There are plenty of foamies that can (and have already) handle these airspeeds (fastest
DS foamies have gone over 250mph in much thicker air). The X8 is just about the last plane I'd choose to do it however. I dunno why the X8 inspires so many unrealistic dreams. ian |
Latest blog entry: My 2012 FPV year in Review
The only real world experience I would like to add here to help are: if or when a spin is induced, the worse, and most probably, in full scale the last mistake you will ever make is to pull back on the stick whist in a spin ! It's a completely natural reaction to most pilots, it took me a good few goes of retraining my mind to do the opposite correction. Pulling back in a spin ( ie: up ) will only tighten the spin to the point of making it a flat spin.... In your very helpfull video, at around 6:50 you see the effects of a spin that is becoming flat as you loose any authority on one elivon ( the dead, flat side ) but as soon as a real deep stall is established, in most planes but especially in flying wings or canards ( long ez series ) it's all over red rover !! Hope this help - G |
Another thing that comes to mind is.... With RG variants being highly appealing but as of yet, lack real world proven use, and understandably a lot of people are concerned about giving up a didget or two to an angry prop... I'm starting to thing of a dolly launch.
This seems so ideal and low cost and ticks every box I can think of: The dolly would stay on the ground, weight would be less important ( it still needs to be as light as possible obviously ) but you could build it with much much larger wheels that would be practical to take aloft with you and the launch angle coud be very adjustable.. As soon as I get home ( I'm sitting on an island in Thailand as I write this ) I'm getting to work. Thoughts ? G |
United States, FL, Milton
Joined Oct 2011
or EPO like easystar ![]() speed mean nothing in near vacuum space LOL any toy will handle it... balloon lift is limited so your buffy X8 will be hard to lift up 30k ! polaris will not stall and glide down easy with any flight controler ![]() i can fly my 133%XL with 3s4000 and you may go up to 3s5000 without motor+ESC wich would give you approx 8 hours of up+ glide flying time |
Croatia
Joined Aug 2010
fpv-ing 2400meters to visit some rc buddyes at other field
Joined Jun 2012
I used the Bixler as my first FPV plane. It is great. I still enjoy flying it, but now I have cut off the wingtips to make it quicker on the roll. |
Joined May 2011
Keep it a bit nose heavy and trim it to a slow speed cruise. You want the plane to be stable in pitch and have it quickly establish that slow speed cruise on it's own (yeah, like someone said, there are better planes for such a purpose). If it's trimmed to less than 35 kts, your TAS should be less than 60 KTAS at 30,000 ft. (about M 0.1 if you're interested). Make sure the stiffness you added will allow 80 knot dives without wing or control surface flutter during your test flights. Without a motor and ESC, you should be pretty light. Instead of full span elevons, you might want to use just the inboard half. Glue or tape the outboard half so it doesn't move. You don't need all that control surface for FPV anyway unless you do FPV akro. Re-grease all your servo gears with low temp grease. Better yet, simply just remove all the grease. Don't want the grease to freeze up and jam the servos. Run an extra battery in parallel to make sure the cold soaked batteries have enough juice. Plug up all the holes to keep the cold air flow inside to a minimum, but don't make it airtight. Pay attention to winds aloft forecasts. 100+ knots of wind is pretty common. Plan on losing the plane. If you get it that high, odds are that you'll lose it unless it's a rare day of winds being under 20 kts all the way down. Still, there are many other things that can go wrong. Install a free-flight tracker so that you have a change of chasing it downwind and finding it. Name, phone number and address with "reward" on the plane increase the odds of getting it back. Find the nearest rocket club. They have places and times that allow for high altitude stuff and the airspace issues it causes. Stay within the legalities. The rocketeers have the scoop on going high and staying legal. That's all I can think of for now. Remember, it's a "foamie". Don't over engineer it and don't worry about breaking it. You can always get another one. Just make sure it doesn't end up in the engines of my B-777 ![]() Ben Clerx |
Building dollies and landing gear robs you of the required learning of how to throw a plane. Having the belly scrapped from hundreds of successful landings is a badge of honor. Ben Clerx |
| Thread Tools | |
| New Product X8---new 2.4GHz Radio System | ASSAN | Radios | 5653 | Feb 13, 2013 05:07 PM |
| For Sale Assan 2.4 ghz X8 6ch receiver Brand New | Scooter33 | Aircraft - General - Radio Equipment (FS/W) | 2 | Oct 12, 2011 09:34 AM |
| Discussion Any info regarding this x8 setup?Better than coax x8? | sjak | Multirotor Talk | 11 | Aug 14, 2011 08:33 AM |
| Sold New Assan Module X8 2.4 for JR Tx | norstaroption | Aircraft - General - Radio Equipment (FS/W) | 6 | Nov 21, 2009 05:42 AM |
| Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 | EyeFlyPlanes | Aircraft - General - Radio Equipment (FS/W) | 0 | Oct 20, 2008 02:39 AM |
