Old Jun 20, 2012, 05:19 AM
Coyote64 is offline
Find More Posts by Coyote64
Praying for better weather
Coyote64's Avatar
Joined Dec 2007
Originally Posted by toubab View Post
Good morning everyone !
My question is : Is it not too dangerous to trow this plane with hand ?
Fabrice
No not really, most throw it by hand
Coyote64 is offline Find More Posts by Coyote64
Old Jun 20, 2012, 05:24 AM
Ian Davidson is offline
Find More Posts by Ian Davidson
Old Blighty
Joined Apr 2010
Comment deleted: Thought I was reading a different thread
Ian Davidson is offline Find More Posts by Ian Davidson
Old Jun 20, 2012, 05:37 AM
Imagecatcher is offline
Find More Posts by Imagecatcher
Imagecatcher's Avatar
NSW Australia
Joined Mar 2010
Originally Posted by ardebee View Post
Thanks for sharing that! Do you feel you have room to install after permanently bonding the two fugelage halves together? I'm a bit nervous about doing that.
You had me worried there for a moment since I hadnt tested that obvious aspect. Pheeew! fits no problem. Even if not I could have assembled it in the nose without too much trouble. Eventually I will make a clip in box for various payloads like Thunderbirds #2
...Think I have just found the name for my X8, I bagzed it first! If I wasnt doing the silver Di-noc covering I probably do the colour scheme too
Imagecatcher is offline Find More Posts by Imagecatcher
Old Jun 20, 2012, 05:51 AM
Old Blighty
Joined Apr 2010
Ha! Yeh, it's only now I'm a little older that I wonder how DID Thunderbirds 2 ever fly with those wings!
Old Jun 20, 2012, 06:22 AM
NSW Australia
Joined Mar 2010
I was just thinking the same. Im also thinking the box tail wing is what the X8 needs. I have been doing some reading on how efficient it is.
Old Jun 20, 2012, 06:41 AM
Gusisin is offline
Find More Posts by Gusisin
Gusisin's Avatar
Joined May 2012
Originally Posted by Imagecatcher View Post
Sure it is doable. This dip of the nose was a last minute thing as I am itching to make a real start. What did you have in mind? PM sketches. I have just fibreglassed the plaster so hopefully I can pop it out on the weekend.
I would say cut back to the first partition and create a collar. The collar would be a circular receiver for the "pods". The pod could have a standard connector of some sort to just plug and play that would handle things like
Power
Video audio, pan and tilt per camera in the nose.
Voltage, ground and signal connections that the user could configure for whatever.
The collar connected to the payload by whatever method, a Velcro collar about 4 cm wide (2cm for body and 2cm for payload) going all the way around seems simple and easy to install.
Also it would mean that your investment is protected, after all most incidents that result in damage are to the nose as aircraft vaery rarely reverse into hills hehe.
I am waiting for my airframe to arrive but as soon as it does I will put some sketches up for discussion.
This way rather than have multiple x8s you could have one that is multi mission.
I am investing a lot in my base airframe with retracts autopilot etc etc so I want to be able to leverage that investment for the most fun
Gusisin is offline Find More Posts by Gusisin
Old Jun 20, 2012, 07:00 AM
toubab is offline
Find More Posts by toubab
Auxerre - France
toubab's Avatar
France, Bourgogne, Auxerre
Joined Dec 2011
Thank you for answering me !
I am a bit afraid about that !
toubab is offline Find More Posts by toubab
Old Jun 20, 2012, 01:37 PM
deTonaTor_NZ is offline
Find More Posts by deTonaTor_NZ
Religion= suffering/wars
deTonaTor_NZ's Avatar
Joined Jan 2006
Originally Posted by moti View Post
nice paint, what kind of paint you use
Sign writers vinyl, no need for messy paint!
deTonaTor_NZ is offline Find More Posts by deTonaTor_NZ
Old Jun 20, 2012, 04:56 PM
Forrest12 is offline
Find More Posts by Forrest12
DS state of origin NSW Vs QLD
Forrest12's Avatar
Joined Jul 2009
No, it didn't land in a bucket of plaster! I am casting the nose (among other bits) so I can make vacuum formed nose covers. Partly for protection, replace a totaled nose, hide fpv slot if not in use and give me a platform to work with. Such would be integrating gopros etc
SO much effort!
Hope you sell some for all that time mate.. Just hurry up and get building!...
Pete
Forrest12 is offline Find More Posts by Forrest12
Old Jun 20, 2012, 05:20 PM
toubab is offline
Auxerre - France
toubab's Avatar
Joined Dec 2011
good afternoon all !
Today I deceided to cast the bottom of my X-8 with silicone !
Then I will put some resina inside to get the shape .
My idea is to make with one layer of light fiber glass a stronger front and bottom for the hard landing !
I dont know yet if it will succed but at less I will try !
I will post more picture of all the stage soon !
Old Jun 20, 2012, 05:22 PM
martin_hrcg is offline
Find More Posts by martin_hrcg
Joined Aug 2006
Prop
All,
I went through the "Beginners Guide to Motor and Prop Selection" - http://www.rcgroups.com/forums/showthread.php?t=1136470
It and WebOCalc tell me to use large props with almost every motor I try. Most say 18x10 or so.
But I don't see anyone using props that large. I have been reading a lot, but I still don't understand why people are not using larger props and what the difference will be.
Anyone help?
Thanks in advance!
martin_hrcg is offline Find More Posts by martin_hrcg
Old Jun 20, 2012, 05:24 PM
Joined Jan 2006
The motor I bought from hobby king ( 1000kv on 4 cell) recommend using a 10x6 prop do that's what I'm starting with, will let you know this weekend how the test flight goes!
Old Jun 20, 2012, 05:28 PM
Coyote64 is offline
Coyote64's Avatar
Joined Dec 2007
Most use around a 13" prop with great results, I`m using a 16" to try get longer flight times on lower Kv.
So far the weight is too much for a 16" to launch by hand and keep amps down if full loaded, a larger prop would be a bit naughty on your fingers for hand launching IMO.
Old Jun 20, 2012, 05:58 PM
ardebee is offline
Find More Posts by ardebee
Joined May 2012
Thanks, I feel more comfortable about gluing the body together now. It looks like you are only correcting for roll with your camera mount. I'm guessing that is probably all that is needed.
Would you mind sharing what you are using to control the autolevel? I was planning to use the APM2 but I thought I read somewhere this capability wasn't available yet.
ardebee is offline Find More Posts by ardebee
Old Jun 20, 2012, 08:01 PM
Joined Aug 2006
What is your flying weight?
Are you carrying a lot of gear?
New Product X8---new 2.4GHz Radio System ASSAN Radios 5740 Mar 06, 2016 01:21 PM
For Sale Assan 2.4 ghz X8 6ch receiver Brand New Scooter33 Aircraft - General - Radio Equipment (FS/W) 2 Oct 12, 2011 09:34 AM
Discussion Any info regarding this x8 setup?Better than coax x8? sjak Multirotor Talk 11 Aug 14, 2011 08:33 AM
Sold New Assan Module X8 2.4 for JR Tx norstaroption Aircraft - General - Radio Equipment (FS/W) 6 Nov 21, 2009 05:42 AM
Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 EyeFlyPlanes Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2008 02:39 AM
