Old Nov 10, 2012, 11:53 AM
Coyote64 is offline
Find More Posts by Coyote64
Praying for better weather
Coyote64's Avatar
Joined Dec 2007
Originally Posted by ommadawn View Post
Thanks Coyote. So 10mm travel each way, same travel for elev and ail, and no additional reflex. Just follow the contour of the wing?
Yup, so full ail and elevator will give you a max of 20mm travel. Yeah no reflex, follow the contour of the wing ( so looks a little higher than the fuse edge the wing butts up too.
Coyote64 is offline Find More Posts by Coyote64
Old Nov 10, 2012, 11:55 AM
Coyote64 is offline
Coyote64's Avatar
Joined Dec 2007
Originally Posted by VizBizTas View Post
Thanks - ok will adjust throws (is 10-15mm a good starting point). CG to far back - you mean nose heavy?
Cheers
Your CG seems too far back, promoting tip stall. Move your CG forward a bit ( more nose heavy yes ) first before dropping control throws, as you move it forward they might not need adjusting.
Old Nov 10, 2012, 03:23 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Note also, that to recover from a flat-ish spin with the X8, push the aileron stick in the same
direction as spin, and apply full down elevator (usually forward stick). So a left hand spin, full
left aileron, full down elvator. In this scenario the only wing with any airspeed is the outside
one, so you need the elevon on that wing down as much much as possible to pitch the whole
plane nose down. Gotta be patient too.
ian
Daemon is online now Find More Posts by Daemon
Old Nov 10, 2012, 03:38 PM
Coyote64 is offline
Coyote64's Avatar
Joined Dec 2007
With or without throttle Ian ?
Old Nov 10, 2012, 03:46 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Without.
Old Nov 10, 2012, 04:33 PM
Coyote64 is offline
Coyote64's Avatar
Joined Dec 2007
I tried elevators back, turn against the spin and throttle, can report it does not work But both times landed flat, no damage just the walk of shame
Old Nov 10, 2012, 07:08 PM
UncleMatt is offline
Find More Posts by UncleMatt
Joined Jun 2006
Originally Posted by Fstclyz View Post
I'm building an SSS for LG FPV and higher altitude flying in Colorado. It soars and floats very well and is easy on the take-off and landings (unlike my ZII). You might want to consider one if the X8 doesn't work out for you. The SSS is cheap in comparison as well. You can see my plane and build up here:
http://www.rcgroups.com/forums/showt...8#post23155892
Thats a nice alternative. I am still seeking some guidance on the appropriate motor and prop combination that would be best suited for flying the X8 up to 13K. Of course, I will be on the ground not much lower than that. I would like to get a scorpion motor, but lack the experience so many of you have.
I have also seen mention of using a variable pitch prop in this thread, but haven't seen anyone pull that off with the X8 yet. It would be nice to have that feature at high altitude. Anyone working on that or have video/photos already in hand?
UncleMatt is offline Find More Posts by UncleMatt
Old Nov 11, 2012, 05:03 AM
Imagecatcher is offline
Find More Posts by Imagecatcher
Imagecatcher's Avatar
NSW Australia
Joined Mar 2010
Catapult trigger mechanism
Here is how I have used a solenoid to trigger my catapult.
Catapult firing mechanism (3 min 51 sec)
Imagecatcher is offline Find More Posts by Imagecatcher
Old Nov 11, 2012, 05:06 AM
NSW Australia
Joined Mar 2010
Maiden attempt
Well I didn't get far but nutted a lot of stuff out The vid is just a bit of fun.
Maiden attempt (2 min 12 sec)
Old Nov 11, 2012, 05:24 AM
Stefan_Go is offline
Find More Posts by Stefan_Go
Stefan_Go's Avatar
Finland, Pirkanmaa, Valkeakoski
Joined Sep 2012
Flat spin recovery
I was just watching the videos of eflite's Scimitar which has a vector-thrust system. It can do a flat spin intentionally and recover from it with the vector-thrust system.
Would a yaw-vts also be beneficial for the X8 in these situations?
Stefan_Go is offline Find More Posts by Stefan_Go
Old Nov 11, 2012, 05:28 AM
Coyote64 is offline
Coyote64's Avatar
Joined Dec 2007
Shame it didnt work, looks to me like the launcher is way underpowered. Its not getting enough speed up to create lift in the first place. No up elevator should be needed at that angle.
Old Nov 11, 2012, 05:29 AM
brifa is offline
Find More Posts by brifa
brifa's Avatar
ITALY
Joined Aug 2006
how many cm behind or forward the holes under the wings should i put the CG??
brifa is offline Find More Posts by brifa
Old Nov 11, 2012, 05:40 AM
NSW Australia
Joined Mar 2010
Hi coyote, i am still holding out that its not under powered. Its way stronger than my right arm! And not like its motors start after launch... Seriously think it was the chute kill switch(ing) off the motor. Tomorrow i try again.
Old Nov 11, 2012, 05:50 AM
Coyote64 is offline
Coyote64's Avatar
Joined Dec 2007
Hiya, you need at least 3x models weight at minimum but 4x is better. If you can get some scales on it you could know for sure. Looking at the footage it should travel a lot further with motor off than it is.
Edit : Just watched your catapult release video. The bungee looks way under powered, I have 10m doubled up of the 10mm bungee to get the 12kg of force required to launch my 3kg X8
Old Nov 11, 2012, 12:24 PM
rsands2801 is offline
Find More Posts by rsands2801
Joined Dec 2007
its underpowered. no question about it...if it was right tension it would have sailed way further. 13-14kg is alot of pull, its way more than what you think it feels like
rsands2801 is offline Find More Posts by rsands2801
New Product X8---new 2.4GHz Radio System ASSAN Radios 5740 Mar 06, 2016 01:21 PM
For Sale Assan 2.4 ghz X8 6ch receiver Brand New Scooter33 Aircraft - General - Radio Equipment (FS/W) 2 Oct 12, 2011 09:34 AM
Discussion Any info regarding this x8 setup?Better than coax x8? sjak Multirotor Talk 11 Aug 14, 2011 08:33 AM
Sold New Assan Module X8 2.4 for JR Tx norstaroption Aircraft - General - Radio Equipment (FS/W) 6 Nov 21, 2009 05:42 AM
Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 EyeFlyPlanes Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2008 02:39 AM
