Old Nov 25, 2012, 11:52 PM
Dr.Tom is offline
Find More Posts by Dr.Tom
Youtube: TomRi25
Dr.Tom's Avatar
Croatia, City of Zagreb, Zagreb
Joined Aug 2010
Originally Posted by yoniweb View Post
Any tips on being able to focus more on throwing and less on losing fingers?
here's mine if it can help,
with 2x 5000 4S batt, 2 cameras and some firework under
launch and land shortly after
just throw the plane and pull your hand down to avoid prop
Tomislav i X8 ... kratka voznja (1 min 46 sec)
better launch without firework weight
(SLOMO at 0:57 of fingers and prop)
Skywalker X8 high altitude flight and handlaunching (5 min 27 sec)
Dr.Tom is offline Find More Posts by Dr.Tom
Old Nov 26, 2012, 03:34 AM
nedz is offline
Find More Posts by nedz
Russian Federation, Nizhegorodskaya oblast, Nizhny Novgorod
Joined Feb 2012
Originally Posted by Daemon View Post
BTW, in case folks missed it in the video thread..
Here's the X8 doing its thing.
http://www.youtube.com/watch?v=ra6myRLtfs0
ian
Very beautiful landscape, at us is not present such: (, on it is flied in clouds
голубое небо в ноябре (3 min 28 sec)
nedz is offline Find More Posts by nedz
Old Nov 26, 2012, 03:40 AM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Clouds are cool. Looks like prop could use a little balancing, and maybe consider
moving your CG back. Appears that you're carrying a tremendous amount of up elevator trim.
ian
Daemon is offline Find More Posts by Daemon
Old Nov 26, 2012, 03:41 AM
henlo is offline
Find More Posts by henlo
South Africa, WC, Vredendal
Joined Sep 2008
http://youtu.be/8e_hzjrw4-Y
http://www.youtube.com/watch?v=ACYiB...761A7&index=54
Great launch!!! What's your CG?
henlo is offline Find More Posts by henlo
Old Nov 26, 2012, 03:49 AM
henlo is offline
Joined Sep 2008
X8 wing ER9x / Eagletree settings
Can someone PLEASE help me? Do someone here have a X8 with ER9x / Eagletree setup that works? Can you please give me your settings? I struggle with the RTH / failsafe settings... Can't I put the RTH on the Throttle cut switch? How do you program your OSD switch?
Old Nov 26, 2012, 04:07 AM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
Sorry, I have the TGY 9x and RMIleC module for Failsafe the TGY TX does not have Failsafe on throttle with the stock module.
Good luck j
jayb1rdz is offline Find More Posts by jayb1rdz
Old Nov 26, 2012, 05:34 AM
chillybee is offline
Find More Posts by chillybee
Plainfield, New Jersey, United States
Joined Mar 2003
Dr. Tom,
Where did you get the flat ribbon cable? And s that the Dragon Link you're using?
chillybee is offline Find More Posts by chillybee
Old Nov 26, 2012, 11:22 AM
Dr.Tom is offline
Youtube: TomRi25
Dr.Tom's Avatar
Joined Aug 2010
flat ribbon cable cost around 0.50$ per meter in local electric parts store.
they have it in 20 lines by 200meters, and cut to your need,
then you separate only as much lines as you need (for fpv tx 2x +, 2x -, 1x video, 1x audio = 6 lines total, and for rx side, 2x +, 2x -, 9 ch x1, rssi x1 = 14 lines total)
and its very very thin, under 1mm i believe, so no problems if you stick it outside on your wing,
if you like it, and test fly it ok, than you can think about making a canal for it in wing...
but I like to keep if this way, if I sell the plane, that it can be converted to classical way of installation
whole setup is listed under second video in my post a few posts up
(it's rangelink, works better than dragonlink, my friend has it and he is angry because he had payed more for his LRS than me )
2 henlo: cg is at rear of two finger holes, 5mm +/- does not matter
(sometimes I fly without a gopro in the nose, and the plane and sticks don't feel it)
Old Nov 26, 2012, 11:35 AM
Jeff Watt is offline
Find More Posts by Jeff Watt
Joined Dec 2004
Shielded Cable source
Anybody have any idea where I can get 4-conductor shielded cable (I need a small diameter outer casing - preferably less than 4mm)
Jeff Watt is offline Find More Posts by Jeff Watt
Old Nov 26, 2012, 11:43 AM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
USB2.0 cable is only thing I can think of.
Old Nov 26, 2012, 12:00 PM
Joined Dec 2004
Duh!
(I was actually sitting here looking at a whole stack of cables I could have already been using!)
Thanks Ian!
Old Nov 26, 2012, 02:50 PM
VizBizTas is offline
Find More Posts by VizBizTas
Joined Sep 2012
Have a look at these - ore terminated ribbon cable with individual plugs. Year them of the cable, ca glue the header in the pin config you want, an off you go... They rock.... http://bit.ly/SlQ0yg
VizBizTas is offline Find More Posts by VizBizTas
Old Nov 26, 2012, 03:45 PM
OzparkPilot is offline
Find More Posts by OzparkPilot
Watts up ?
OzparkPilot's Avatar
Australia, NSW, Sydney
Joined Nov 2006
Te only real competitor to the X8 I have seen under development has been Range Videos RVjet. Its now in production and this video demonstrates the wing toss method very successfully ! I think its looks a real winner..
http://www.youtube.com/watch?feature...v=JvpUR_TMzTA#!
OzparkPilot is offline Find More Posts by OzparkPilot
Old Nov 26, 2012, 03:51 PM
Joined Sep 2012
Security install cable, or audio mic cables.
Old Nov 26, 2012, 04:05 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
It's not the same type of plane or the same type of launch. That's just an off center backhand
launch. He didn't rotate at all. It's easier on a plank because the CG is only a 2-3 inches
behind the leading edge of the wing so it's easier to support the weight of the plane from there.
On the X8, the CG is 8-9 inches back, so loaded up it's trying to twist itself out of your grip.
If you had your X8 together with gear in it, you'd see what I mean by simply trying to hold it up
level from that location.
The discus launch Opt is describing (which I've seen used on other smaller wings)
starts with the far wing tip resting on the ground behind you. Throttle up, and swing the plane
around about 90 degrees (mostly powering itself, rather you pulling it forward) and release
as it points the launch direction.
ian
New Product X8---new 2.4GHz Radio System ASSAN Radios 5740 Mar 06, 2016 01:21 PM
For Sale Assan 2.4 ghz X8 6ch receiver Brand New Scooter33 Aircraft - General - Radio Equipment (FS/W) 2 Oct 12, 2011 09:34 AM
Discussion Any info regarding this x8 setup?Better than coax x8? sjak Multirotor Talk 11 Aug 14, 2011 08:33 AM
Sold New Assan Module X8 2.4 for JR Tx norstaroption Aircraft - General - Radio Equipment (FS/W) 6 Nov 21, 2009 05:42 AM
Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 EyeFlyPlanes Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2008 02:39 AM
