Old Jul 23, 2012, 05:58 PM
OzparkPilot is offline
Find More Posts by OzparkPilot
Watts up ?
OzparkPilot's Avatar
Australia, NSW, Sydney
Joined Nov 2006
Originally Posted by bw459205 View Post
Hello,
Thought I'd share this...
I have fitted aluminium M3 threaded bushes into the base of my X8 as mounting points for equipment, batteries, etc.
The bushes are set into ply plates with epoxy, then these have been secured to the foam with UHU por contact adhesive.
I fell it adds a bit of strength to the lower fuse, and anything screwed into these isn't going anywhere!
Ben
Thats looks neat and clean. Does the X8 come with the Laser cut wood as in the picture ? Mine is still ons its long range flight ( shipping ) to me...
OzparkPilot is offline Find More Posts by OzparkPilot
Old Jul 24, 2012, 12:19 AM
Watts up ?
Joined Nov 2006
X8 arrived just now - The box looks like the Olympic boxing team have been using it for training but the 8 looks scratch free ! The even remembered to include my folding CF prop !Now on to the build... looks pretty easy and quick.
Quick question, anyone flying one with a dragon link as I'm keen to see how your routed the aerial please.
Old Jul 24, 2012, 01:23 AM
Watts up ?
Joined Nov 2006
X8 arrived !
Btw.. I think this may just be a very cool add on for the X8... http://www.eagletreesystems.com/guardian/index.htm
Old Jul 24, 2012, 04:10 AM
peppe_i8uza is offline
Find More Posts by peppe_i8uza
failure is not an option
Joined Jul 2012
My X8 is just arrived
any info about retracting gear and laminating?
standard power combo (for starting, of course.... ;-))
peppe_i8uza is offline Find More Posts by peppe_i8uza
Old Jul 24, 2012, 12:34 PM
Ben Cook is offline
Find More Posts by Ben Cook
UK, Hertfordshire, Hitchin
Joined Aug 2007
No the ply plates are not included in the kit. I cut those myself. I can post the templates if you want to use them.
Ben Cook is offline Find More Posts by Ben Cook
Old Jul 24, 2012, 04:43 PM
Ben Cook is offline
Joined Aug 2007
I'm putting this EMAX BL2820/07 (919kV) on mine, with a 13x7" prop. I tested it to 470 watts peak on 3S with this set-up. Should be more than adequate for 3kg AUW. As you can see, I've mounted it on anti-vibration mounts and can confirm it runs pretty quiet out of airframe.
Old Jul 25, 2012, 10:17 AM
BushmanLA is offline
Find More Posts by BushmanLA
BushmanLA's Avatar
Joined Dec 2005
Where did you get those mounts? I need something like that to get my prop outside of the recessed area.
BushmanLA is offline Find More Posts by BushmanLA
Old Jul 25, 2012, 10:23 AM
jet72 is offline
Find More Posts by jet72
Austria, Wien, Vienna
Joined Feb 2012
http://mikrokopter.altigator.com/dampening-c-58.html
http://www.quadrocopter.com/Vibratio...M3x8_p_42.html
http://www.coolmodels.gr/m3x8-vibrat...ge=en&pID=1566
http://www.elpac.de/products.php?cat...atic=0&lang=en
jet72 is offline Find More Posts by jet72
Old Jul 25, 2012, 10:24 AM
latin105fm is offline
Find More Posts by latin105fm
latin105fm's Avatar
London, UK
Joined Jan 2009
Hi there. Where did you get the anti- vibration mounts?
latin105fm is offline Find More Posts by latin105fm
Old Jul 25, 2012, 10:46 AM
Flying Tivo is offline
Find More Posts by Flying Tivo
Joined Feb 2007
Templates
Hello,
Ben
Ben:
Would you be willing to share your cutting templates for the plywood boards??
Felipe
Flying Tivo is offline Find More Posts by Flying Tivo
Old Jul 25, 2012, 01:06 PM
hendrix is offline
Find More Posts by hendrix
Greece, Attica, Piraeus
Joined Jun 2004
Here is a nice video.
Unfortunately the battery moved during opening (i was in a hurry and i used double sided tape)
and CG changed giving rise to oscillations.
It is good to know this however because the two previous openings were flawless
Of course the descent rate was low enough so no damage is done.
I wasn't able to film launching which is perfect every time because i can't launch and take video at the same time.
x8 parachute (1 min 14 sec)
SDC10910 (0 min 16 sec)
Chris
hendrix is offline Find More Posts by hendrix
Old Jul 25, 2012, 01:23 PM
Ben Cook is offline
Joined Aug 2007
http://www.youtube.com/watch?v=7WyNx...ature=youtu.be
Chris
That is excellent- WELL DONE!
Did you make the parachute?
Old Jul 25, 2012, 01:29 PM
hendrix is offline
Joined Jun 2004
It is a custom order from spherachutes, light fabric, thin lines, size 120 inch.
If you keep the plane under 3 - 3.5 Kg the 80 or 100 inch might be as good or more appropriate i would say.
Chris
Old Jul 25, 2012, 01:32 PM
Ben Cook is offline
Joined Aug 2007
I see you're in the UK too. I bought these from Maplins:
http://www.maplin.co.uk/anti-vibrati...r-mounts-43552
I coupled them with generic M3 PCB stand-offs to get a bit more 'reach' out of the fuse. It also means I can glue the bulkhead into the airframe without worrying about the screws on the inside of the bulkhead (that is to say that they will be buried). I can unscrew the anti-vibe mounts from the stand-offs without too much disruption to the installation.
Old Jul 25, 2012, 02:04 PM
i3dm is offline
Find More Posts by i3dm
RC pilot by soul
Israel
Joined Apr 2005
Guys,
Where is the best place to get a WHITE EPO X8 with intl. shipping ?
i want white so i could plant some night flying LEDs inside the wing..
i3dm is offline Find More Posts by i3dm
New Product X8---new 2.4GHz Radio System ASSAN Radios 5740 Mar 06, 2016 01:21 PM
For Sale Assan 2.4 ghz X8 6ch receiver Brand New Scooter33 Aircraft - General - Radio Equipment (FS/W) 2 Oct 12, 2011 09:34 AM
Discussion Any info regarding this x8 setup?Better than coax x8? sjak Multirotor Talk 11 Aug 14, 2011 08:33 AM
Sold New Assan Module X8 2.4 for JR Tx norstaroption Aircraft - General - Radio Equipment (FS/W) 6 Nov 21, 2009 05:42 AM
Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 EyeFlyPlanes Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2008 02:39 AM
