening or Friday. That way you'll have my exact measurements are. Cheers, Brian |
Joined Jul 2003
Mike - Have an X8 and want to do some experimentation with it. Not really happy with the flexy wings so we'll see. May have to make my own wings for the fuse.
Brian - thanks for the explanation. I'll set it at 60% and see how it does. Not sure if I want to use a stomp launcher with it or if I'll just hand launch it with the bungee. Jimmy |
| Thread Tools | |
| New Product X8---new 2.4GHz Radio System | ASSAN | Radios | 5653 | Feb 13, 2013 05:07 PM |
| For Sale Assan 2.4 ghz X8 6ch receiver Brand New | Scooter33 | Aircraft - General - Radio Equipment (FS/W) | 2 | Oct 12, 2011 09:34 AM |
| Discussion Any info regarding this x8 setup?Better than coax x8? | sjak | Multirotor Talk | 11 | Aug 14, 2011 08:33 AM |
| Sold New Assan Module X8 2.4 for JR Tx | norstaroption | Aircraft - General - Radio Equipment (FS/W) | 6 | Nov 21, 2009 05:42 AM |
| Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 | EyeFlyPlanes | Aircraft - General - Radio Equipment (FS/W) | 0 | Oct 20, 2008 02:39 AM |
