Old Sep 01, 2012, 09:24 PM
jcarff is offline
Find More Posts by jcarff
United States, FL, Pensacola
Joined Jul 2012
X8 Parts
I am ready to buy and want to know everyone's thoughts on this setup for my X8. looked around a little more and finalizing my part list.
Motor - Turnigy Aerodrive SK3 - 3548-840kv
Prop - Spinner/
12x6.5 carbon fiber prop
esc - HobbyKing Red Brick 60A ESC
battery - ZIPPY Flightmax 5000mAh 4S1P 30C
i also want the option to eventually add a second 5000mAh to increase my flight time. Is this a good setup, would anyone recommend anything else. I am willing to spend 100 to 200 on the motor/esc/prop/battery. i am looking to get at least a 30 min flight and have enough power to have some fun. please let me know what you think. i am dying to place this order. also can anyone recommend a bec for me.
jcarff is offline Find More Posts by jcarff
Old Sep 01, 2012, 09:34 PM
seojeff is offline
Find More Posts by seojeff
seojeff's Avatar
United States, GA, Atlanta
Joined Aug 2011
Prop - Spinner/
That setup will work fine. You'll easily get more than 30 mins.
seojeff is offline Find More Posts by seojeff
Old Sep 01, 2012, 11:43 PM
xviper is online now
Find More Posts by xviper
Canada
Joined Jul 2009
Finally got a chance to fly my X8 this morning and test out the "stallability" and "spinability" of this plane. In the first video, is the first flight of the day. The video was done with a Sony Webbie attached to my ball cap. With the doom and gloom of the X8 stalling out and spinning itself uncontrollably into the dirt, I took the plane up pretty high before I started testing. That's why the plane is just a small blip that focuses in and out, but if you go full screen and keep your eyes on the little speck, you'll see how many times I stalled it. I powered off, then pulled gently up till the plane stopped flying. I also did a sudden pull up to the vertical with power off and even pulled up and rolled to the inverted power off. In one stall, the X8 went into a spin. Had I done nothing, it would have corkscrewed itself into the ground, but once I felt it had enough decent speed, I applied opposite full aileron and the thing just straightened up and I could level out. In one vertical stall, the X8 even did a tail slide for a couple of dozen feet, then flipped over and pointed nose down. The X8 does in fact, stall just like my Funjet and Scimitar. This first flight was with my smaller batteries, which put the CG at -5mm (0mm being the stock recommended location).
I'm afraid both videos are quite boring because nothing happened. The plane did not auger itself into the ground. It recovered easily from each stall and the spin.
X8 Skywalker Wing - hat cam (6 min 39 sec)
The next video is my second flight and since the first flight was so uneventful, I decide to risk my Sony cam mounted on the forehead of the X8 and repeated all my stalls. This time, with my bigger batteries and the Sony, the CG moved to +15mm. Once again, the video is pretty boring because nothing eventful happened. Recovery was very easy and happened within less than 50 feet of lost altitude. Never was any power used to achieve recovery. I only powered up to go back up to try another stall or in the case where the hawks came after the plane, to get away from them.
Stalling X8, onboard Sony Webbie (4 min 3 sec)
So to answer my own questions about the CG and about stalling and spinning:
Does the CG need to be exact (within reason)? ........... NO! We've (Daemon and I) discovered that the CG can be varied as much as +15 and -5 mm. I'm pretty sure it can be varied even more without any problems. It's not doom and gloom to be a bit off, but to be on the safe side, go with what is recommended.
Is a stall with the X8 the end of the flight? NO! (unless it's too low) In fact, if left alone, it recovers quite nicely, then with a little help of elevator, to level out.
Will a spin end up in the dirt? NO! (unless it's too low) Again, leave it alone till it falls to its terminal velocity (that won't take long), then give it opposite control input and it'll straighten out so you can actually make it fly again.
The only warning I can give with regards to the X8 .............. Hawks and falcons really hate this thing for some reason. They tend to attack it and try to take a piece out of it. Luckily, my X8 is powerful enough and fast enough and maneuverable enough to get away from them and can actually "play" with them. I'm sure most X8's out there can do the same.
Finally, if you fly this thing through goggles or a view screen, all bets are off. You may have a real tough time figuring out why something went wrong, what it's doing when it goes wrong or how to right the wrong.
xviper is online now Find More Posts by xviper
Old Sep 02, 2012, 04:04 PM
jcarff is offline
Joined Jul 2012
purchase complete
xviper, glad to hear you were successful in recovering from your stalls, i was planning on running a few stall tests when i get my x8 in, glad to know that they should be easy to recover from. I finally placed my completed order and now am just waiting for my parts.
44mm Alloy folding Prop Spinner with 5mm adapter
Carbon Fiber 12x6.5 Folding Prop Blades
Turnigy Plush 60amp Speed Controller
ZIPPY Flightmax 5000mAh 4S1P 25C
2x Corona DS329MG Digital Metal Gear Servo 3.8kg / 32g / 0.11s
total cost with shipping is $174.69 bringing my x8 expenses to a total of $375.69. cant wait to customize this thing
Old Sep 02, 2012, 04:29 PM
henlo is offline
Find More Posts by henlo
South Africa, WC, Vredendal
Joined Sep 2008
Hi There! Can someone please help me?
I have a E-flight Power 60 motor laying around. Will it work on my X8 wing & with what prop & with how many cell lipo's?
Specs
•Type:Brushless Outrunner
•Size:Replacement for 60-size glow engines
•Bearings or Bushings:Ball Bearings
•Wire Gauge:14
•Recommended Prop Range:14x8 to 16x10
•Voltage:18.5 to 28.8
•RPM/Volt (Kv):400
•Resistance (Ri):.06 ohms
•Idle Current (Io):2.70A @ 10V
•Shaft Diameter:6mm (.24 in)
•Overall Length:62mm (2.40 in)
•Weight:380g (13.0 oz)
•Overall Diameter:50mm (2.00 in)
•Diameter:50mm (2 in)
•Length:62mm (2.4 in)
•Continuous Current:40A
•Maximum Burst Current:60A (15 sec)
•Cells:16-24 Ni-MH/Ni-Cd or 5-7S Li-Po
•Speed Control:80A Brushless
henlo is offline Find More Posts by henlo
Old Sep 02, 2012, 05:04 PM
bobthenuke is offline
Find More Posts by bobthenuke
70 is the new 50
bobthenuke's Avatar
United States, AZ, Peoria
Joined Feb 2005
FWIW, http://www.rcgroups.com/forums/showt...55543&page=339
Report # 5082 (Stall tests)
bobthenuke is offline Find More Posts by bobthenuke
Old Sep 02, 2012, 05:10 PM
seojeff is offline
seojeff's Avatar
Joined Aug 2011
Specs
•Wire Gauge:14
•RPM/Volt (Kv):400
That's kinda overkill and low kv. Not sure if a 13x6 at that kv would be enough. If you can get a folding prop that size I guess it will work. Says you need a 5, 6, or 7 cell lipo. Again, most folks are running 3s or 4s - no need for higher unless you want to go fast which isn't really what this kit is built for. My advice is to sell that motor in the classified section - for what you get for it you could buy a properly sized motor and a 4s 5000mah lipo from HobbyKing.
Old Sep 02, 2012, 05:34 PM
70 is the new 50
bobthenuke's Avatar
Joined Feb 2005
Originally Posted by idletime View Post
The general feedback on that type of air-brake is this: they will not function well on a wing. They will cause too much disruption on airflow across the elevons. I ordered a set myself, but have not installed for the same reason.
I wouldn't hesitate for a second since that "general feedback" is suspect in its accuracy. Here's a picture of a Multiplex Cortina, a much sought-after wing that utilizes pop up air brakes (mounted right in front of the elevons) and it flies wonderfully with no issues with the brakes extended (I have one myself and love it). I intend to add pop up brakes myself either on my current X-8 wing or, hopefully, on a new one that I can modify to my heart's content. The only issue I have with the HobbyKing airbrakes is that they're made of cheap plastic.
-bob
Old Sep 02, 2012, 06:00 PM
wep is offline
wep
Find More Posts by wep
wep
https://vimeo.com/wep800
wep's Avatar
Joined Dec 2006
Check out the new launcher from my buddy Dammes.
Fully custom made, electronically released.
Mine(x8 and launcher) are still in build process, aredifferent but will show here soon of course.
X8 and DL-01 launcher test (4 min 1 sec)
wep is offline Find More Posts by wep
Old Sep 02, 2012, 06:24 PM
Obese1konobe is offline
Find More Posts by Obese1konobe
New Zealand, Wellington, Wellington City
Joined Aug 2012
Ias rules
Originally Posted by peppe_i8uza View Post
right.... for that we should have a Pitot, reading IAS (indicated air speed), that is the only speed to refer about flight conditions..... just a GPS is not enough.... I ordered my Pitot tube for APM2.5..... I'm sorry for "pure" and "good" RC pilots (I'm not), but it's the only way to properly evaluate stall speed, attitude, etc.
100% true. Flying OSD using Gps derived speed is living on the knife edge.
It's IAS that the wing and the laws of physics 'cares about' ...
Obese1konobe is offline Find More Posts by Obese1konobe
Canada
Joined Jul 2009
Originally Posted by bobthenuke View Post
Nice to know there are a few people here who believe me when I say a stall with an X8 does not spell the end of the world. There will always be those who simply won't believe it unless they see proof and send out the challenge to provide that proof. Then there's the armchair aeronautical engineers who insist that an X8 cannot be safely flown unless the CG is spot on, without any deviation whatsoever. I kinda sat there and scratched my head when I read that 5mm of CG shift is the only way their X8 would fly. On a huge model like this, 5mm is nothing, but of course, to some, 1mm is the difference between flying and crashing.
Old Sep 03, 2012, 10:13 AM
ojala1 is offline
Find More Posts by ojala1
United Kingdom, England, Cumb
Joined Sep 2011
[QUOTE=henlo;22621862]Hi There! Can someone please help me?
I am running an E-Flight Power 32 with 2 x 4s 5000Mah with 12 x 7 prop and it goes vertical
ojala1 is offline Find More Posts by ojala1
Old Sep 03, 2012, 11:09 AM
henlo is offline
Joined Sep 2008
[QUOTE=ojala1;22627826]
Thanks a lot, that help me a lot!!! Don't like HK's Turnigy motors that much. Had bad luck with them & they are noisy!!! :-)
What FPV setup do you have in your X8? What's the flying weight of it?
Old Sep 03, 2012, 11:51 AM
fatalisx8 is offline
Find More Posts by fatalisx8
Joined Jul 2012
Hi Everyone,
I took my time and read the whole thread, quite lot of information. Then I got to the point that I have the wing and other bits and bobs and more on order. Im using a Hacker motor and since Im a total beginner in this scene (but willing to learn ) I did not manage to take out the motor shaft and turn around. There was nothing in the user manual about this process so I went along with some guide from youtube. The guide did not mention that Im supposed to dissolve the thread lock with acetone before trying to remove the screws which hold the shaft in place. Anyway i messed up quite high number of 1.5 mm hex wrenches and the screws a bit as well. So I would not change the shaft anymore unless its absolute neccessary. I gave a call to the shop where the guy suggested to use the small attachment which came with the motor to be installed on the other side of the motor. However this part has thread on it and the diamter is 6 mm. The folder prop spinner I have ordered but havent received is for 5mm shaft. I find this setup a bit awkward and also some more screws are included which could be a cause of a failure in the future? I also find it dodgy to make space for the original motor shaft which would enter the foam of the fusselage. What do you think is this setup can be okay or should I insist on changing the shaft over? Will I be able to mount the prop spinner on the attachment?
The prop spinner is the same as this, only mine is 50mm wide:
http://www.ebay.co.uk/itm/41mm-Alumi...item1e6c7ef68f
Also Im attaching two photoes of the motor not yet fixed in the wing (obviously I will use longer bolts or anti vibe mount to bolt the motor to a second firewall in the end of the fuse as its common with others).
Thanks for your input!
fatalisx8 is offline Find More Posts by fatalisx8
Old Sep 03, 2012, 12:17 PM
shadowsnipes is offline
Find More Posts by shadowsnipes
Joined Jul 2012
Will this modification for X8 be alright? I mean, will it not necessarily create any problems aside from removing the hand-launch capability?
The pink part is the foam to be cut while the blue parts are the walls and cover for the hole created.
I would like to hear your opinions first before implmenting it.
By the way, I'll be using Catapult launch.
shadowsnipes is offline Find More Posts by shadowsnipes
New Product X8---new 2.4GHz Radio System ASSAN Radios 5740 Mar 06, 2016 01:21 PM
For Sale Assan 2.4 ghz X8 6ch receiver Brand New Scooter33 Aircraft - General - Radio Equipment (FS/W) 2 Oct 12, 2011 09:34 AM
Discussion Any info regarding this x8 setup?Better than coax x8? sjak Multirotor Talk 11 Aug 14, 2011 08:33 AM
Sold New Assan Module X8 2.4 for JR Tx norstaroption Aircraft - General - Radio Equipment (FS/W) 6 Nov 21, 2009 05:42 AM
Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 EyeFlyPlanes Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2008 02:39 AM
