Old Nov 09, 2012, 06:13 PM
Youtube: TomRi25
Croatia
Joined Aug 2010
X8 skywalker handlaunching and landing... (4 min 36 sec)
btw, HK has metal gear 180° servo, pretty cheap
http://www.flyfreak.net/elektronika-...cseen#msg95023
Dr.Tom is offline Find More Posts by Dr.Tom
Old Nov 09, 2012, 06:20 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I use the Hitec HS-5245MG for the GoPro pan servo on my Skywalker. It can
be programmed to 180 degrees, but you need access to a Hitec digital servo
programmer (my LHS has one I use).
ian
Daemon is offline Find More Posts by Daemon
Latest blog entry: My 2012 FPV year in Review
Old Nov 09, 2012, 11:07 PM
Joined Oct 2011
Ecilop Chasing X8
Ecilop Chasing X8 part 2 (2 min 9 sec)
s6100021 is offline Find More Posts by s6100021
Old Nov 10, 2012, 03:46 AM
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
You just need to add your peregrine falcon to the chase... Looks like an Etihad Airlines Commercial. Nice
jayb1rdz is offline Find More Posts by jayb1rdz
Old Nov 10, 2012, 03:59 AM
Joined Sep 2012
Originally Posted by TheCure View Post
Pictures as requested.
Took a good few hours per side to sand that taper down
Nice. Well done
http://www.facebook.com/groups/projectbigbird
VizBizTas is offline Find More Posts by VizBizTas
Old Nov 10, 2012, 04:02 AM
Joined Sep 2012
Video soon....
Did 2 Maiden flights today with BigBird. Both ended in flat spins that I could not get out of....
No damage and ALL caught on video from onboard and the ground.
Bungee launch worked really well too..
Hmmmm - ideas...?
Cheers
Old Nov 10, 2012, 04:21 AM
Praying for better weather
Coyote64's Avatar
Joined Dec 2007
Sounds like you have your CG too far back and too much throws on your control surfaces.
Or just CG too far back
Coyote64 is online now Find More Posts by Coyote64
Old Nov 10, 2012, 07:59 AM
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
Getting ready to maiden. What is recommended control throws in mm, and how much reflex please?
ommadawn is online now Find More Posts by ommadawn
Old Nov 10, 2012, 08:27 AM
Coyote64's Avatar
Joined Dec 2007
No reflex, 10mm ailerons + 10mm elevator on top works for me
Old Nov 10, 2012, 08:34 AM
The Flying Circus
ommadawn's Avatar
Joined Sep 2007
Thanks Coyote. So 10mm travel each way, same travel for elev and ail, and no additional reflex. Just follow the contour of the wing?
Old Nov 10, 2012, 09:09 AM
Joined Dec 2004
Double post
Jeff Watt is offline Find More Posts by Jeff Watt
Old Nov 10, 2012, 11:17 AM
Joined Sep 2012
Video of BigBirds Maiden Flight. Done a great job again with the video Phil, thanks. Includes bungee launch and the death spin "landings"...! http://m.youtube.com/#/watch?v=dyNuH...%3DdyNuHo-FNBE
Old Nov 10, 2012, 11:20 AM
Joined Sep 2012
Thanks - ok will adjust throws (is 10-15mm a good starting point). CG to far back - you mean nose heavy?
Cheers
Old Nov 10, 2012, 11:23 AM
ITALY
Joined Aug 2006
with the hitec servos on the ailerons i hear some jitterings (even with double ferrites)... why??
they are the hs225 mg
Originally Posted by philthyy View Post
Hitec servos are well proven. I trust them. As far as ESC, I would go with the Castle Creations ICE 75. Or a Kontronics ESC.
brifa is offline Find More Posts by brifa
Old Nov 10, 2012, 11:42 AM
Joined Dec 2004
Cheers
No, the nose is too light. It should balance right at the rear of the finger holes on the bottom of the plane.
New Product X8---new 2.4GHz Radio System ASSAN Radios 5653 Feb 13, 2013 05:07 PM
For Sale Assan 2.4 ghz X8 6ch receiver Brand New Scooter33 Aircraft - General - Radio Equipment (FS/W) 2 Oct 12, 2011 09:34 AM
Discussion Any info regarding this x8 setup?Better than coax x8? sjak Multirotor Talk 11 Aug 14, 2011 08:33 AM
Sold New Assan Module X8 2.4 for JR Tx norstaroption Aircraft - General - Radio Equipment (FS/W) 6 Nov 21, 2009 05:42 AM
Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 EyeFlyPlanes Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2008 02:39 AM
