Old Apr 20, 2012, 08:27 PM
Dangaras is offline
Find More Posts by Dangaras
Dont be divided from the truth
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
Originally Posted by IndyMatt View Post
I have been after the HobbyLobby 4 blader for my PZ P47 and they have been out of stock forever as well. What about the Master Airscrew three bladers?
You can wait for a 12*8*3 to get instock or get a 13*8*3 and trim it down..
Dangaras is offline Find More Posts by Dangaras
Old Apr 20, 2012, 08:29 PM
IndyMatt is offline
Find More Posts by IndyMatt
Indianapolis, IN
Joined Oct 2010
Well define stupid, I know it is not scale but what are the other options? The two bladers are not scale either. The master air screws do draw a ton of amps.
IndyMatt is offline Find More Posts by IndyMatt
Old Apr 20, 2012, 09:02 PM
JimNM is offline
Find More Posts by JimNM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
Merlin, going from FWIW.. 3 blade hobby lobby on 3s drew almost 500 watts on my Spitfire. On the mas 11*7 gas prop, I had to go to 4s to get the same amp draw and on 3s it is around 350 watts. The gas prop needs to turn faster to load the motor to the same degree. My Windrider Hurricane uses the same motor and same mas prop. 3s is scale-ish, 4s is quite a bit more exciting.
JimNM is offline Find More Posts by JimNM
Old Apr 21, 2012, 12:08 AM
Tartago is online now
Find More Posts by Tartago
Plane crazy
Tartago's Avatar
Joined Apr 2006
Props were in stock for a few moments and swoshhhh!
Is HK playing with our nerves?
But finally I got my share.
Tartago is online now Find More Posts by Tartago
Old Apr 21, 2012, 06:19 AM
MERLIN V16 is offline
Find More Posts by MERLIN V16
Never Trade Luck for Skill
MERLIN V16's Avatar
United States, FL, North Port
Joined Jan 2005
Only Stupid from a scale point of view Indy. 2 bladers are for toy planes so they are are scale on anything.
Jim
I used the HL 9.5x10x4 on my P-47. It was over 600 watts and over 50 AMPs to do it. A pitch change got to a more reasonable 450W at 40 something amps.
These HL scale props do not like real high RPMs and if the hub develops a crack in the retaining pin area it will shed a blade fast. They would be OK on this plane with it's stock Motor.
MERLIN
MERLIN V16 is offline Find More Posts by MERLIN V16
Old Apr 21, 2012, 03:06 PM
IndyMatt is offline
Indianapolis, IN
Joined Oct 2010
Yeah those hobbylobby props are real nice but they are never in stock as well! Frustrating stuff!
If the two bladers work better for our planes from an amp and speed point of view what advantage do the 4 bladers and 3 bladers give to the full size planes?
Old Apr 21, 2012, 03:24 PM
anlucas is online now
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Greater torque. ie ability to better accelerate a heavier plane than say a 2 blader.
anlucas is online now Find More Posts by anlucas
Old Apr 21, 2012, 04:11 PM
BrettAltea is offline
Find More Posts by BrettAltea
Australia, VIC, Melbourne
Joined Aug 2011
Originally Posted by garrettt04s View Post
What motor comes in these? I just ran my pack out and nosed it into the ground. Needs a prop and a new motor. Turns over very hard. What can I use as a prop for now?
Don't have the Corsair but have the Durafly P-47. I upgraded the motor to the NTM 3536 910kv (with optional accessory pack) and it was a straight plug in except for enlarging the hole in the cowl by a couple of mm.
I fly this motor with a two bladed 12 x 8 SF prop which pulls 33 amps. A little marginal on a 35 amp ESC but I have an external BEC wired in. With this setup I can go unlimited vertical on 3S. Much better than the stock setup which is a little pedestrian. The two bladed prop isn't scale but can't tell with it in the air and I'd much rather a more efficient/powerful prop that doesn't break as easily.
BrettAltea is offline Find More Posts by BrettAltea
Old Apr 21, 2012, 04:57 PM
MERLIN V16's Avatar
Joined Jan 2005
My friend gave me a 12x8x2E APC but I did not have a way to get it on at the field. How did you get (the even thinner) SF on your plane Brett?
Old Apr 21, 2012, 05:18 PM
SubEd is offline
Find More Posts by SubEd
Joined Sep 2007
Haven't finished putting it together yet, but did paint up a Pappy tribute.
Need to paint some more lines on the canopy and weather still.
SubEd is offline Find More Posts by SubEd
Old Apr 21, 2012, 05:20 PM
MERLIN V16's Avatar
Joined Jan 2005
The paint is perfect! Well Done!
Old Apr 21, 2012, 06:04 PM
taz101 is online now
Find More Posts by taz101
taz101's Avatar
Australia, QLD, Gold Coast
Joined Oct 2010
That looks SENSATIONAL!!!!!
LURCH
taz101 is online now Find More Posts by taz101
Old Apr 21, 2012, 10:17 PM
Joined Aug 2011
The NTM accessory pack spinner fits it easily. http://www.hobbyking.com/hobbyking/s...ry%5FPack.html
Old Apr 21, 2012, 10:30 PM
bouncebk2003 is offline
Find More Posts by bouncebk2003
bouncebk2003's Avatar
Minneapolis,MN.
Joined Mar 2006
Taz101,
wow!I can't believe it's the same one I have.Nice work!
bouncebk2003 is offline Find More Posts by bouncebk2003
Old Apr 22, 2012, 05:27 AM
Strongbow is offline
Find More Posts by Strongbow
Strongbow's Avatar
Jacksonville, Fl.
Joined Jan 2010
I know this thread is full of flight pics, but, I just couldnt resist. This bird has turned into one of my favorites and always goes to the field with me. These pics were taken at Jax RC , one of our local club fields.
Strongbow is offline Find More Posts by Strongbow
Discussion Durafly 1100mm P-51D Mustang anj4de Electric Warbirds 5282 Aug 12, 2016 03:32 AM
Question ME-109, Spitfire, F4U Corsair, F4U Corsair, or P-51D Mustang, best flyer??? zippiz GWS (Grand Wing Servo) 89 Oct 03, 2015 04:58 PM
Discussion Comparison between FMS 1.4m Spitfire or Durafly HK 1.4 Spitire Fidy$Trainer Electric Warbirds 17 Aug 11, 2015 11:36 AM
Discussion Parkzone f4u corsair VS Airfield f4u corsair Hoopsta17_99 Electric Warbirds 54 Mar 16, 2012 08:11 PM
Discussion HK 1100mm P-47 captjoey42 Electric Warbirds 2 Nov 04, 2011 11:43 AM
