Canada
Joined Jul 2009
http://www.bevrc.com/the-king-of-fly...font_p303.html
Buy a buck's worth of something and shipping is free. |
Yes, white EPO is really EPO. Remember it was white before it was black.
It's pretty thick foam, so not sure you're going to see much light coming through though. ian |
Latest blog entry: My 2012 FPV year in Review
Joined Jan 2009
good job, congratulations. I also I have a parachute system in my x8
Greece, Attica, Piraeus
Joined Jun 2004
Hi.
I have seen this video before Nice and clean job indeed. Can you describe the parachute release mechanism (any photos would be very helpful) as It looks like you are releasing the parachute from the bottom? Also what size is the parachute (diameter or periphery) and weight? Mine has a 120 inch periphery and weights 360g Chris |
Joined Apr 2005
Well my X8 is on the way to replace the ZII - really didnt like the crappy ZII foam !
so few questions: 1. does the X8 take standard size servos ? 2. you guys with retracts - how much weight do you add with electric gear ? 3. whats the distance record for an FPV X8 and with which setup ? 4. how do you guys do quick detachable mechanisms for the wings ? im planning to use a Hacker inrunner motor i have at home which is about 1600KV with 4.4 planetery gear and 12x9 folding prop on 6S 6500mAh producing about 600W at WOT. Of course im hoping for a 100W cruise. |
1. Yes
2. I've yet to see anyone with functioning retracts (meaning, they've actually taken off and landed using them). Just having installed them on the plane doesn't tell you if they'll work, thus knowing the weight of them on the plane, isn't much value, yet. 3. rsowder went over 11 miles out, and back. He's posted his setup in this thread. 4. Slide em on, tape wings to fuse.. fly.. land, remove tape, pull wings off. 1600Kv / 4.4 * 6S * 3.7 is only 8072rpm versus the 1110kv * 3S * 3.7 = 12321rpm of a typical 3S setup or 780kv * 4S * 3.7 = 11544rpm of a typical 4S setup. The point I'm making is you're running lower rpm, higher torque setup, and should probably run a larger diameter, lower pitch prop (12x9 is likely to stall at high throttle anyway). ian |
We tape the wings on 350+mph 30lb DS sailplanes, for the same reasons.
Dunno why folks are so hung up on making things more complicated and ultimately much more breakable. If you use nylon bolts, make em small ones, because anything bigger than about a 6x32 will rip your wood mounts apart (or off the wings) before they give. Tape is perfectly suited to this particular shearing force. ian |
Joined Apr 2005
i dont like tape either. mainly because it means carrying one more item (tape roll) to the field.
was thinking about high strength magnets planted into the wing ribs, or even multiplex "multilocks". http://mysite.verizon.net/vze2qbfc/id19.html |
Canada
Joined Jul 2009
I use a simple small nut and bolt to hold the wings on. The nut gets hot glued on one side (fuse side) and the bolt gets a bit of medium Loctite and goes through from the wing side. I've looped and rolled and flipped it upside down on landing and the wings don't move with this simple solution. Don't know what would happen if you fly it into a tree.
| Thread Tools | |
| New Product X8---new 2.4GHz Radio System | ASSAN | Radios | 5653 | Feb 13, 2013 05:07 PM |
| For Sale Assan 2.4 ghz X8 6ch receiver Brand New | Scooter33 | Aircraft - General - Radio Equipment (FS/W) | 2 | Oct 12, 2011 09:34 AM |
| Discussion Any info regarding this x8 setup?Better than coax x8? | sjak | Multirotor Talk | 11 | Aug 14, 2011 08:33 AM |
| Sold New Assan Module X8 2.4 for JR Tx | norstaroption | Aircraft - General - Radio Equipment (FS/W) | 6 | Nov 21, 2009 05:42 AM |
| Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 | EyeFlyPlanes | Aircraft - General - Radio Equipment (FS/W) | 0 | Oct 20, 2008 02:39 AM |
