Old Jul 30, 2012, 12:58 AM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Originally Posted by rcmonster99 View Post
I probably would have dived the same way if I know there was a strong wind against me. It was a close have though!
It's still better to resist that urge, *especially* with a headwind.
Just this evening, I flew my X8 out 6.5 miles (new PB), and turned toward home
with 3400ft of altitude and only 1200mAh remaining in the pack. Normally
that'd be plenty as the X8 has a great glide ratio (even if only 10:1,
that's 6.4 miles on glide alone, and I know it's better than that).
That's when I discovered I had at least a 10mph headwind (was dead
calm at launch, and air I was flying in was glass smooth). That cut
my ground speed to less than 20mph effectively adding at least 7.5
minutes to my flight time, increasing total distance through the air
to over 10 miles. Was all I could do to keep from putting the nose down
a lot when I'd see the ground speed drop below 15mph. A tiny bit of nose
down, as little motor as possible and simply wait it out, and I made it all but
the last 175 yards (landed at the end of the driveway).
Streamed that flight live on justin.tv, for which there's an archive of the flight for
a few days if anyone cares.
ian
Daemon is offline Find More Posts by Daemon
Old Jul 30, 2012, 02:05 AM
rsowder is offline
Find More Posts by rsowder
rsowder's Avatar
San Francisco
Joined May 2009
ian
Where and how do I view your flight? I'm not families with Justin.tv.
rsowder is offline Find More Posts by rsowder
Old Jul 30, 2012, 02:08 AM
galaxiex is offline
Find More Posts by galaxiex
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
Post #10 in this thread >>> http://www.rcgroups.com/forums/showthread.php?t=1701284
galaxiex is offline Find More Posts by galaxiex
Old Jul 30, 2012, 02:12 AM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
http://www.justin.tv/daemon42/videos
The flight got chopped up into pieces on jtv (probably networking glitches)
so it's the most recent 3-4 clips (last of the day on 7/29).
[edit]Unfortunately, looks like jtv lost a big chunk of the flight
between about 5.5 miles out, and 3 miles which was kind
of the most relevant. Oh well. I've got the ground
recording but it lacks the commentary between myself and my spotter
about strategy to get home.
ian
Old Jul 30, 2012, 04:34 AM
OzparkPilot is offline
Find More Posts by OzparkPilot
Watts up ?
OzparkPilot's Avatar
Australia, NSW, Sydney
Joined Nov 2006
Would vortex generators be beneficial to the X8s flight characteristics ?
OzparkPilot is offline Find More Posts by OzparkPilot
Old Jul 30, 2012, 06:20 AM
Gusisin is offline
Find More Posts by Gusisin
Gusisin's Avatar
Joined May 2012
Originally Posted by G-Forced View Post
I remember seeing someone had gone ahead and installed a nice solid set of retracts to there 8 - I can't seem to find it now.. Are you out there ?
Yep that would be me. I have been off the air for a while due to a motor bike accident. Good news is that the occupational therapy of building my X8 means that I am almost ready to maiden. I will be posting an update on the retracts soon. Basically I chose a set of DSR-46 retracts from EPF hobbies in Tiawan. All up weight atm with battery, video kit, pan tilt, retracts motor gps arduino, osd the works is 3.2 KG.
Retract lessons.
1. Good news is that if you retract the mains toward the center of the aircraft and the nosewheel from front to back and balance the CG to be good with wheels up you get a handy way to shift the cg to the front in a spin :-) and its not much it is equiv to adding a 25c coin on the front bulkhead beam.
2. Secure the gear to plywood reinforcements ( I will post pictures).
3. Plan for some form of prop strike pritection. I chose to install a skid that retracts with the gear. Basically is decends behind the main gear for take off and landing such hat if you over rotate the skid will hit before the prop.
Here she is, covered the front in fine glass with varnish then sprayed with grey primer.
Gusisin is offline Find More Posts by Gusisin
Old Jul 30, 2012, 07:49 AM
ggtronic is offline
Find More Posts by ggtronic
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
Originally Posted by brosius85 View Post
don't just balance it for the video - the vibrations will ruin every part of the plane ask me how i know
nice video ! that was close !
the flight between about 5.5 miles out, and 3 miles which was kind
about strategy to get home. ian
thanks to share ... really interesting ! that was close too
ggtronic is offline Find More Posts by ggtronic
Old Jul 30, 2012, 08:38 AM
toubab is offline
Find More Posts by toubab
Auxerre - France
toubab's Avatar
France, Bourgogne, Auxerre
Joined Dec 2011
don't just balance it for the video - the vibrations will ruin every part of the plane if you leave them. the motor will have the most problems and will have a drastically decreased lifespan. ask me how i know
https://vimeo.com/27719317
Very good job !!!
toubab is offline Find More Posts by toubab
Old Jul 30, 2012, 12:25 PM
rsowder is offline
rsowder's Avatar
San Francisco
Joined May 2009
ian
Very cool. Suspenseful ending. I'll try and watch your next flight live.
Randy
Old Jul 30, 2012, 06:03 PM
Watts up ?
Joined Nov 2006
Retract lessons.
Im really keen on seeing more information as a RG might work well for my purposes but I am yet to start my X8
Old Jul 31, 2012, 02:30 AM
deTonaTor_NZ is offline
Find More Posts by deTonaTor_NZ
Religion= suffering/wars
deTonaTor_NZ's Avatar
Joined Jan 2006
Ok guys, here's my almost finished self contained catapult launcher for the X8. It's designed to be put in a shoulder bag for hiking to remote places. The middle section comes out and the legs pull out.
Yet to test it out, got 17-25kgs of pull from 2-3 bungees 800mm long, that I use for my big composite glider. Fingers crossed!
deTonaTor_NZ is offline Find More Posts by deTonaTor_NZ
Old Jul 31, 2012, 04:37 AM
Imagecatcher is offline
Find More Posts by Imagecatcher
Imagecatcher's Avatar
NSW Australia
Joined Mar 2010
Very interested in the outcome of this.
Imagecatcher is offline Find More Posts by Imagecatcher
Old Jul 31, 2012, 04:52 AM
Gusisin is offline
Gusisin's Avatar
Joined May 2012
I am happy to provide any help you might need but my advice wait until I get it off the ground and back safe on the wheels hahahahahahahaha.
Old Jul 31, 2012, 09:44 PM
htran is offline
Find More Posts by htran
Joined Jan 2011
Ian is this with the BEVRC supplied motor? My X8 with the BEVRC motor and ESC bundle feels so under powered. Max airspeed was only about 30 knots.
Only drawing about 25A with 4S WOT with 12x6 Aeronaut folding props. The supplied ESC is supposed to by 70A but it doesn't look big enough to handle 70A.
My ZII does 60A with 4S WOT with Aeronaut 9x6 and does about 90 knots.
Originally Posted by Ian Davidson View Post
Just throwing this out there to anyone who finds this of interest/help.
No thrust or pitch-speed data below I know, but I measured this yesterday using the optional motor supplied by BevRC for the X8, paired with a range of Aeronaut CAM folding props on a 3S set-up.
(I'm scratching my head slightly with the 13x11 and 13x10 comparison. I noted the exact same oddity though when comparing these props on a Scorpion motor.)
htran is offline Find More Posts by htran
Old Jul 31, 2012, 09:48 PM
Watts up ?
Joined Nov 2006
You first
New Product X8---new 2.4GHz Radio System ASSAN Radios 5740 Mar 06, 2016 01:21 PM
For Sale Assan 2.4 ghz X8 6ch receiver Brand New Scooter33 Aircraft - General - Radio Equipment (FS/W) 2 Oct 12, 2011 09:34 AM
Discussion Any info regarding this x8 setup?Better than coax x8? sjak Multirotor Talk 11 Aug 14, 2011 08:33 AM
Sold New Assan Module X8 2.4 for JR Tx norstaroption Aircraft - General - Radio Equipment (FS/W) 6 Nov 21, 2009 05:42 AM
Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 EyeFlyPlanes Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2008 02:39 AM
