Old Nov 22, 2012, 09:15 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Originally Posted by Jeff Watt View Post
Somewhere there is a video of an X8 being launched "discus" style from a small ledge (Australia?), but I did a media search tonight and can't find it.
I have to assume it was light build by the way he handled it. I can't picture trying to launch my 8 lb wing that way.
The discus launch vid was posted fairly early in this thread.
Main problem is securing the wing so it doesn't pull off the fuse as you spin around.
Maybe I'll try it before I retire my first X8.
ian
Daemon is online now Find More Posts by Daemon
Old Nov 22, 2012, 09:40 PM
Jeff Watt is offline
Find More Posts by Jeff Watt
Joined Dec 2004
Originally Posted by Daemon View Post
The discus launch.........
ian
Video of course? !
Jeff Watt is offline Find More Posts by Jeff Watt
Old Nov 22, 2012, 09:50 PM
OzparkPilot is offline
Find More Posts by OzparkPilot
Watts up ?
OzparkPilot's Avatar
Australia, NSW, Sydney
Joined Nov 2006
So this is what Im thinking of making - NOT copying, but a similar idea - Given my field is smooth. Before I start, has anyone got first hand experience please ?
OzparkPilot is offline Find More Posts by OzparkPilot
Old Nov 23, 2012, 12:40 AM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
I used a dolly for launching an edf model....the SAPAC JAS 39 that I stuffed a 90mm into and a pusher version of an ME163.
I ended up having to bind a second RX to the dolly (which was Tricycle gear layout) so I could steer it as the model kept wanting to weather vein into the wind.....which wasn't stright down the runway. I also added a loose fitting mast which fitted into hole at the front of the fuse to stop the model lifting off the dolly prematurely.
J
jayb1rdz is offline Find More Posts by jayb1rdz
Old Nov 23, 2012, 01:31 AM
Watts up ?
Joined Nov 2006
Thats sounds very cool but a bit to complex for what I was intending. Clearly it was needed so food for thought indeed. Thanks Jay
Old Nov 23, 2012, 05:45 AM
peppe_i8uza is offline
Find More Posts by peppe_i8uza
failure is not an option
Joined Jul 2012
this is my cart
http://www.facebook.com/video/video....35475156515105
http://www.facebook.com/v/4443748185397
a dolly (or cart) for my x8 take-off
on-board the dolly, there is a rx binded on same radio, with a servo on ch.4, rudder, unused on x8
so, I can line-up during taxing and take-off
of course, sound is from another plane.... ;-)
peppe_i8uza is offline Find More Posts by peppe_i8uza
Old Nov 23, 2012, 07:54 AM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
Aussie Pete tried something similar with limited success. He tried it with his Queen Bee wing which is somewhat bigger than the X8. Scroll down till you find the appropriate pix
http://www.rcgroups.com/forums/thumb...ttach&u=262829
ommadawn is offline Find More Posts by ommadawn
Old Nov 23, 2012, 07:55 AM
BillyM is offline
Find More Posts by BillyM
BillyM's Avatar
Canada, MB, Brandon
Joined Jan 2003
I saw that video and that was not what I had in mind. It was more of "vertical toss". As I recall the prop went by his nose.... What I'm thinking of is a modified launch similar to that used by the discus launch glider guys. I've launched many deltas this way but never anything as big and heavy as the X8.
Main problem is securing the wing so it doesn't pull off the fuse as you spin around..
I've thought about this but for those that attach the wing with tape, I don't think it will be an issue. Even a small amount of tape applied to a clean wing surface requires a huge amount of force to break lose when pulling sideways. If the wing is taped on all around the complete wing joint, I don't believe it will come off......
Bill
BillyM is offline Find More Posts by BillyM
Old Nov 23, 2012, 11:14 AM
Joined Dec 2004
Bill
If it went anywhere near his head it is a different video - there is a "discus" style toss out there somewhere. I went back through this thread and cannot find it. The pilot starts with one wing tip on the ground and the other in his left hand , applies full throttle and then spins half a turn. The plane goes to a horizontal attitude during the spin, and he releases the wing.
The one I saw was on a very small mountain-top ridge near the sea.The video showed the launch from a tripod mounted camera and switched to an FPV perspective after launch.
As I said, it seemed like a REALLY light build. It was one of the videos that convinced me to get an X8, so it had to be posted before May.
This is not the video, but it shows a similar launch technique:
Rc flying wing launch (0 min 18 sec)
The X8 launch actually started with the wingtip on the ground.
Old Nov 23, 2012, 01:19 PM
hendrix is offline
Find More Posts by hendrix
Greece, Attica, Piraeus
Joined Jun 2004
And that's about 1km from my home
I would say that this is discus launching (Random pick) and it would be interesting to see how many pieces of the X8 will actually fly
Fling DL Discus Launch Glider (1 min 43 sec)
Chris
hendrix is offline Find More Posts by hendrix
Old Nov 23, 2012, 01:53 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Opt showing a vid of discus style launch of the X8
http://www.rcgroups.com/forums/showp...postcount=1660
Old Nov 23, 2012, 02:20 PM
Dirt-Torpedo is offline
Find More Posts by Dirt-Torpedo
...just an earth bound misfit
Dirt-Torpedo's Avatar
Joined Mar 2010
This one actually shows a launch:
http://www.rcgroups.com/forums/showp...&postcount=448
Dirt-Torpedo is offline Find More Posts by Dirt-Torpedo
Old Nov 23, 2012, 02:21 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Yes, but it's not an X8. It's a proven method of launching *some* wings.
The question is how reliable it is for a loaded up X8.
Old Nov 23, 2012, 07:02 PM
Watts up ?
Joined Nov 2006
Thanks for that - Thats what I was intending. Might contact him for some learning.
Old Nov 23, 2012, 07:24 PM
ommadawn is offline
The Flying Circus
ommadawn's Avatar
Joined Sep 2007
Heres a few too many shots of my new X8. I have yet to maiden her. I am using 10,000/3s and 2200/3s for video. 1100Kv motor. 12x6 folder prop. Also note the cooling fan for 1000/2.4 Vtx. Works really well. Keeps the Vtx to ambient.
Also using fine tuned Vtx aerial from Flytron, at 2450Mhz, which is the sweet spot for my 18Dbi patch.
RVOSD and DragonLink. ASI pitot tube at front.
Still to fit the HK airbrakes.
New Product X8---new 2.4GHz Radio System ASSAN Radios 5740 Mar 06, 2016 01:21 PM
For Sale Assan 2.4 ghz X8 6ch receiver Brand New Scooter33 Aircraft - General - Radio Equipment (FS/W) 2 Oct 12, 2011 09:34 AM
Discussion Any info regarding this x8 setup?Better than coax x8? sjak Multirotor Talk 11 Aug 14, 2011 08:33 AM
Sold New Assan Module X8 2.4 for JR Tx norstaroption Aircraft - General - Radio Equipment (FS/W) 6 Nov 21, 2009 05:42 AM
Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 EyeFlyPlanes Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2008 02:39 AM
