Old Sep 11, 2012, 07:54 PM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
Originally Posted by rsowder View Post
I'm guessing you were using "Foam safe" CA. You need to use "Non foam safe" CA. With that, you'll break the foam before you break the glued joint.
Thank you for adding that important detail.
Foam safe CA is a poor bonding material for EPO. Regular Med -CA with kicker is best.
jayb1rdz is offline Find More Posts by jayb1rdz
Old Sep 11, 2012, 08:31 PM
blackidmagic is offline
Find More Posts by blackidmagic
Joined Aug 2012
I'll be sure to add some of that to my cart next time I order something.
blackidmagic is offline Find More Posts by blackidmagic
Old Sep 12, 2012, 01:47 AM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
X8 spin testing
FPV - X8 - Spin baby spin (8 min 24 sec)
ian
Daemon is offline Find More Posts by Daemon
Old Sep 12, 2012, 03:57 AM
Opt is offline
Opt
Find More Posts by Opt
Opt
New Zealand, Auckland
Joined Oct 2010
Fantastic work, Ian. Thanks for this.
Opt is offline Find More Posts by Opt
Old Sep 12, 2012, 04:48 AM
Kev.au is offline
Find More Posts by Kev.au
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
Originally Posted by Daemon View Post
You spin me right round (like a record baby) lyrics (3 min 13 sec)
Kev.au is offline Find More Posts by Kev.au
Old Sep 12, 2012, 07:15 AM
Rastislavko is online now
Find More Posts by Rastislavko
You can't take the sky from me
Rastislavko's Avatar
Slovakia, Bratislava Region, Bratislava
Joined Jun 2006
This fits better:
TaleSpin Intro (1 min 1 sec)
Great work, Ian. What about your head after all that spinning? And, did you find that poor GoPro?
Rastislavko is online now Find More Posts by Rastislavko
Old Sep 12, 2012, 09:19 AM
xviper is offline
Find More Posts by xviper
Canada
Joined Jul 2009
That was a thing of beauty! You were able to get much better video proof than I did because I was uncertain of the results, so mine were from much higher altitudes.
From your vids, my conclusions in post #5343 still stand.
http://www.rcgroups.com/forums/showp...postcount=5343
xviper is offline Find More Posts by xviper
Old Sep 12, 2012, 09:38 AM
Flying Tivo is offline
Find More Posts by Flying Tivo
Joined Feb 2007
Ian:
Did you find out that left spins are easy to enter than right?
Did you balance your wing laterally??
Felipe
Flying Tivo is offline Find More Posts by Flying Tivo
Old Sep 12, 2012, 10:42 AM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Ya. Pointing down in the spin moments before gave me an idea of where I was
positioned relative to the railroad tracks. OSD told me the distance from
base station and speed. Dropping the camera at 35mph from 630ft up
means it'll travel roughly another 100 yards. Did a few calculations and marked
the center of the search area on Google Earth. We ran out there, and I found
it in the short grass inside of 3 minutes. Camera was ok, but it had ejected
the card, so no video of the fall. Without a ground recording, it would have been
totally impossible to find.
Originally Posted by Flying Tivo View Post
Ian:
Felipe
Yes, my particular X8 will only spin to the left. The scariest spin started
with an attempt to go right, but it still snapped to the left. There's no
obvious reason why it prefers left but the plane is a bit beat up.
ian
Old Sep 12, 2012, 11:08 AM
Cubcrazy is online now
Find More Posts by Cubcrazy
Scale Foam Flyer
Cubcrazy's Avatar
United States, AR, Cabot
Joined Oct 2007
Most planes decide which direction they prefer to spin based on the prop orientation with regard to rotation and thrust line. Try doing some spins with power off in both directions and see how the lack of motor torque effects it.
-Cub
Cubcrazy is online now Find More Posts by Cubcrazy
Old Sep 12, 2012, 11:18 AM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Should be fairly obvious from the video, that the motor was off for *every* spin.
ian
Old Sep 12, 2012, 11:25 AM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
deleted
Old Sep 12, 2012, 12:54 PM
rcmonster99 is offline
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
this is test pilots stuff only you get to keep your derriere firmly on the ground.
rcmonster99 is offline Find More Posts by rcmonster99
Old Sep 12, 2012, 01:49 PM
AlexF is offline
Find More Posts by AlexF
Italy Genoa
Joined Nov 2008
Today i made my first flght with the x8 wing and i am sorry but it doesn't work, i made the correct cg and i went up on a hill where we fly with gliders to make a first fly more easy and secure.
But the x8 was put it noese up on the sky and then stall. i did 3 times then i quit.
Please can you tell me how much weight you put on to correct the cg?
i think to make fly this delta it needs to go fast and never get slowly if not it stall, is it correct?
Thanks Alex
AlexF is offline Find More Posts by AlexF
Old Sep 12, 2012, 02:05 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
It's hard (almost impossible) to hand launch the X8 without power. The problem
is the finger holes are well below the center of mass, so when you try to throw
it hard, it pitches upward and tip stalls, because it won't fly without at least 15-20mph
of airspeed. A running launch with the nose down might work from a hill,
but it's a lot easier to just power up and let the thrust keep it from pitching up.
ian
New Product X8---new 2.4GHz Radio System ASSAN Radios 5740 Mar 06, 2016 01:21 PM
For Sale Assan 2.4 ghz X8 6ch receiver Brand New Scooter33 Aircraft - General - Radio Equipment (FS/W) 2 Oct 12, 2011 09:34 AM
Discussion Any info regarding this x8 setup?Better than coax x8? sjak Multirotor Talk 11 Aug 14, 2011 08:33 AM
Sold New Assan Module X8 2.4 for JR Tx norstaroption Aircraft - General - Radio Equipment (FS/W) 6 Nov 21, 2009 05:42 AM
Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 EyeFlyPlanes Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2008 02:39 AM
