Old Feb 20, 2013, 06:02 PM
fathergoat is offline
Find More Posts by fathergoat
How do I land this thing?
fathergoat's Avatar
United States, IN, Warsaw
Joined Feb 2012
I used a small burr to cut the corner away and give it room to function. now it opens and closes smoothly.
They certainly aren't perfect and i don't mind a little fitting, if I didn't get two right legs.
derp.
fathergoat is offline Find More Posts by fathergoat
Old Feb 20, 2013, 08:27 PM
paul2pilot is offline
Find More Posts by paul2pilot
paul2pilot's Avatar
Huntington Beach, CA
Joined Jan 2011
Somehow, the plane just doesn't look as cool that way
paul2pilot is offline Find More Posts by paul2pilot
Old Feb 20, 2013, 09:12 PM
EOD_Pete is offline
Find More Posts by EOD_Pete
BOMB BREAKER
United States, CA, Oceanside
Joined Feb 2012
Ha ha, will the other one even retract?
EOD_Pete is offline Find More Posts by EOD_Pete
Old Feb 20, 2013, 09:34 PM
taz101 is online now
Find More Posts by taz101
taz101's Avatar
Australia, QLD, Gold Coast
Joined Oct 2010
fathergoat, have you contacted Philip!
I'm sure if you email him he will rectify the problem straight away.
If you do email him, attach a couple of those photos!!
I'm sure he would almost have the replacement in the mail today, he is that good when he has mad the mistake.
LURCH
taz101 is online now Find More Posts by taz101
Old Feb 21, 2013, 05:31 AM
fathergoat's Avatar
Joined Feb 2012
it does, but I'm going to put the plastic one back on for now.
LURCH
I did exactly that after I made this thread. He's already responded and is sending me out a new set. I am a little disappointed that I can't fly it with the metal trunnions yet. Everyone makes mistakes, the true mark of a good business is how fast they rectify it. Philip get's an A+
Old Feb 21, 2013, 07:00 AM
Junkers Jumo is offline
Find More Posts by Junkers Jumo
Schwalbe
Junkers Jumo's Avatar
Australia, WA, Yokine
Joined Aug 2011
Originally Posted by fathergoat View Post
Philip get's an A+
Here here!
Junkers Jumo is offline Find More Posts by Junkers Jumo
Old Feb 21, 2013, 08:09 AM
taz101's Avatar
Joined Oct 2010
Hopefully if you sent him the photo of the trunnions side by side, he might figure out which ones he sent you and send you a pair of the opposites!
But at the very least, will probably be one of each to be on the safe side!!
LURCH
Old Feb 21, 2013, 09:31 AM
MrGloriousfall is offline
Find More Posts by MrGloriousfall
France, IdF, La Roche-Guyon
Joined Oct 2011
great! so i order mine tonight!
MrGloriousfall is offline Find More Posts by MrGloriousfall
Old Feb 22, 2013, 08:07 PM
rickgode is offline
Find More Posts by rickgode
I'm just a 2.5D Pilot
rickgode's Avatar
Fort Worth, TX
Joined Dec 2005
I love those metal trunnions! So what are the little scissor like shock absorber things called? And where can we order that?
Ricky
rickgode is offline Find More Posts by rickgode
Old Feb 22, 2013, 08:15 PM
fathergoat's Avatar
Joined Feb 2012
are you talking about oleo legs? if so I haven't found any that fit...yet
Old Feb 22, 2013, 08:32 PM
rickgode is offline
rickgode's Avatar
Fort Worth, TX
Joined Dec 2005
Oleo legs! That's what I want. I try and grease the corsair in, but those tires are pretty stiff and could use a little shock absorbition!
Ricky
Old Feb 25, 2013, 06:19 AM
Joined Oct 2011
remote control switch for the lights
hi guys,
i received my receiver controled switch from turnigy those last days (http://www.hobbyking.com/hobbyking/s...idProduct=8833).
no problem to connect it and make it works for the lights.
i plug it on the JST connector (charge) of the 3s 2200mAh that feed the entire plane.
as all examples i've seen are plug on the wire that goes to the esc, do you think i may have problems using this kind of connexion?
Old Feb 25, 2013, 07:11 AM
quitcherbitchen is online now
Find More Posts by quitcherbitchen
Bombs away!!!
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
Yes, you will have a problem, the power needs to be stepped down. You will burn up the lights. I have one of these for a machine gun module and they work great so long as you follow the schematic to the letter. you need to tap the power + line after the esc and also tap the negative - post esc.
quitcherbitchen is online now Find More Posts by quitcherbitchen
Old Feb 25, 2013, 07:53 AM
Joined Oct 2011
hi quitcherbitchen,
do you mean i have to plug it between the esc and the receiver?
Old Feb 25, 2013, 08:28 AM
Bombs away!!!
Joined Jul 2011
Yes, follow the schematic to the letter. Either that or make a harness inbetween the lights and the receiver. You need to step the power down to the lights and the switch doesn't step. Only your ESC will do that. The important thing is to tap the negative as the switch needs that for a reference. Check my blog. It might help you understand even though it is for a machine gun sound unit.
Discussion Durafly 1100mm P-51D Mustang anj4de Electric Warbirds 5282 Aug 12, 2016 03:32 AM
Question ME-109, Spitfire, F4U Corsair, F4U Corsair, or P-51D Mustang, best flyer??? zippiz GWS (Grand Wing Servo) 89 Oct 03, 2015 04:58 PM
Discussion Comparison between FMS 1.4m Spitfire or Durafly HK 1.4 Spitire Fidy$Trainer Electric Warbirds 17 Aug 11, 2015 11:36 AM
Discussion Parkzone f4u corsair VS Airfield f4u corsair Hoopsta17_99 Electric Warbirds 54 Mar 16, 2012 08:11 PM
Discussion HK 1100mm P-47 captjoey42 Electric Warbirds 2 Nov 04, 2011 11:43 AM
