Old Sep 17, 2012, 04:15 AM
Gatos is offline
Find More Posts by Gatos
www.eahk.gr at Iraklion Grete
Gatos's Avatar
Greece, Crete
Joined Jun 2012
Hi guys
I have the AVTX5.8 Transmitter 800mW and fat shark goggles and I need OSD and Stabilization system . What is your opinion about this combination?
FY31AP trade edition-Equipped with Hornet OSD
http://www.bevrc.com/fy31ap-trade-ed...-osd_p292.html
Gatos is offline Find More Posts by Gatos
Old Sep 17, 2012, 09:45 AM
toubab is offline
Find More Posts by toubab
Auxerre - France
toubab's Avatar
France, Bourgogne, Auxerre
Joined Dec 2011
Merci Rc Monster ! Thanks Dave soon, soon will be the video ( I have done a litlle montage) with the technical description !
PS : Rc monster , si tu est de l'autre coté de la manche, on pourrais volé ensemble un jour !!! Quel équipement FPV as tu ?
toubab is offline Find More Posts by toubab
Old Sep 17, 2012, 01:12 PM
saabguyspg is offline
Find More Posts by saabguyspg
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
you can see my 31AP thread here..
http://www.rcgroups.com/forums/showt...575919&page=76
I love my FY products... yes there are some downfalls but so far they are the easiest to set up and they just work.
If you expect military grade performance then you are gonna have to spend lots more money
Steve
Originally Posted by Gatos View Post
Hi guys
saabguyspg is offline Find More Posts by saabguyspg
Old Sep 17, 2012, 01:19 PM
Dr.Tom is offline
Find More Posts by Dr.Tom
Youtube: TomRi25
Dr.Tom's Avatar
Croatia, City of Zagreb, Zagreb
Joined Aug 2010
What is neutral setting for elevons to start with, 0 or some mm up?
Is hand launching better with more deflection or same like those for level flight?
I had a flying wing, and it needed 5mm up elevons just to start with,
even more for launch, but it had much higher wingloading than x8 and smaller thrust to weight ratio (smaller prop in goal of getting higher speed)
http://www.rcgroups.com/forums/showp...&postcount=615
Dr.Tom is offline Find More Posts by Dr.Tom
Old Sep 17, 2012, 01:53 PM
xviper is offline
Find More Posts by xviper
Canada
Joined Jul 2009
My X8 needs no UP clicks of elevator for launch. I throw it at full throttle and a bit of above level inclination, with the same trim as the last flight it had.
Now, having said that, your first launch could be tricky because you don't really know if the plane is trimmed for normal flight. Also keep in mind that the warpage that gives an upsweep on the rear fuse wing root is different for every plane. If you leave it as is, trim will be different than if you use something to line the wing root with the part of the wing it meets. On mine, the warp is slightly different on one side than it is on the other, so one elevon has more down defection than the other just to make it fly level. It looks goofy but the plane flies just great.
PS. As with you, my other planes are different. My Funjet Ultra needs about 12 clicks of UP trim for launch and my V70 Zephyr needs 6 clicks of UP. And my flying Pterodactyl needs nothing.
xviper is offline Find More Posts by xviper
Old Sep 17, 2012, 10:02 PM
zolpot is offline
Find More Posts by zolpot
Joined May 2012
zolpot is offline Find More Posts by zolpot
Old Sep 18, 2012, 01:56 AM
deTonaTor_NZ is offline
Find More Posts by deTonaTor_NZ
Religion= suffering/wars
deTonaTor_NZ's Avatar
Joined Jan 2006
Mods I made to my catapult. Firing it this weekend.
deTonaTor_NZ is offline Find More Posts by deTonaTor_NZ
Old Sep 18, 2012, 03:32 AM
hans66 is offline
Find More Posts by hans66
Joined May 2011
Very nice, mate. We can tell what you do for a living...
hans66 is offline Find More Posts by hans66
Old Sep 18, 2012, 04:16 AM
toubab is offline
Auxerre - France
toubab's Avatar
Joined Dec 2011
Very good job ! I may said perfect !
Dont worry I am sure it will work well !
How do you hold the plane ?
Is it easy to carry in the car or in a bag ?
Let me know if you want to sail one one of this catapult because I will be very interestede
Old Sep 18, 2012, 04:45 AM
zolpot is offline
Joined May 2012
Old Sep 18, 2012, 06:36 AM
jmcclv is offline
Find More Posts by jmcclv
jmcclv's Avatar
France
Joined Mar 2011
Originally Posted by zolpot View Post
Make it 2 please.
+1
Do you use ''on the shell'' parts or special ones ?
JM
jmcclv is offline Find More Posts by jmcclv
Old Sep 18, 2012, 06:37 AM
toubab is offline
Auxerre - France
toubab's Avatar
Joined Dec 2011
Was long to do the video montage but now it is done !
Here it is
X8 in Auxerre field (5 min 35 sec)
Advise and idea will be welcome !
Fabrice
Old Sep 18, 2012, 06:55 AM
Imagecatcher is offline
Find More Posts by Imagecatcher
Imagecatcher's Avatar
NSW Australia
Joined Mar 2010
Beautifully designed and made DT. makes mine look like scrap metal.
What is your kg pull? and the AUW of the X8?
Mine will be shy of 5kg so that + the cradle I figure I need close to 35kg of pull on the bands (6 loops @ 1m perimeter)
Again very nice engineering...your power toys are way better than mine.
Imagecatcher is offline Find More Posts by Imagecatcher
Old Sep 18, 2012, 06:56 AM
toubab is offline
Auxerre - France
toubab's Avatar
Joined Dec 2011
Hey guys, I was wondering if anyone could chime in a bit to give some suggestions/opinions on my next build, not sure if I have the most efficient setup as I imagine. Thanks.
X8 wing
Hacker a40v2 500kv 1100w
Castle ice 75a
13x7 graupner, 45mm spinner
servos turnigy digital 5.4kg/.11sec/22.5g
10Ah 6s turnigy 65-130c
cc bec pro 20a (to power vtx and camera)
rvosd 5.1
tbs69 & replacement 1.8mm 170fov lens
2500mw VTx 1.3ghz rmrc
skew planar 1.3ghz
low pass filter 1.3ghz
dragonlink v2
xt90 connectors
Do you have any video of your x8 here ?
What is your time flight with this set up ?
Fabrice
Old Sep 18, 2012, 09:21 AM
zolpot is offline
Joined May 2012
New Product X8---new 2.4GHz Radio System ASSAN Radios 5740 Mar 06, 2016 01:21 PM
For Sale Assan 2.4 ghz X8 6ch receiver Brand New Scooter33 Aircraft - General - Radio Equipment (FS/W) 2 Oct 12, 2011 09:34 AM
Discussion Any info regarding this x8 setup?Better than coax x8? sjak Multirotor Talk 11 Aug 14, 2011 08:33 AM
Sold New Assan Module X8 2.4 for JR Tx norstaroption Aircraft - General - Radio Equipment (FS/W) 6 Nov 21, 2009 05:42 AM
Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 EyeFlyPlanes Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2008 02:39 AM
