Old Oct 01, 2012, 06:18 PM
deTonaTor_NZ is offline
Find More Posts by deTonaTor_NZ
Religion= suffering/wars
deTonaTor_NZ's Avatar
Joined Jan 2006
Dude, I would be very concerned about equipment freezing up!
Originally Posted by jb_bak View Post
I'm exploring the idea of sending my X8 up to around 30K feet with a 1300g weather balloon. If this goes well I might try higher. I have an APM2.5 that will autonomously fly back overhead and circle while coming down.
I need to strengthen the wings and elevons to handle the higher true airspeed anticipated. I was thinking of .73 oz fiberglass cloth on wings, and kevlar on the nose (I already have some, just finish off the upper part and cover the holes)
Can anyone shed light on ideas on getting the X8 up for the challenge? Maybe running an extra carbon fiber spar or two?
deTonaTor_NZ is offline Find More Posts by deTonaTor_NZ
Old Oct 01, 2012, 07:26 PM
Dirt-Torpedo is offline
Find More Posts by Dirt-Torpedo
...just an earth bound misfit
Dirt-Torpedo's Avatar
Joined Mar 2010
Sounds like a very reasonable concern:
http://en.wikipedia.org/wiki/U.S._Standard_Atmosphere
Standard ambient temperature at those altitudes is -50F (-45C), which is getting well into milspec temperature range. For sure the Lipos don't want to be charged to 4.2V/cell either.
Depending on balloon lift, lipo-powered thermostatically-controlled heaters and insulation may be the way to go, but that's going to take some quality modelling based on experimental data.
Servos may be fun to winterproof.
Dirt-Torpedo is offline Find More Posts by Dirt-Torpedo
Old Oct 02, 2012, 07:45 AM
PittSpecial is offline
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
No need for Heaters. NASA's Rocket U Ballon Project uses two Thunder Power 3-Cell, 2250mAH, Li-POLYs and they are inserted in foam, period.
Rocket U: Engineers Push New Limits (2 min 4 sec)
PittSpecial is offline Find More Posts by PittSpecial
Old Oct 02, 2012, 06:07 PM
Joined Mar 2010
I'll assume these guys didn't just pick a random piece of foam out of the trash and HOPE for the best. The point is that thermal design and management is appropriate to operation at 30,000 ft. Would be nice to get an explanation on why the burn wire failed to terminate the ascent at the planned peak of 80,000 ft?
While my ultra-micros have their 1S120 packs' lifeblood sapped by a -10C prop blast (even in a cozy duct tape pocket filled with cottonballs), self-heating often leaves my 3S2200's uncomfortably hot to the touch in -10C weather.
Depending on the system you might even want to worry about over insulating in that thin air, and needing to dump heat. I know that SSD Macbook Pros are working at 50% density altitudes of the 22,000 ft base camp on Everest but I haven't seen any pics on the 33% density altitude of the 29,000 ft summit.
Rocket U seems really sad to me but let's pray that it's more than just an idling HOPE for a return to bygone glories.
Here's a pretty extreme low temperature battery problem:
http://jproc.ca/rrp/alert_power_system.html
Old Oct 02, 2012, 07:45 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Sadly, I believe it is going to get worse! You know that saying?
Prepare for the worse and hope for the Best!
Budget outlays for 2013 does not look nice. The only saving grace "is" we NASA is operating on a continuing resolution CR until January 1st, 2013 and at that time your guess is as good as mine!
Thanks for your reply, I am not a Rocket U member but, I will ask someone in my office to answer some of your posted points.
Old Oct 04, 2012, 11:01 AM
Beauregard is offline
Find More Posts by Beauregard
My three sons...
Beauregard's Avatar
Steamboat Springs Co.
Joined Nov 2004
Wondering if anyone has loaded up the x8 with a 1.5lb payload? I'm wanting to put a real camera on one...
Beauregard is offline Find More Posts by Beauregard
Old Oct 04, 2012, 11:18 AM
xviper is online now
Find More Posts by xviper
Canada
Joined Jul 2009
1.5 lbs for this plane is nothing. People have put 20,000 mah worth of batteries in it. That's nearly 5 lbs right there. You could fly a 6 pack of beer to gramma's house.
xviper is online now Find More Posts by xviper
Old Oct 04, 2012, 01:38 PM
TooSLow2Care is offline
Find More Posts by TooSLow2Care
insert witty phrase here
Joined Aug 2006
The manual states that TOW is 3.2Kg. the airframe weighs in at 880g that leaves you 2,320g of payload and avionics. or 5.11lbs... your 1.5lb camera (680g) is nothing for this airframe. it will carry my Nikon D90 (w/18-55mm lens) at 767g(1.7lbs) or my Canon 7D (w/18-55mm lens) at 1043g(2.3lbs) without an issue...
though i have my own camera system developed and being installed in my X8 that is, in my mind the correct system to use. instead of putting a human form factor camera in the air.
cheers,
Brian
TooSLow2Care is offline Find More Posts by TooSLow2Care
Last edited by TooSLow2Care; Oct 04, 2012 at 01:38 PM. Reason: fat-fingered the keyboard a few times :P
Old Oct 04, 2012, 04:00 PM
Andre6553 is offline
Find More Posts by Andre6553
Vulcan skyhook multirotor
Andre6553's Avatar
South Africa, GP, Pretoria
Joined Feb 2011
Does your gramma drink beer
Andre6553 is offline Find More Posts by Andre6553
Old Oct 04, 2012, 04:04 PM
My three sons...
Beauregard's Avatar
Joined Nov 2004
Thanks.. Thats great news.. I'm thinking of mounting the Sony cx760..
Old Oct 04, 2012, 04:29 PM
Canada
Joined Jul 2009
Naw, that's for when I go visit. She's too busy smokin weed.
Old Oct 04, 2012, 07:29 PM
OzparkPilot is offline
Find More Posts by OzparkPilot
Watts up ?
OzparkPilot's Avatar
Australia, NSW, Sydney
Joined Nov 2006
Haha, she sounds like my grandma !
OzparkPilot is offline Find More Posts by OzparkPilot
Old Oct 05, 2012, 05:31 AM
Rastislavko is offline
Find More Posts by Rastislavko
You can't take the sky from me
Rastislavko's Avatar
Slovakia, Bratislava Region, Bratislava
Joined Jun 2006
White X8 is now in stock on HobbyKing for a very reasonable price of $167.65 (platinum)...
Rastislavko is offline Find More Posts by Rastislavko
Old Oct 05, 2012, 06:24 AM
bracky72 is offline
Find More Posts by bracky72
Questionable judgement
bracky72's Avatar
Charles Town, WV
I just realized I know you from s2000 land. Small world.
bracky72 is offline Find More Posts by bracky72
Old Oct 05, 2012, 07:46 AM
seojeff is offline
Find More Posts by seojeff
seojeff's Avatar
United States, GA, Atlanta
Joined Aug 2011
Don't expect any credit for that affiliate link - they don't allow form spam.
seojeff is offline Find More Posts by seojeff
New Product X8---new 2.4GHz Radio System ASSAN Radios 5740 Mar 06, 2016 01:21 PM
For Sale Assan 2.4 ghz X8 6ch receiver Brand New Scooter33 Aircraft - General - Radio Equipment (FS/W) 2 Oct 12, 2011 09:34 AM
Discussion Any info regarding this x8 setup?Better than coax x8? sjak Multirotor Talk 11 Aug 14, 2011 08:33 AM
Sold New Assan Module X8 2.4 for JR Tx norstaroption Aircraft - General - Radio Equipment (FS/W) 6 Nov 21, 2009 05:42 AM
Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 EyeFlyPlanes Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2008 02:39 AM
