Old Mar 08, 2013, 07:34 PM
GiusedtoBe is offline
Find More Posts by GiusedtoBe
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
Originally Posted by MrGloriousfall View Post
So... ok with the "fren-glish"..?
Oui de Superbe!
GiusedtoBe is offline Find More Posts by GiusedtoBe
Old Mar 08, 2013, 08:13 PM
ryramZ is offline
Find More Posts by ryramZ
Your Pilot Ryan
ryramZ's Avatar
United States, IN, South Bend
Joined Nov 2008
yeah pretty windy on all those flights MRGF. Good job. That's a narrow little strip underneath some lines. Awesome. I like the Strokes, I saw your band. Your english is great.
ryramZ is offline Find More Posts by ryramZ
Old Mar 08, 2013, 11:40 PM
Griphin is online now
Find More Posts by Griphin
Griphin's Avatar
Australia, VIC, Melbourne
Joined Mar 2012
Yeah. His English is fine. Mine on that other hand not so much and it's the only language I got!
I've been running this on a 2800mAh 4S 30C batt weighing in at 299g and find it does extremely well CG and power wise. I don't use the scale spinner though rather a light alloy nose cone which iI find is easy to tighten and remove.
Griphin is online now Find More Posts by Griphin
Old Mar 09, 2013, 12:17 AM
LimitingFactor is offline
Find More Posts by LimitingFactor
LimitingFactor's Avatar
United States, CA, Glendale
Joined May 2010
Been using the spinner from my parkzone wildcat on mine-fits perfectly.
LimitingFactor is offline Find More Posts by LimitingFactor
Old Mar 09, 2013, 08:05 PM
ryramZ is offline
Your Pilot Ryan
ryramZ's Avatar
Joined Nov 2008
That's nice to know. Are you using the durafly prop shaft with the PZ wildcat aluminum prop hub? Threads match? Just making sure I'm reading you loud and clear.
I'm finishing up the assembly this evening. I really like it.
Old Mar 11, 2013, 03:37 AM
Joined May 2010
Yup. Fitted fine, a little smaller in size than the stock hub but I think it looks better. Best of luck flying her. I was bothered by the flaps so I did the split flap mod. Easy to do and looks so much better to me.
Old Mar 11, 2013, 03:42 PM
ScottAR04 is offline
Find More Posts by ScottAR04
The Fix is Half The Fun
ScottAR04's Avatar
United States, TX, Plano
Joined Feb 2013
Did you have the link that show the Flap Mod that everyone is using cant find it on thread
ScottAR04 is offline Find More Posts by ScottAR04
Old Mar 11, 2013, 08:37 PM
Joined May 2010
Oops no i don't, i remember seeing the link early on in this thread-was actually from another plane. Will try and find it, if not take some pics and see if i can explain what i did. I have never cut flaps before and even i found it quite easy to do.
Old Mar 11, 2013, 09:29 PM
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
Yeah I would be curious as well. i just want to see how you linked the three pieces.
Alan
Old Mar 11, 2013, 09:46 PM
quitcherbitchen is online now
Find More Posts by quitcherbitchen
Bombs away!!!
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
My Stuka flap mod is similar to LimitingFactor's. He and I fly together. Check my blog under the Stuka Flaps. I used a credit card cut like a chevron to connect the two. The inner most flap is slave to the outer. Glue the chevon to the outer and just coat the inner with some epoxy to strengthen up the skin. I also used dry silicon lube on the credit card chevron to make it function easier.
quitcherbitchen is online now Find More Posts by quitcherbitchen
Old Mar 12, 2013, 12:19 AM
Joined May 2010
Yup, quityer is pretty spot on with his mod. The only difference is that i glued some painted chinese food container instead of a credit card. Glued the middle flap on either side and a slot to move up and down in the outer two. And from where i cut out i went to home depot and go some flat latex paint . Behr 37 82 29 140 is the colour they matched off my plane-its close but not perfect but honestly you wont notice it at all once you attach your flaps-cost me only about 2 dollars and i have tons left.
Old Mar 12, 2013, 04:51 AM
rare bird is online now
Find More Posts by rare bird
rare bird's Avatar
Joined Nov 2012
I have just ordered a pair (hopefully) of those great metal trunnions as well.
How did you fathergoat attach the wheels to them? Did you just bend the struts? And how did you fix the snap-ring?
rare bird is online now Find More Posts by rare bird
Old Mar 12, 2013, 01:05 PM
ryramZ is offline
Your Pilot Ryan
ryramZ's Avatar
Joined Nov 2008
Some assembly tips. These probably apply to many of these Durafly models.
Durafly F4U Corsair Assembly/Tips Overview (19 min 31 sec)
Old Mar 20, 2013, 05:46 AM
MrGloriousfall is offline
Find More Posts by MrGloriousfall
France, IdF, La Roche-Guyon
Joined Oct 2011
metal trunnion
hi guys,
i received my metal trunnion from PW-RC yesterday. They look good except that the pins (both of'em) were bent during transportation.
i gonna test them in flight this week-end and will let you know, like fathergoat already did, how they accept my hard landings
MrGloriousfall is offline Find More Posts by MrGloriousfall
Old Mar 20, 2013, 07:14 AM
Bombs away!!!
Joined Jul 2011
hi guys,
Mr Glorious, Let Peter know that yours were messed up by the Postal Farce. He will send you replacement. He is a really good guy.
Discussion Durafly 1100mm P-51D Mustang anj4de Electric Warbirds 5266 Today 06:20 AM
Question ME-109, Spitfire, F4U Corsair, F4U Corsair, or P-51D Mustang, best flyer??? zippiz GWS (Grand Wing Servo) 89 Oct 03, 2015 04:58 PM
Discussion Comparison between FMS 1.4m Spitfire or Durafly HK 1.4 Spitire Fidy$Trainer Electric Warbirds 17 Aug 11, 2015 11:36 AM
Discussion Parkzone f4u corsair VS Airfield f4u corsair Hoopsta17_99 Electric Warbirds 54 Mar 16, 2012 08:11 PM
Discussion HK 1100mm P-47 captjoey42 Electric Warbirds 2 Nov 04, 2011 11:43 AM
