United States, FL, Pensacola
Joined Jul 2012
Just got notice that the final parts for my X8 are showing up today, so I figure I should start to get to work. I plan on creating a bunch of custom parts for my x8. Currently my plans are:
1) to thermal form a skid plate as i will probably be landing on a road. 2) 3d print custom servo boxes and have the servo arms come up through the top of the wings 3) 3d print inserts that i will strategically place around the main body, allowing me to bolt the entire body together instead of gluing. 4) custom 3d printed GoPro pan and tilt system that will allow me to easily attach a GoPro in its case. 5) custom printed or carbon fiber interior that will have mounts for esc, apm2, transmitters... and a slidable battery mount to precisely set up my cg. 6) 3d print 3dr and video transmitter mounts allowing the antennas to easily screw on and off through the top of the body. So far I have made a 3d scan of both half of the body of the x8 to use for sizing while i design my printed parts and printed out my first simple piece to make sure all measurements were accurate. The first piece I did was simply a motor mount plate that goes on the inside of the body allowing me to bolt the motor on all the way through the foam. My question - If you had easy access to thermal forming, custom carbon fiber parts, high precision 3d printer, cnc mill, 3d scanner, etc... what would be your dream upgrade to your X8 be. |
I have made a number of vac formed parts : belly skid, floor bays, fpv shroud, ant covers, esc cover, etc. look up my 'posted attachments'. Being a big plane, postage on skid plates etc is costly. Wish we had China postage system sometimes...how do they do it??? |
Joined Jul 2012
What i want to know is: is there some upgrade out there that someone wants, but they do not have the skills, time, or access to the necessary equipment to make it happen. I wish we had China post also.
Well, I think an 'affordable' belly skid plate would be a natural seller....key word being affordable.
What is that number? Not sure, but its not $50. What would get me to order one without thinking is a price of $10-$20 max. Not sure if there is a business at that price - maybe a hobby business. Second 'seller' would be a liner for the inside - equipment bay mounting...so everything had a 'solid' place to attach. Anyway, just my 2c |
Oh and yeah 'hobby businesses' dont have the economies of scale like the big mobs so why would they be cheaper? If I get AN order for a belly skid ($45) it is AN order, a run of ONE. I dont mind but when I have spent the hours making casts, then bucks/molds and test runs on materials, to then make one for the a dollar or two above the cost of the plastic sheet its a bit rough. Ideally Bevrc would offer them but until then we all have to improvise and ....share the knowledge and the dollars we save at Hobby King with each other ![]() Currently Im making a clear hatch (standard), as mine isn't standard due to the chute. check out the bits I have made 'posted attachments' Thanks |
Croatia
Joined Aug 2010
Joined Aug 2012
1. How the Airbrakes work for you? Are they really able to reduce the speed? 2. Do you use your airbrakes as rudder as well? 3. Can you post a video approaching for landing and activating the airbrakes so we can see it in use? Thanks for sharing. |
| Thread Tools | |
| New Product X8---new 2.4GHz Radio System | ASSAN | Radios | 5653 | Feb 13, 2013 05:07 PM |
| For Sale Assan 2.4 ghz X8 6ch receiver Brand New | Scooter33 | Aircraft - General - Radio Equipment (FS/W) | 2 | Oct 12, 2011 09:34 AM |
| Discussion Any info regarding this x8 setup?Better than coax x8? | sjak | Multirotor Talk | 11 | Aug 14, 2011 08:33 AM |
| Sold New Assan Module X8 2.4 for JR Tx | norstaroption | Aircraft - General - Radio Equipment (FS/W) | 6 | Nov 21, 2009 05:42 AM |
| Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 | EyeFlyPlanes | Aircraft - General - Radio Equipment (FS/W) | 0 | Oct 20, 2008 02:39 AM |
