Old Mar 15, 2012, 10:26 AM
RolandS888 is offline
Find More Posts by RolandS888
Outta Sight
Australia, WA, Joondalup
Joined Jul 2008
Angelos, what prop size are you running on that?
RolandS888 is offline Find More Posts by RolandS888
Old Mar 15, 2012, 11:09 AM
rcmonster99 is offline
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
Originally Posted by Angelos View Post
Here is the maiden of the X8. It's not me swearing at the end (thanks Yogz for sound effects) and the plane landed safely 50 or so meters further down.
The motor is an A3732 KV480 running from 6S with 80A ESC. (The data on the video are a bit wrong.)
http://www.youtube.com/watch?v=Bx7KWibSWoo
The rudder worked but not as effective as I was hopping. As I like my planes agile I would be happier if it had twice as much authority and I may try increasing the size of the elevons. Still it may be enough to achieve it's ultimate purpose and I will re-evaluate it whist FPV.
I can't conclude how defective the crow airbrake was but I noticed the aileron and elevator controls lost some authority when the airbrake was on, possibly around 30%.
-Angelos
Nicely done Angelos.... can't wait to hear your opinions on your first fpv flight but it looks like you got this plane pretty well sorted already...
rcmonster99 is offline Find More Posts by rcmonster99
Old Mar 15, 2012, 12:11 PM
Ian Davidson is offline
Find More Posts by Ian Davidson
Old Blighty
Joined Apr 2010
I've always thought this was an interesting motor for a 6S set-up. Pretty lightweight for its power and Kv rating
http://www.hobbyking.com/hobbyking/s...dProduct=14740
Ian Davidson is offline Find More Posts by Ian Davidson
Old Mar 15, 2012, 01:20 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Would a three blade folding prop benefit much?
http://www.hobbyking.com/hobbyking/s...dproduct=21878
smaller diameter prop; more 'grip' maybe
boredom.is.me is offline Find More Posts by boredom.is.me
Old Mar 15, 2012, 01:23 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Folding props are already hard enough to balance, without trying to deal with a 3 blader.
ian
Daemon is online now Find More Posts by Daemon
Old Mar 15, 2012, 01:45 PM
Wayno Complaino is offline
Find More Posts by Wayno Complaino
Fixed wings can be Drones too!
Wayno Complaino's Avatar
Joined Aug 2011
Where would the the bladder 'go' on landing? Wouldn't it always drag (and get damaged) ?
Wayno Complaino is offline Find More Posts by Wayno Complaino
Old Mar 15, 2012, 01:54 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Huh? That's the point of a folding prop.
ian
Old Mar 15, 2012, 03:48 PM
Joined Aug 2011
Sorry, missed the folding bit, doh! Never seen a three blade folding prop...
Old Mar 15, 2012, 04:04 PM
Angelos is offline
Find More Posts by Angelos
Angelos's Avatar
Didcot, UK, OX11
Joined Sep 2003
14*10 aeronaut camcarbon folder. It is VERY quiet, more so than it appears on the video (and it's not that loud on there!)
HOWEVER that was a los maiden, no FPV gear on board, so we cannot as yet verify that it is loading the motor correctly. Angelos is at this moment installing the rest of the kit so he will report back asap (maybe tomorrow)
Paul (Yogz) @ Spartan hq on Angelos' PC
Angelos is offline Find More Posts by Angelos
Old Mar 15, 2012, 05:24 PM
jet72 is offline
Find More Posts by jet72
Austria, Wien, Vienna
Joined Feb 2012
http://www.hobbyking.com/hobbyking/s...dProduct=21878
jet72 is offline Find More Posts by jet72
Old Mar 15, 2012, 05:49 PM
zaguruinzasky is offline
Find More Posts by zaguruinzasky
Smoke on , go !
zaguruinzasky's Avatar
Verona - Italy
Joined Jan 2007
Or these if you want top quality http://www.aero-naut.de/en/products/...cessories.html
zaguruinzasky is offline Find More Posts by zaguruinzasky
Old Mar 15, 2012, 06:56 PM
Joined Nov 2007
Originally Posted by zaguruinzasky View Post
Even though they cost a lot more, I'll take those over HK any day. I can't wait to start an X8.
Old Mar 15, 2012, 08:09 PM
ASB32 is offline
Find More Posts by ASB32
hmph!
ASB32's Avatar
United States, UT, Logan
Joined Dec 2008
Originally Posted by geives1 View Post
what about using something like this for take off? Looks easy enough to build and seems to work great for powered sailplanes.
http://www.youtube.com/watch?v=Kx5AToRmcV8
I've been messing with a cart for launching a plane with a pusher prop. The problem is that the plane accelerates once it has lift and the cart slows down. This can result in some undesirable cart to prop interaction.
ASB32 is offline Find More Posts by ASB32
Old Mar 15, 2012, 11:02 PM
jschall is offline
Find More Posts by jschall
United States, CA, Chico
Joined Aug 2010
So, I made a separate thread in the flying wing section, but I decided I should ask these here:
Most layouts I see have the (3s or 4s) batteries mounted in front, with long cables to the esc/motor. This seems to be a problem because:
A. I'm guessing making a foot and a half cable run to carry 60+ amps DC from the battery to the motor is going to lose a lot of energy to the voltage drop. I don't know how much.
B. The cables (carrying large DC amperages) would have to run very close past ArduPilot magnetometer (compass), which is definitely going to cause problems.
I don't see a way around mounting the batteries in the front, because I have nothing else heavy to put in the front to balance the plane that won't be deadweight.
One possible solution is to use higher voltages. So, using a 6s or 8s system, for efficiency rather than speed and power. However, I don't understand the prop/motor/speed/thrust/voltage/power relationship very well, so I was wondering how this can be done, specifically?
My other question is regarding landing gear. I fly off a runway primarily, and there's no foam-friendly grass nearby (mostly fields of star thistle.) So, how doable are retracts?
It's also important to me that the plane is relatively resistant to flipping or tipping over in wind while rolling, so I think the possible layouts of retracts are important to that concern...
jschall is offline Find More Posts by jschall
Old Mar 15, 2012, 11:17 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
You're overthinking it. The voltage drop for a 1 foot long 12V DC run at 65Amps over
10-12Gauge copper wire is 1.1-1.8%, or at most 0.2V. Straight DC wires shouldn't
be generating a magnetic field.
ian
New Product X8---new 2.4GHz Radio System ASSAN Radios 5740 Mar 06, 2016 01:21 PM
For Sale Assan 2.4 ghz X8 6ch receiver Brand New Scooter33 Aircraft - General - Radio Equipment (FS/W) 2 Oct 12, 2011 09:34 AM
Discussion Any info regarding this x8 setup?Better than coax x8? sjak Multirotor Talk 11 Aug 14, 2011 08:33 AM
Sold New Assan Module X8 2.4 for JR Tx norstaroption Aircraft - General - Radio Equipment (FS/W) 6 Nov 21, 2009 05:42 AM
Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 EyeFlyPlanes Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2008 02:39 AM
