Old May 23, 2012, 12:16 PM
guytzoler is offline
Find More Posts by guytzoler
Israel, Adi
Joined May 2006
Guys thanks a lot for your help i will finish my order ... finaly thanks
guytzoler is offline Find More Posts by guytzoler
Old May 23, 2012, 12:57 PM
King Haggis is offline
Find More Posts by King Haggis
Joined Aug 2011
A few weeks ago, I asked a RC model webshop owner for advice which servos to use for the X8 and he recommended and sold me these:
Robbe S3001
Are they good enough for the X8? I was planning on using them but seeing people in this thread are recommending 4.5kg+ I don't think these are good enough after all... All I can find on internet about these S3001's is that they are 45grams, 2.4kg @ 4.8v and 3kg @ 6v and size is 40,4x19,8x36mm. I'm not very experienced at modelbuilding. Should I return these servos?
If I swap them for stronger servos, should I keep this size or do they also need to be bigger or smaller? Thanks!
King Haggis is offline Find More Posts by King Haggis
Old May 23, 2012, 01:36 PM
Niels Erik is offline
Find More Posts by Niels Erik
Sorry-I am from Denmark !!
Niels Erik's Avatar
Danmark, Lolland, Søllested
Joined Nov 2010
Robbe S3001
Regards what people write, i do fly with these:
http://www.hobbyking.com/hobbyking/s...dProduct=14458
And iam not falling out of the sky Only trouble so far was a pushrod falling of-And i landed with a flatspin The servo gives me the power i need-But iam not flying fast at all-Max 80 kph
Niels Erik is offline Find More Posts by Niels Erik
Old May 23, 2012, 02:11 PM
jet72 is offline
Find More Posts by jet72
Austria, Wien, Vienna
Joined Feb 2012
Robbe S3001
NO!
they are standard servos and slow !
buy digital servos, metal gear, min. 2 ballbearings, <0.2sec, 4-5kg+
http://www.hobbyking.com/hobbyking/s...dproduct=19810
jet72 is offline Find More Posts by jet72
Old May 23, 2012, 02:32 PM
Coyote64 is offline
Find More Posts by Coyote64
Praying for better weather
Coyote64's Avatar
Joined Dec 2007
Just before I maiden mine I thought I had better watt test my motor prop, I was surprised, according to eCalc I had the best config to get max ( 670 watts ) from my motor
Motor : Turnigy SK 3542 100KV
Prop : 11x6 ( as recommended by eCalc )
Watts : 528
Over 100 watts down on eCalc prediction and my hopes
I tried a few others
Prop : 14x8
Watts : 850w @ 62 Amps
That`s more like it, but way too high for my 670w motor
Prop : 12x8.5
Watts : 622w
Better but a bit more would be nice
I`m thinking 13x7 should give me a bit more ?
Waiting on the Power Up 32 with 800 watts, but I ordered it weeks ago and no show so far
Coyote64 is offline Find More Posts by Coyote64
Old May 23, 2012, 02:54 PM
BushmanLA is offline
Find More Posts by BushmanLA
BushmanLA's Avatar
Joined Dec 2005
Meh, you should be able to launch pretty easy with 500 Watts.
BushmanLA is offline Find More Posts by BushmanLA
Old May 23, 2012, 02:57 PM
crazy1pilot is offline
Find More Posts by crazy1pilot
What goes up, must come down
crazy1pilot's Avatar
United States, MI, Midland
Joined Sep 2009
I would go with the
Prop: 12x8.5
Watts: 622
No need to over work the motor, as it is now, the X8 has a hard time keeping the motor cool.
Crazy1
crazy1pilot is offline Find More Posts by crazy1pilot
Old May 23, 2012, 03:26 PM
Forrest12 is offline
Find More Posts by Forrest12
DS state of origin NSW Vs QLD
Forrest12's Avatar
Joined Jul 2009
Right guys
Im going to try and save everyone some money here.
If you want the most efficient 4S set up here it is.
Ive tested 6 types of 3542 motors ranging from 500kv up to 1100kv and by far this has the best power to economy ratio.
http://www.hobbyking.com/hobbyking/s...ner_830KV.html
running a 13 X 6.5 folding aeronaught prop. 42mm prop center.
Im running a 100amp speedie to be safe but 80amps would be plenty. As at max throttle it pulled 48amps
This set up will launch up 24000mah of 4S and also have a cruise of 8-9 amps with 8000 mah of batteries on board. Approx 40 mins flight time
Ive bought from this motor up to Tiger motors and then up to scorpion motors in this test. So ive spent quite alot of money . Dont try and re invent the wheel this works. Its your decision if you take the advice or not. Motor runs cool even at full throttle bench tests. Speedie also ran just warm on the bench.
Pete
Forrest12 is offline Find More Posts by Forrest12
Old May 23, 2012, 03:39 PM
Ian Davidson is offline
Find More Posts by Ian Davidson
Old Blighty
Joined Apr 2010
When you say economical, do you mean efficient?
Ian Davidson is offline Find More Posts by Ian Davidson
Old May 23, 2012, 03:42 PM
Forrest12's Avatar
Joined Jul 2009
yes
Old May 23, 2012, 03:55 PM
Old Blighty
Joined Apr 2010
Would love for you to try your 830kv motor on 3S with a 14x10 prop and report back. My feeling is it would offer very compatible performance, but be even more efficient still.
Old May 23, 2012, 04:04 PM
Forrest12's Avatar
Joined Jul 2009
Maybe
Ian , My post was simply to help people out with an "efficient" start. Ive spent over $500 on motors on this bird and thats alot of money to have a bunch of spare motors that I may not use again. There was no useable motor info when i got my first X8 in February.
This motor truely is amazing for the price. Quiet, tight, smooth, efficient, cheap! It ticked all the boxes.
Old May 23, 2012, 04:07 PM
Old Blighty
Joined Apr 2010
Originally Posted by Forrest12 View Post
Maybe
Indeed - I agree! I think it sounds like a great X8 motor, for 3S or 4S. I appreciate you having gone to all the effort (and cost) to find it.
Old May 23, 2012, 05:07 PM
Flying Tivo is offline
Find More Posts by Flying Tivo
Joined Feb 2007
Im planing on using Rimfire .32 42-50-800, a little on the heavy side 198grms, with a 13x8.
Maybe a 14x9 for 587watts for a static thrust of 3331. grms. This is well in range of the max watts for this motor 1480. I feel this will give a nice launch thrust and a very efficient cruise.
Please let me know what you all think!
Felipe
Flying Tivo is offline Find More Posts by Flying Tivo
Old May 23, 2012, 05:09 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
While it sounds like a good deal for 4S, I think it's too low kv for 3S.
ian
Daemon is offline Find More Posts by Daemon
New Product X8---new 2.4GHz Radio System ASSAN Radios 5740 Mar 06, 2016 01:21 PM
For Sale Assan 2.4 ghz X8 6ch receiver Brand New Scooter33 Aircraft - General - Radio Equipment (FS/W) 2 Oct 12, 2011 09:34 AM
Discussion Any info regarding this x8 setup?Better than coax x8? sjak Multirotor Talk 11 Aug 14, 2011 08:33 AM
Sold New Assan Module X8 2.4 for JR Tx norstaroption Aircraft - General - Radio Equipment (FS/W) 6 Nov 21, 2009 05:42 AM
Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 EyeFlyPlanes Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2008 02:39 AM
