Old Dec 07, 2012, 06:41 PM
fathergoat is offline
Find More Posts by fathergoat
How do I land this thing?
fathergoat's Avatar
United States, IN, Warsaw
Joined Feb 2012
the pin is press fit so I removed that first.
I then drilled it out in progressively larger sizes until the aluminum tube would fit. I went all the way down until I hit a screw. Then I marked the length and location of the slot. If you try to drill it to size in one shot it's more likely you'll drill off center.
I used a dremel to cut a slot just big enough and cut it to length. Since mine were broke I CA'd them back into their appropriate halves.
After that I mixed up some epoxy and spread it in one half put the tube in and epoxied the other half on. I was careful to line up the slot while doing so. After it's set I just have to put the axle in and pop in the pin.
I don't know how well this will hold up. I think it should be at least as strong as stock, it could even be stronger, or it might break while taxiing. I wanted to use steel but what was available had a thick wall and wouldn't have left much plastic. It may however be a good candidate for a metal gear mod.
fathergoat is offline Find More Posts by fathergoat
Old Dec 09, 2012, 07:10 PM
Dangaras is offline
Find More Posts by Dangaras
Dont be divided from the truth
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
Thats nice work. The tube will definitely hold up and make it stronger..
Dangaras is offline Find More Posts by Dangaras
Old Dec 09, 2012, 07:18 PM
handyman 220 is offline
Find More Posts by handyman 220
United States, CT, East Hartford
Joined Jul 2008
Just ordered one from HK. I like the size for easy transportation without taking it apart. It sounds like there is very little problems with this plane. I also have the Unique models corsair it is also a nice model. The only drawback to both kits is the flaps aren't scale, and need to be fixed.
handyman 220 is offline Find More Posts by handyman 220
Old Dec 13, 2012, 05:19 PM
fathergoat's Avatar
Joined Feb 2012
Well the sleeve did/didn't hold up. It's no good for repairs. Upon landing the epoxy came loose and the plastic pieces seperated. The tube still held everything together though so it sort of worked. I may experiment with using it as reinforcement for new gear. It might not be able to fix broken gear but it may be able to keep it from breaking.
Old Dec 14, 2012, 12:49 PM
comanch is offline
Find More Posts by comanch
United States, FL, Satellite Beach
Joined Jul 2012
What if, you wrapped the outside of the plastic with thread and epoxy. Kind of like a fishing rod line guide. Would that maybe keep it all together? Wouldnt be hard to do if done before putting it into the motor side. Looks like it could be done between the boss for the pin and the boss for the gear door screws???
comanch is offline Find More Posts by comanch
Old Dec 14, 2012, 01:00 PM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
Oh yes. That would work perfectly. That worked for me on a different project and is yet to fail...
Old Dec 14, 2012, 04:53 PM
fathergoat's Avatar
Joined Feb 2012
That would work awesome if they didn't break off right at the trunnion. So you really can't get any thread around that area. I'm still working on a solution though. I'm trying to come up with something that just about anyone will have access to do. I feel like the sleeve will be half of the solution I just need to figure out the rest of it.
Old Dec 14, 2012, 05:42 PM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
Thinking about it, I have never seen a break like that. You probably got a defective plastic part, bubble or something like that..
A new one will probably fix you right up and never occur again.
Just like all the original props used to break at the slightest glance. Now that has significantly diminished.
Old Dec 15, 2012, 09:01 AM
fathergoat's Avatar
Joined Feb 2012
the first set broke like that because I pancaked on a failed landing. the other one broke when I hit a small lip in the asphalt. I don't blame either one on the gear being too weak. the way I see it the gear is strong enough to hold up to hundreds of good landings and even a few rough ones. I'm just trying to come up with a way to repair it when it does happen or beef it up to make it more durable.
Old Dec 15, 2012, 08:53 PM
comanch is offline
Joined Jul 2012
Would be nice if the trunnion thru pin area were aluminum from the factory vs plastic.
Old Dec 16, 2012, 07:53 AM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
There is a metal trunion version at pw-rc, just not in this size yet..
http://www.pw-rc.com/product_info.ph...72ce204c08e912
Old Dec 22, 2012, 05:41 PM
mperaltaoz is offline
Find More Posts by mperaltaoz
No RTF flies like your own SB
mperaltaoz's Avatar
Australia, VIC, Melbourne
Joined Aug 2012
Broken wheel rotating shaft
Anyone has any ideas on how to fix this?
The retract works properly, but the wheel shaft got broken in the union with the rotating axle (the little stick that goes out and makes the entire wheel rotate 90 degrees).
I was thinking of gluing or soldering another little stick made of a push rod, but not sure how to fill the rest of the shaft piece to complete the trunnion's internal length.
mperaltaoz is offline Find More Posts by mperaltaoz
Old Dec 22, 2012, 06:26 PM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
You might be better off buying a new set.
Old Dec 22, 2012, 06:47 PM
dambit is offline
Find More Posts by dambit
Most people are stupid!
dambit's Avatar
Australia, QLD, Gold Coast
Joined Oct 2011
Yep, cheap and way less hassle.
dambit is offline Find More Posts by dambit
Old Dec 22, 2012, 07:16 PM
mperaltaoz's Avatar
Joined Aug 2012
I will, but they are in backorder at the moment and I want to keep flying...
I think I managed to fix it quite good... Will see how it goes and post results later.
Discussion Durafly 1100mm P-51D Mustang anj4de Electric Warbirds 5266 Today 06:20 AM
Question ME-109, Spitfire, F4U Corsair, F4U Corsair, or P-51D Mustang, best flyer??? zippiz GWS (Grand Wing Servo) 89 Oct 03, 2015 04:58 PM
Discussion Comparison between FMS 1.4m Spitfire or Durafly HK 1.4 Spitire Fidy$Trainer Electric Warbirds 17 Aug 11, 2015 11:36 AM
Discussion Parkzone f4u corsair VS Airfield f4u corsair Hoopsta17_99 Electric Warbirds 54 Mar 16, 2012 08:11 PM
Discussion HK 1100mm P-47 captjoey42 Electric Warbirds 2 Nov 04, 2011 11:43 AM
