Old Nov 15, 2012, 05:41 AM
hendrix is offline
Find More Posts by hendrix
Greece, Attica, Piraeus
Joined Jun 2004
Maybe my idea is rubish but here it goes:
I know that a heavy x8 is difficult to keep above your head and be stable enough so maybe if we fit two small plywood fins where the wings start and at CG will make it easier to hold for hand launching
(WITH TWO HANDS of course so someone else will have to control it)....
Chris
hendrix is offline Find More Posts by hendrix
Old Nov 15, 2012, 07:06 AM
Imagecatcher is offline
Find More Posts by Imagecatcher
Imagecatcher's Avatar
NSW Australia
Joined Mar 2010
Originally Posted by crazy1pilot View Post
Someone who has a made a launcher, what angle do you set it at and tension of bungee do you use? I would like to build one shortly and have an idea.
Crazy1
I read somewhere 15 degrees so thats what I did. I have 6x 8mm x 800mm bungees that offer 40+kgs at 1.5m stretch. Some have said I will need more for my 4.9kg bird ( I have the motors running at release). You can see my launcher in the attachments and videos.
Imagecatcher is offline Find More Posts by Imagecatcher
Old Nov 15, 2012, 07:12 AM
henlo is offline
Find More Posts by henlo
South Africa, WC, Vredendal
Joined Sep 2008
X8 Maiden
Maidened my X8! What a blast to fly!!!! It flies SO steady & super slow for such a big wing. OK, I only had 1 x 4s 4000mHh for the motor & 1 x 2350 3s for VTx in it to test LOS. The through was hair raising both times - a buddy through it for me & both times the nose went straight up but I managed to fly it. But in flight it was rock stable & needed only a little bit of throttle. In the video you can see the Amps & Watts... It has a Eflight Power 32 in it with a 12x8 Carbon prop & it has loads of power - to go vertical is no problem. Tested RTH a few times but it didn't work like it should. It went into a spiral dive each time I have tested it. (came out of it quickly) CG was 1cm behind recommended CG. Will test it again this weekend. :-) Sorry for the bad video, I use 5740Mhz for the signal to the plane & 5860Mhz for the signal to my fatsharks from the GS. Seems they interfere with eachother... :-) Will use the FS with a wire to the GS next time. :-)
X8 wing Maiden FPV (LOS) (7 min 31 sec)
henlo is offline Find More Posts by henlo
Old Nov 15, 2012, 10:41 AM
xviper is online now
Find More Posts by xviper
Canada
Joined Jul 2009
Chris
I have visions of some poor volunteer holding this thing up with 2 hands over his head and tossing it. Goodbye scalp!
xviper is online now Find More Posts by xviper
Old Nov 15, 2012, 11:25 AM
LouMelancon is offline
Find More Posts by LouMelancon
United States, GA, Cumming
Joined Dec 2001
Is this reasonable
I have a lot of experience with glow engines but practically nothing with electric motors. I tested the motor, esc and battery combination for my X-8 yesterday. Please advise if this is acceptable performance for the plane (my intended use is slow, long, FPV cruising).
All testing done with a 4S 5000 Mah battery, and folding CF 13X6.5 prop:
Amp draw at full throttle 44
Watts at full throttle 602
RPM 8,800
According to Thrust HP I can expect about 6 lbs of thrust and a max speed of 54mph.
This seems to be plenty enough power and low enough current draw to be practical on the X-8. Your thoughts please?
The motor is a Turnigy Aerodrive SK3, 4240, 740KV. After 5 minutes of half throttle running the rear end of the motor against the firewall is slightly warm. The 70 Turnigy amp esc is getting hot, but it is not in moving airflow during testing.
Should I try to provide more cooling air to the motor and esc than what will naturally occur through the air openings in the front of the fuselage which allow air flow through the fuselage then out the rear motor mount holes? Should I try to mount the ESC so that its heat sink is on the surface of the model to get more cooling?
LouMelancon is offline Find More Posts by LouMelancon
Old Nov 15, 2012, 12:18 PM
Jeff Watt is offline
Find More Posts by Jeff Watt
Joined Dec 2004
You should not bench test this kind setup for longer than absolutely necessary to determine what your current draw is (i try for less than 5 seconds).
You are lucky you didn't burn up the motor or ESC, or both. There is not enough cooling flow for either device on the bench.
That setup has plenty of power for normal cruising and basic loops and rolls.
SK3s are known for quick melting (magnets detach).
I know, I've made magic smoke with one myself Seems all of us glow guys want to "run it up" to check them out, but its not a good idea without some big fans on the bench
I fly with almost the same setup now without issue. My ESC never goes over 113F even when the outside air temps were 85F+. It is mounted inside in the rear compartment. (Temp sensor monitored).
Jeff Watt is offline Find More Posts by Jeff Watt
Old Nov 15, 2012, 12:35 PM
hendrix is offline
Joined Jun 2004
I thought so my self but a helmet could solve this.
When i hand launch mine i always wear a glove.
Chris
Old Nov 15, 2012, 01:44 PM
BldrFlyr is online now
Find More Posts by BldrFlyr
BldrFlyr's Avatar
United States, CO, Boulder
Joined Nov 2012
Originally Posted by Dr.Tom View Post
http://www.youtube.com/watch?v=RModL...=ULRModLGbkQ24
7:11 my X8 launching, hands off,
no need for catapult
(2 cameras, FPV, 2x 5000 4S batt)
Beautiful country. My wife is from Croatia and we spend the summers in Brac and Zagreb.
BldrFlyr is online now Find More Posts by BldrFlyr
Old Nov 15, 2012, 02:56 PM
ponoc is offline
Find More Posts by ponoc
Joined Aug 2012
Originally Posted by octane81 View Post
According to BEVRC price is not set.
When it stalls it will just go into a death spiral , which you really DONT WANT with a FPV plane... not safe.
Take a look here , 2:25
Thins death spiral happend more than once , and it was no mechanical or servo failure. Just stalling..
http://youtu.be/2clR-cSNc1c?t=2m27s
Man really maybe you should a pilot or someone who knows about this.
I did and he told that you should some really simple things.
1st turn off the motor.
2nd remove your fingers from the sticks (set control surfaces to neutral)
3rd turn off auto stabilization or AP or any electronic.
The first thing you expect to see is that the wing will slow with the spiral as it gains speed and finally stop. Then gradually you must increase the throttle ( SLOWLY) get enough airspeed and then continue with your flight. If you fly high you have more than enough time to get out of this situation.
Things you MUST NOT do.
1st allow the AP or auto stab. system to do its job. It only keeps the stall.
2nd increase the throttle to gain more speed. Major mistake. It will increase the spiral diving due to NO support of the wing. This means that the motor will rotate the plane and NOT the prop.
Delta wings have very low stall speed relatively of course but they can easily go to flat spin or spiral dive. Dont give them that chance its bad.
For my X-8 i keep the CoG front kinda 5mm from the manual's CG. This makes the plane to gain speed. Try it !!!!
ponoc is offline Find More Posts by ponoc
Old Nov 15, 2012, 03:12 PM
Joined Dec 2004
Disregard - Replying to a post that someone revived after almost a year
Old Nov 16, 2012, 02:59 AM
KiwiKid is online now
Find More Posts by KiwiKid
Aeroplanes fly aerobatics!!
KiwiKid's Avatar
Hamilton, New Zealand
Joined Jun 2005
It might be easier just to turn the sucker upside down and give it the full welly
http://www.youtube.com/watch?feature...v=p54WaGqhLPY#!
KiwiKid is online now Find More Posts by KiwiKid
Old Nov 16, 2012, 03:02 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
A small shift of CG is ok. 15mm behind recommended, is too much. It's flyable, but
not particularly stable there, as you've discovered.
ian
Daemon is online now Find More Posts by Daemon
Old Nov 16, 2012, 03:06 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
You replied to a post from 2011, before the X8 was even released.
Good luck with that "sticks at neutral position" recovery, if/when your X8 does
someday spin.
ian
Old Nov 16, 2012, 03:18 AM
VizBizTas is offline
Find More Posts by VizBizTas
Joined Sep 2012
someday spin.
ian
Hi - I had the spins, and as an example, added a 2200mah 3s about 150mm from the nose, and it is sorted. Will now do CG and add less right in the nose to keep it like it is.
VizBizTas is offline Find More Posts by VizBizTas
Old Nov 16, 2012, 08:42 AM
UncleMatt is offline
Find More Posts by UncleMatt
Joined Jun 2006
This may not be a workable idea, but what if we simply design a short throwing "stick" for use with the X8? I am sure one of us could cook up an interface between "stick" and fuselage that would keep it flight ready level as you throw it. This idea worked for our ancestors when they were launching spears at game/enemies, and maybe it would work here as well.
And of course this "stick' could be any shape or configuration we want, a modern "atlatl" if you will. It could be as short as practicable, and the extra energy delivered to the plane would make it launch even easier. Best part is no human parts near rotating blades.
UncleMatt is offline Find More Posts by UncleMatt
New Product X8---new 2.4GHz Radio System ASSAN Radios 5733 Feb 07, 2016 01:23 PM
For Sale Assan 2.4 ghz X8 6ch receiver Brand New Scooter33 Aircraft - General - Radio Equipment (FS/W) 2 Oct 12, 2011 10:34 AM
Discussion Any info regarding this x8 setup?Better than coax x8? sjak Multirotor Talk 11 Aug 14, 2011 09:33 AM
Sold New Assan Module X8 2.4 for JR Tx norstaroption Aircraft - General - Radio Equipment (FS/W) 6 Nov 21, 2009 06:42 AM
Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 EyeFlyPlanes Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2008 03:39 AM
