Old Mar 06, 2012, 01:18 PM
Opt is offline
Opt
Find More Posts by Opt
Opt
New Zealand, Auckland
Joined Oct 2010
This is an average photo of my average equipment layout
I think the video transmitter is too close to the batteries in the front as i get drop outs when the batteries are in the way when turning. I dont want to bother mounting the vtx on the wing if i can help it, any ideas?
Just bank left at distance? haha
Opt is offline Find More Posts by Opt
Old Mar 06, 2012, 01:56 PM
philthyy is offline
Find More Posts by philthyy
UAV Integrations
United States, WA, Battle Ground
Joined Nov 2005
Opt, what antennas are you using? You shouldn't get drop outs when turning if you run CP antennas. (unless the batteries are RIGHT next to the antenna...)
philthyy is offline Find More Posts by philthyy
heinduplessis is offline
Find More Posts by heinduplessis
Foam Snow
South Africa, WC, Cape Town
Joined Aug 2011
Originally Posted by argo-2 View Post
Anyone tried reverse-thrust? Works pretty well on my AXN CloudsFly e-glider. Only change required is to re-program the ESC (can only do with certain brands of ESC though).
That does not sound like a bad idea!? C'mon Ian, tell us why not ;P
heinduplessis is offline Find More Posts by heinduplessis
Old Mar 06, 2012, 01:59 PM
NDw is offline
NDw
Find More Posts by NDw
NDw
Ireland, Limerick, Kilmallock
Joined Aug 2010
Car escs do have reverse
NDw is offline Find More Posts by NDw
Old Mar 06, 2012, 02:10 PM
Opt is offline
Opt
Opt
Joined Oct 2010
cloverleaf vTx, stock whip vRx
I only had one drop out at about 600m away when i was banking right to come back to me. I'm fairly sure at that point the batteries would have been right between the antennas
Old Mar 06, 2012, 02:55 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Stock whip on vRx is always sub-optimal.
ian
Daemon is offline Find More Posts by Daemon
Old Mar 06, 2012, 03:16 PM
Opt is offline
Opt
Opt
Joined Oct 2010
I'm intending to build an SPW next, I didnt think this would really help with the batteries being in the way though. Does CP penetrate lipos?
The switch to the CL antenna was an improvement though, even if it is not very well made!
I'm using 2510mhz btw
Old Mar 06, 2012, 03:24 PM
NDw is offline
NDw
NDw
Joined Aug 2010
Couldn't you use an extenson and mount just the antenna further out on the wing? Rather than the vtx too.
Old Mar 06, 2012, 03:31 PM
philthyy is offline
UAV Integrations
Joined Nov 2005
CP will not penetrate batteries. It is just the polarization, not the frequency that changes. CP helps with dB loss when banking (essentially eliminates it). Once you go CP on BOTH the Vtx and the Vrx, you should notice a better signal when banking. But yeah, I would still mount the Vtx antenna up higher, or better yet, farther out on the wing, away from the batteries.
Old Mar 06, 2012, 03:43 PM
Niels Erik is offline
Find More Posts by Niels Erik
Sorry-I am from Denmark !!
Niels Erik's Avatar
Danmark, Lolland, Søllested
Joined Nov 2010
What about using a normal propeller, and dont use brake on the esc?
Then the propeller will run free, and work as a brake, when the power to the motor are cut??
Ore just let the motor run slow ,acting as a brake, when comming in for a landing-And cut about ½ meter off the ground?
Can it work??
Niels Erik is offline Find More Posts by Niels Erik
Old Mar 06, 2012, 03:53 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
While a freewheeling prop might provide some useful braking, it's generally a bad idea to have
a spinning prop when you touch down. A stationary prop (even non-folding) will tend to just sort
of squirt out of the way when touches the ground, but a spinning prop has enough momentum
to drive a tip into the ground and then snap as the plane continues forward.
My ESC will freewheel with the throttle just above zero, and brake at zero, so maybe I'll see
if it'll help with the initial descent into the LZ and then turn brake on while in ground effect.
ian
Old Mar 06, 2012, 04:49 PM
Niels Erik's Avatar
Joined Nov 2010
ian
Looking forward to read about your test of the "freewheeling brake"
Old Mar 06, 2012, 05:18 PM
Funky Diver is offline
Find More Posts by Funky Diver
Look Sideways at Polarisation
Funky Diver's Avatar
United Kingdom, England, Darlington
Joined Jun 2011
Why not just add an pop up air brake, it doesn't have to be anything too radical, or even glider style airbrakes?
A sheet of balsa on a servo would be enough surely? There's plenty real estate for it to be added either top or bottom (obviously top would be more sensible for landing)
Funky Diver is offline Find More Posts by Funky Diver
Old Mar 06, 2012, 06:31 PM
vertcnc is offline
Find More Posts by vertcnc
Illinois, USA
Joined Aug 2009
X8 just about ready for maiden. Waiting on weather.
Name: X8 resize1.jpg
Description: X8Name: X8 resize2.jpg
Description: X* with Nav Lights
vertcnc is offline Find More Posts by vertcnc
Old Mar 06, 2012, 06:38 PM
helichoper is offline
Find More Posts by helichoper
helichoper's Avatar
Australia, SA, Adelaide
Joined Nov 2006
Nice visible colors vertcnc good job--good luck with the maiden don't forget the video
helichoper is offline Find More Posts by helichoper
New Product X8---new 2.4GHz Radio System ASSAN Radios 5740 Mar 06, 2016 01:21 PM
For Sale Assan 2.4 ghz X8 6ch receiver Brand New Scooter33 Aircraft - General - Radio Equipment (FS/W) 2 Oct 12, 2011 09:34 AM
Discussion Any info regarding this x8 setup?Better than coax x8? sjak Multirotor Talk 11 Aug 14, 2011 08:33 AM
Sold New Assan Module X8 2.4 for JR Tx norstaroption Aircraft - General - Radio Equipment (FS/W) 6 Nov 21, 2009 05:42 AM
Sold New - 4 (Four) ASSAN X8 R6 6Ch 2.4GHz Receivers - $105 EyeFlyPlanes Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2008 02:39 AM
