Old Sep 19, 2012, 04:52 PM
frviana is offline
Find More Posts by frviana
Joined Aug 2012
Originally Posted by seojeff View Post
Sounds like a great combo to me.
On the prop and Spinner... any advise where I could get them in North America and what type of Spinner and prop I should look for?
frviana is offline Find More Posts by frviana
Old Sep 19, 2012, 05:01 PM
xviper is offline
Find More Posts by xviper
Canada
Joined Jul 2009
Originally Posted by Daemon View Post
Rear edge of the two front finger holes.
This is the recommended CG.
Originally Posted by AlexF View Post
that's right!
so witch CG is correct?
the one that bev says is wrong!
BEV recommends what Daemon just said. It is NOT wrong.
CG is pretty forgiving on the X8. Start at the recommended point (rear edge of the finger holds) and go from there. If you click 'Thread Tools' at the top of this page and then 'View all attachments from this thread', you'll see a few images of exactly where the CG should be. It's worth skimming through this entire thread, however daunting that might seem.
This is correct. The X8 has been successfully flown, stalled, spun at varying CGs, from exactly as BEV says, to several mm fore and several mm aft of the suggested CG. None are bad. None are preferred. It's what flies right to each individual.
Prevent stalling? EVERY plane will stall no matter what CG you use.
xviper is offline Find More Posts by xviper
Old Sep 20, 2012, 02:14 AM
daggad is offline
Find More Posts by daggad
Aalesund, Norway
Joined Jun 2012
I maidened my X8 with CG at recommended rear edge of the two front finger holes. And it did not need a single click of trim.
daggad is offline Find More Posts by daggad
Old Sep 20, 2012, 02:21 AM
rcmonster99 is offline
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
that's right!
when someone like Daemon recommend a CoG I would take it as gospel, look at his contribution to this thread see how successful his flights are and look at the extent he went to demonstrate spins and how to get out of them. his practical experience is invaluable.
So I would not hesitate to say the CoG is where Ian Suggests it is
rcmonster99 is offline Find More Posts by rcmonster99
Old Sep 20, 2012, 05:20 AM
AlexF is offline
Find More Posts by AlexF
Italy Genoa
Joined Nov 2008
i can easy trust Deamon , the problem that i have is that i have the same CG but my x8 do not fly correctly at the moment when i launch it it goes noese up and stall
AlexF is offline Find More Posts by AlexF
Old Sep 20, 2012, 08:48 AM
seojeff is offline
Find More Posts by seojeff
seojeff's Avatar
United States, GA, Atlanta
Joined Aug 2011
I would check your thrust angle & the trim on your elevons - also see if they have any play - are you using the stock elevons or did you replace them with balsa? Finally, did you do anything about the trailing edge of the wings not matching up with the fuselage? When I addressed this I was able to take all the trim out of my X8.
seojeff is offline Find More Posts by seojeff
Old Sep 20, 2012, 09:15 AM
AlexF is offline
Italy Genoa
Joined Nov 2008
my elevons are the stock and i trim them a little bit, there's no play.
the trailing is completely different of the fuselage and i did not touch ,but i think that could be the problem or not?
Old Sep 20, 2012, 09:26 AM
xviper is offline
Canada
Joined Jul 2009
Mine is the same. Without knowing how you launch it, it's hard to say what the problem might be. It's been discussed here before. The way you throw it may have more to do with why it goes up and stalls. Do you "throw" it or do you "push" it? How much power are you using when you launch it?
Old Sep 20, 2012, 09:37 AM
AlexF is offline
Italy Genoa
Joined Nov 2008
i wrote before,
i have been up on a hill where we go fly with gliders, there were some wind to help me fly, and i launch like i launch all gliders for example Blade2m with motor on 1\2 power.
Old Sep 20, 2012, 09:46 AM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
Are you launching with any auto pilot assistance??
I have my CG set 5mm behind the long finger holes but I launch at about 2/3 throttle using a scorp 3228 1100 on 4s and 9x6. I am not 100% certain of kv.
My build is light. Only a single 4s 4000 or 5000 mah for motor and servos and 2200 mah 3s to drive the VTX. It carries FY ap 21 and FY 117 ap OSD and a FPV cam to carry. No extra weight or reinforcement other than CF tongue at wing joiner and fiber tape on LE of wings.
I hold the model by the finger grips and balance the nose with the left hand which also holds my TX.
One step and a shove into the wind and off it goes. After many many launches only one failure when I did not take location altitude into consideration.
I launch with auto pilot "on" and in stable flight mode.
jayb1rdz is offline Find More Posts by jayb1rdz
Old Sep 20, 2012, 09:36 PM
jb_bak is offline
Find More Posts by jb_bak
Joined Oct 2011
So my Maiden went crazy, but I finally figured everything out. My first launch was out of control, and a stall/spin straight into the ground nose first. Bent/separated the nose and broke the big carbon fiber wing spar. Turns out I launched it with the gain on from the guardian stabilizer, along with a CG too far rear. Some packing tape and a 3/8 inch dowel from lowes later, I was back up. Flew fine but wouldn't turn left very well. Some settings were wrong with the mixing. After I got that fixed, it finally flew good. Threw on the goggles, and flew FPV so long I got bored! So now I have an APM2.5 on the way to make this really fun.
jb_bak is offline Find More Posts by jb_bak
Old Sep 20, 2012, 09:48 PM
zolpot is offline
Find More Posts by zolpot
Joined May 2012
zolpot is offline Find More Posts by zolpot
Old Sep 20, 2012, 09:58 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Nope, you've got all you need, assuming the little squares for the canopy magnets
are in the bag (think I see corner of one there). The rectangular pieces that
used to go through those slots in the wing root, have been eliminated from the kit.
ian
Daemon is online now Find More Posts by Daemon
Old Sep 20, 2012, 10:01 PM
Vlodek9 is offline
Find More Posts by Vlodek9
Vlodek9's Avatar
United States, AZ, Chandler
Joined Sep 2010
So does anyone recommend making their own rectangular pieces for the wing slots or was that pointless. I guess I'm asking why would they eliminate it, to save money or is it just not needed?
Vlodek9 is offline Find More Posts by Vlodek9
Old Sep 20, 2012, 10:17 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
They were originally intended to be used only as a method to hold the wings on by
putting some sort of bolt or screw through them (the hole is still in the wing).
Now the intention is that a bolt or screw be put through the holes in the top (the tabs that stick up)
of the wing root pieces instead. I use neither. Even in a mild crash, any small attachment
mechanism like a bolt, will serve only to rip the thin plywood apart, of tear it from the foam.
Instead, I just use tape to hold the wings on. Same as I use tape to hold
the wings on, my 350mph 15lb carbon composite DS plane. It holds up to flight loads
and gives in a crash or rough landing.
Of course feel free to over-complicate the X8 build. Most people here do.
ian
New Product X8---new 2.4GHz Radio System ASSAN Radios 5741 Aug 22, 2016 01:25 PM
For Sale Assan 2.4 ghz X8 6ch receiver Brand New Scooter33 Aircraft - General - Radio Equipment (FS/W) 2 Oct 12, 2011 09:34 AM
Discussion Any info regarding this x8 setup?Better than coax x8? sjak Multirotor Talk 11 Aug 14, 2011 08:33 AM
Sold New Assan Module X8 2.4 for JR Tx norstaroption Aircraft - General - Radio Equipment (FS/W) 6 Nov 21, 2009 05:42 AM
Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 EyeFlyPlanes Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2008 02:39 AM
