Old Jun 19, 2012, 04:40 PM
yogz is offline
Find More Posts by yogz
oxford uk
Joined Aug 2010
Way Hay!!! Another word the rc filth filter missed lol Bugger Arse!
Sorry... don't mean to offend anyone, I am just really against censorship... wouldn't use foul language myself, or expect others to either... just found some things on RCG a wee bit dogmatic on occasion..
P
yogz is offline Find More Posts by yogz
Old Jun 19, 2012, 04:57 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
It occurs to me that there is an easier way to hinge the canopy that requires no cutting at all.
Many have heard of a "tension hinge" or as some call it an "over/under hinge".
It's usually used on control surfaces hinges, sometimes as the only hinging method, sometimes
as a supplement to traditional full length tape hinges. With EPO foam hinges, I often
just cut a little slit at either end, and add a set of tension hinges, while retaining the foam hinges
everywhere else.
What many don't realize is that a set of tension hinges can hinge pretty much any shape to
any other. pointed to round, round to square, square to square.. etc.
A set of three tension hinges, each about an inch wide, can hinge the front of the X8 canopy to
the fuse. I just tested it, and it works quite well. The tape needs a little stretch to handle
the curve in the fuse (clear hockey tape is a good match), but it makes for a tight hinge with
very little moving resistance. Is also aerodynamically clean.
ian
Daemon is offline Find More Posts by Daemon
Old Jun 19, 2012, 05:35 PM
Gusisin is offline
Find More Posts by Gusisin
Gusisin's Avatar
Joined May 2012
Originally Posted by ardebee View Post
That's great and very resourcefull, thanks! Appreciate your taking time from your busy day. :-)
Could I use an accelerometer to give me an indication of the angle?
If you are using the arduino use a potentiometer with 5v running through it and read it as an analog I put you can code then for different angles. Bet to keep it as simple as possible. Obviously choose a pot maybe 10k that is free to rotate.
Gusisin is offline Find More Posts by Gusisin
Old Jun 19, 2012, 05:36 PM
Gusisin is offline
Gusisin's Avatar
Joined May 2012
I forgot to say pot the pot at the junction of the vane and the pivot in my little video.
Old Jun 19, 2012, 05:44 PM
johnorama is offline
Find More Posts by johnorama
UAV Dude KF7HYV
johnorama's Avatar
United States, NV, Silver Springs
Joined Mar 2007
Originally Posted by Daemon View Post
Of course nothing is absolute, but if your preset auto-pilot speed is set for max efficiency (which
is generally just a tick above stall speed), then it will not be happy trying to maintain
a speed based off GPS input, in a tailwind.
All that other advice is swell, except that auto-pilots generally just don't think that way, which
is why they can create problems. They first apply pitch inputs to change or maintain
altitude, and then change throttle to maintain a pre-set airspeed. It can stall the plane
in the response lag between the two actions.
ian
It looks that we are saying a similar message. My initial reply was to counter your statement that "any autopilot that can control the throttle, must have true airspeed as its speed input and not GPS speed (ground speed), or it will cause stalls any time it flies downwind", and I believe your follow-up clarified that it is not 100% true.
My second point may have not been clear enough. These autopilots control loops are designed incorrectly and therefore it is nearly impossible to setup the aircraft for max efficiency when the throttle surges with every bit of turbulence the plane hits.
johnorama is offline Find More Posts by johnorama
Site Sponsor
Old Jun 19, 2012, 05:46 PM
UAV Dude KF7HYV
johnorama's Avatar
Joined Mar 2007
ian
That's awesome. I have a number of canopies I am going to try this out on. Thanks!
Site Sponsor
Old Jun 19, 2012, 06:11 PM
vertcnc is offline
Find More Posts by vertcnc
Illinois, USA
Joined Aug 2009
everywhere else.
ian
I never tried a tension type hidge. pardon my ignorance. How is one sided tape stuck down on both surfaces? What am I missing?
vertcnc is offline Find More Posts by vertcnc
Old Jun 19, 2012, 06:32 PM
idletime is offline
Find More Posts by idletime
idletime's Avatar
Canada, ON, Toronto
Joined Apr 2011
Let me see if I can explain....one strip is right-side up...the other is upside-down. This allows the sticky side to stick to the top (outside of the canopy) and the other strip is up-side down...so it can stick to the inside of the fuse.
Where they meet, the sticky side of both strips go together....think of when you shake someones hand...both palms go together.
Hope that helps.
idletime is offline Find More Posts by idletime
Old Jun 19, 2012, 06:35 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Two strips of tape, stuck face to face for only a short distance (1/4-1/2"). Now one end of
the longer strip has sticky side up, the other sticky side down. Thread it through the hinge line
and stick each side to it's respective surface. Reverse the direction on the next
strip over, repeat.. They're great for repairing regular control surface hinges in the field.
You can slit the original tape or foam, just long enough to fit two tension hinges side by
side. Thread em through, pull tight (under tension) so the surface is lined up,
stick and done. If hinging an entire surface with em, you might use em in pairs, spaced
every couple inches, or just three sets of three. (set at either end, and one near the
control horn).
ian
Old Jun 19, 2012, 06:49 PM
vertcnc is offline
Illinois, USA
Joined Aug 2009
Ok, got it. Just didn't realize they were made from 2 pieces. Thanks for the explanation.
Old Jun 19, 2012, 09:10 PM
ardebee is offline
Find More Posts by ardebee
Joined May 2012
That makes sense. Much simpler to use a potentiometer. Although I'm still interested in your differential pressure approach. Thanks for the info.
ardebee is offline Find More Posts by ardebee
Old Jun 20, 2012, 05:06 AM
toubab is offline
Find More Posts by toubab
Auxerre - France
toubab's Avatar
France, Bourgogne, Auxerre
Joined Dec 2011
Good morning everyone !
My question is : Is it not too dangerous to trow this plane with hand ?
Fabrice
toubab is offline Find More Posts by toubab
Imagecatcher is offline
Find More Posts by Imagecatcher
Imagecatcher's Avatar
NSW Australia
Joined Mar 2010
Image catcher you read my mind. I want to build a mould for "pods" that can be interchanged. Standard connectors to the standard stuff in the main fuse and special mission cams and equipment in the nose, do you think this is doable ?
Sure it is doable. This dip of the nose was a last minute thing as I am itching to make a real start. What did you have in mind? PM sketches. I have just fibreglassed the plaster so hopefully I can pop it out on the weekend.
Imagecatcher is offline Find More Posts by Imagecatcher
Old Jun 20, 2012, 05:07 AM
NSW Australia
Joined Mar 2010
Depending on your programming skills the ardupilot will allow you to add a couple of static sensors one on top and one below with a bit of coding you could have a stall warning on the OSD hehe. The static sensors would connect to the ic2 port
I'd be really interested in that. I have the APM air sensor.
Old Jun 20, 2012, 05:18 AM
NSW Australia
Joined Mar 2010
cool idea Yogz
New Product X8---new 2.4GHz Radio System ASSAN Radios 5743 Sep 01, 2016 11:51 AM
For Sale Assan 2.4 ghz X8 6ch receiver Brand New Scooter33 Aircraft - General - Radio Equipment (FS/W) 2 Oct 12, 2011 09:34 AM
Discussion Any info regarding this x8 setup?Better than coax x8? sjak Multirotor Talk 11 Aug 14, 2011 08:33 AM
Sold New Assan Module X8 2.4 for JR Tx norstaroption Aircraft - General - Radio Equipment (FS/W) 6 Nov 21, 2009 05:42 AM
Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 EyeFlyPlanes Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2008 02:39 AM
