Old Mar 09, 2012, 10:03 AM
crd
Breath and take it all
crd's Avatar
United States, FL
Joined Nov 2006
Is that a UFO on mark 0:57?
Originally Posted by Daemon View Post
Here's a fairly methodical X8 flight with telemetry, demonstrating the power required
for various modes. Min sink, 35mph, 45mph, max climb, top speed.. etc.
http://www.youtube.com/watch?v=EPv9cPWpVf0
News heli was orbiting around the area in the first part of the video. I didn't
spot anything interesting on the highway for em, so assume they were watching me.
It was so brutally slow to overlay the OSD info that way, that I missed the hard cuts,
so the video feels a little raw. Oh, and keep in mind that my X8 is a bit battered
and has flight camera, video Tx and antenna all outside the fuse so should be able
to make an X8 more efficient than this. My guess is with a clean one, cruise level
at maybe 6.5A (3S pack).
ian
crd is offline Find More Posts by crd
Old Mar 09, 2012, 10:05 AM
Norway
Joined Aug 2011
"News heli was orbiting around the area in the first part of the video. I didn't
spot anything interesting on the highway for em, so assume they were watching me."
Bauf is offline Find More Posts by Bauf
Old Mar 09, 2012, 10:56 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Can hear the heli before launch and see it in the distance 5 or 6 times in the first 5 mins.
They orbited the area several times.
ian
Daemon is online now Find More Posts by Daemon
Latest blog entry: My 2012 FPV year in Review
Old Mar 09, 2012, 11:22 AM
Old Blighty
Joined Apr 2010
I have no doubt posting this will cause more debate than it's worth, but below is spreadsheet calculator I put together a while back and that I use. Once you've done a few test flights to plug in the initial figures, it can pretty accurately predict what the maximum range your plane will do at a given powered speed, with a given battery capacity.
Anyway, the default values plugged in are ones I've garnered from Ian's last flight video.
Play with the battery capacity (C:13) and Flight Speed (E:14) cells and see how these affect the 'Current', 'Flight Duration' and 'Max Range' cells
http://dl.dropbox.com/u/267254/Forum...htRange-X8.xls
Ian Davidson is offline Find More Posts by Ian Davidson
Old Mar 09, 2012, 12:49 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Something doesn't seem to add up. You have C12 current (stall speed) listed as 1.7A/h.
That's not possible. If I set it to anything realistic (7-8A) then the range drops to nothing.
BTW, amp/h is not a unit we ever use. A is instantaneous current. A*h is unit of capacity.
If you look at the instantaneous mWh/km value in the OSD, can use it to calculate expected range
(which it does on the fly as well, based on the pre-set battery capacity, which was 4000mAh for this flight,
even though I was using a 5000mAh battery).
It's affected by wind and current battery voltage, but I think at 35mph with my plane (not as slippery as it could be) it is
conservatively somewhere around 1600-1800mWh/km.
A 3S 5000Ah battery contains roughly 55500mW*h of power (depends on what you choose for nominal voltage).
Therefore 55500mW / 1800mWh/km = 30.8_km or about 19 miles. At 1600mWh/km it'd be about 21 miles.
Probably eek out a few more miles at min sink airspeed.
ian
Old Mar 09, 2012, 01:19 PM
Old Blighty
Joined Apr 2010
Yup, valid point on units of current - changed.
The spreadsheet was something I compiled a while back for a big-winged Easy Star I had; a plane I could fly and work out some of the real data for. In the case of the X8, I don't have one to fly yet, but based on the calculated stall speed (17.7 mph) I simply back-calculated the stall speed current from some of the data in your video e.g. 10A @ 30 MPH (or whatever it was)
Anyway, based on your video, if you just leave the stall speed as 1.7A (be this right or wrong) all the other calculations should follow suit and be pretty accurate for your X8 - enabling the effect of changing flight-speed and battery capacity to be seen on current draw and flight range.
Old Mar 10, 2012, 06:00 AM
Joined Mar 2012
long endurance flight : WING X8
flight time 1hour 25 minutes !!
2x 5000mAh Nano Tech Lipos
3548/790 KV Turnigy
80A Turnigy
IISI Telemetrie
MY WING X8:
campilot is offline Find More Posts by campilot
Old Mar 10, 2012, 06:35 AM
Psionic001's Avatar
Australia, NSW, Sydney
Joined Apr 2006
She looks nice in Black.
3548/790 KV Turnigy
80A Turnigy
IISI Telemetrie
Psionic001 is offline Find More Posts by Psionic001
Old Mar 10, 2012, 06:49 AM
Old Blighty
Joined Apr 2010
3548/790 KV Turnigy
80A Turnigy
IISI Telemetrie
Fantastic! 4S, or 3S with a large prop? What size prop were you using?
Old Mar 10, 2012, 07:12 AM
Norway
Joined Aug 2011
love the look of that x8, im also interested in cell number
Old Mar 10, 2012, 07:53 AM
Outta Sight
Australia, WA, Perth
Joined Jul 2008
Nicely done CamPilot. It does look good in black.
I too am interested to know the prop and cell count.
RolandS888 is offline Find More Posts by RolandS888
Old Mar 10, 2012, 08:21 AM
Sorry-I am from Denmark !!
Niels Erik's Avatar
Danmark, Lolland, Søllested
Joined Nov 2010
I dont have a X8 yet-I preordred one, but all the hardware are in the house
I have a 3548 900 kv, a 12*6 foldable prop, 4s 5000 lipos (a lot off them) And a 70A opto bec
Niels Erik is offline Find More Posts by Niels Erik
Old Mar 10, 2012, 09:17 AM
Austria, Wien, Vienna
Joined Feb 2012
cam-pilot´s setup:
4s 5000mah
prop.: 11x8
motor: 600W/790kv
BTW....he´s one of the best RC Pilots in Austria
jet72 is offline Find More Posts by jet72
Old Mar 10, 2012, 09:38 AM
Norway
Joined Aug 2011
damn, he got 1h 25m from a 5Ah? thats pretty nice.. guess i dont need to use both my 5Ah batteries then
Old Mar 10, 2012, 09:40 AM
Russian Federation, Nizhegorodskaya oblast, Nizhny Novgorod
Joined Feb 2012
[QUOTE=campilot;20992120]long endurance flight : WING X8
3548/790 KV Turnigy
80A Turnigy
IISI Telemetrie
This is a super, great flight. I have the same battery and engine, propeller only 12/8
Description: Name: DSC00987.jpg
Description: Name: DSC00991.jpg
Description: Name: DSC00995.jpg
Description:
nedz is offline Find More Posts by nedz
New Product X8---new 2.4GHz Radio System ASSAN Radios 5662 Yesterday 10:51 AM
For Sale Assan 2.4 ghz X8 6ch receiver Brand New Scooter33 Aircraft - General - Radio Equipment (FS/W) 2 Oct 12, 2011 09:34 AM
Discussion Any info regarding this x8 setup?Better than coax x8? sjak Multirotor Talk 11 Aug 14, 2011 08:33 AM
Sold New Assan Module X8 2.4 for JR Tx norstaroption Aircraft - General - Radio Equipment (FS/W) 6 Nov 21, 2009 05:42 AM
Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 EyeFlyPlanes Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2008 02:39 AM
