Old Sep 19, 2012, 11:48 AM
xviper is offline
Find More Posts by xviper
Canada
Joined Jul 2009
Originally Posted by jb_bak View Post
My folding prop does not have anything to push against going forward. Another words, you can physcially move the props far enough forward that they touch the trailing edge of the plane. Is this correct or have I got them mounted wrong? I did build a bracket to keep them from going over center to the rear
The only time (extremely rare) when this might be a problem is if you've gone vertical, shut the motor off at the zero gravity point and the plane does a tail slide. Then the blades can go towards the body and if you crank the motor on before the X8 flips over to point its nose down (and wind pushes the blades back), the blades could whack the body.
xviper is offline Find More Posts by xviper
Old Sep 19, 2012, 12:17 PM
eroeder is online now
Find More Posts by eroeder
eroeder's Avatar
United States, TX, Frisco
Joined Jan 2004
Originally Posted by Daemon View Post
That's fine. Centrifugal force will keep it from going forward.
What is extremely important is that you have a prop-stopper to prevent
a blade from folding back past the center line. If it does, it will not swing open
when the motor starts and the severe imbalance will literally rip the
motor from the plane.
ian
What is a prop stopper? Never heard of it. Who sells?
Thanks!
eroeder is online now Find More Posts by eroeder
Old Sep 19, 2012, 12:21 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Many sources if you search but here's an example http://www.getfpv.com/accessories-27/accessories.html
It prevents the blades from folding back over center.
I've made em myself out of sheet metal, and even old cut up credit cards.
ian
Daemon is online now Find More Posts by Daemon
Old Sep 19, 2012, 12:29 PM
xviper is offline
Canada
Joined Jul 2009
Here's another:
http://www.espritmodel.com/search.as...d=prop+stopper
Old Sep 19, 2012, 01:46 PM
eroeder's Avatar
Joined Jan 2004
Interesting!
Old Sep 19, 2012, 03:22 PM
AlexF is offline
Find More Posts by AlexF
Italy Genoa
Joined Nov 2008
Actually i haven't understood, wich is the correct CG?
AlexF is offline Find More Posts by AlexF
Old Sep 19, 2012, 03:53 PM
jb_bak is offline
Find More Posts by jb_bak
Joined Oct 2011
Thank you guys for clearing up my folding prop question
jb_bak is offline Find More Posts by jb_bak
Old Sep 19, 2012, 03:54 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Rear edge of the two front finger holes.
Old Sep 19, 2012, 03:55 PM
frviana is offline
Find More Posts by frviana
Joined Aug 2012
I just ordered a X8 and I am now checking for the electronics...
I'm wondering if I could use a e-flite 25 as Motor... is has very similar Specs of the Hacker A-30
http://www.e-fliterc.com/Products/De...odID=EFLM4025A
I got both the E-Flite 25 and an E-flite 60A ESC... would those work well?
frviana is offline Find More Posts by frviana
Old Sep 19, 2012, 03:57 PM
AlexF is offline
Italy Genoa
Joined Nov 2008
Deamon,
so why somebody says different cg?
Old Sep 19, 2012, 04:01 PM
Stefan_Go is offline
Find More Posts by Stefan_Go
Stefan_Go's Avatar
Finland, Pirkanmaa, Valkeakoski
Joined Sep 2012
If I understood it right, some people said that a CG a few mm in front of the recommended CG provides more stability and prevents stalling.
Stefan_Go is offline Find More Posts by Stefan_Go
Old Sep 19, 2012, 04:08 PM
frviana is offline
Joined Aug 2012
Also, is this the Hitec HS-485HB Deluxe servo 4.8kg/45g/0.22sec too big of a Servo? I have a few of it hanging at home.
Old Sep 19, 2012, 04:16 PM
AlexF is offline
Italy Genoa
Joined Nov 2008
that's right!
so witch CG is correct?
the one that bev says is wrong!
Old Sep 19, 2012, 04:44 PM
seojeff is offline
Find More Posts by seojeff
seojeff's Avatar
United States, GA, Atlanta
Joined Aug 2011
Sounds like a great combo to me.
seojeff is offline Find More Posts by seojeff
Old Sep 19, 2012, 04:47 PM
seojeff is offline
seojeff's Avatar
Joined Aug 2011
that's right!
CG is pretty forgiving on the X8. Start at the recommended point (rear edge of the finger holds) and go from there. If you click 'Thread Tools' at the top of this page and then 'View all attachments from this thread', you'll see a few images of exactly where the CG should be. It's worth skimming through this entire thread, however daunting that might seem.
New Product X8---new 2.4GHz Radio System ASSAN Radios 5743 Sep 01, 2016 11:51 AM
For Sale Assan 2.4 ghz X8 6ch receiver Brand New Scooter33 Aircraft - General - Radio Equipment (FS/W) 2 Oct 12, 2011 09:34 AM
Discussion Any info regarding this x8 setup?Better than coax x8? sjak Multirotor Talk 11 Aug 14, 2011 08:33 AM
Sold New Assan Module X8 2.4 for JR Tx norstaroption Aircraft - General - Radio Equipment (FS/W) 6 Nov 21, 2009 05:42 AM
Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 EyeFlyPlanes Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2008 02:39 AM
