Old Aug 06, 2012, 07:40 PM
irodrigo is offline
Find More Posts by irodrigo
Always a noob
Joined Jul 2012
Originally Posted by Dangaras View Post
Rudder and tailwheel compensate on the ground but once you are off you use it to fly.
Yeah but do I need to compensate on the ground only? Or on the air too since that's where the spiral is happening?
irodrigo is offline Find More Posts by irodrigo
Old Aug 06, 2012, 07:53 PM
Bucksterpup is offline
Find More Posts by Bucksterpup
Joined Jun 2012
Corsair Build question regarding glue, clevis, ESC
Hi All,
1. Are you guys using the contact cement that came with the Corsair or CA glue for
assembly?
2. Anyone know the size of nylon clevis I should buy to replace cheap plastic ones that came with? I will likely just use Du-Bros from LHS.
3. Do you just let the ESC hang back toward tail from battery, or are you velcroing or putting somewhere specific in the fuse?
I have already replaced the wheels with Du-Bro 2.25" Ultra-lite Wheels, and am going to use the MAS 12x8 2-blade prop
Thanks, from previously Parkzone only flyer
Bucksterpup is offline Find More Posts by Bucksterpup
Old Aug 06, 2012, 08:07 PM
Griphin is offline
Find More Posts by Griphin
Griphin's Avatar
Australia, VIC, Melbourne
Joined Mar 2012
RE glue they really do. Get the bird rolling first and then smoothly increase throttle countering with the rudder to keep it straight. The faster you go on the ground the better and easier the take-off. DON'T pull up hard ease it off the ground when it wants to fly. You can't go too fast it's a warbird and speed = control. Once in the air you don't need the rudder to compensate. If you do you need to trim it so it flies straight and level. I had it flying great hands free so it can.
Griphin is offline Find More Posts by Griphin
Old Aug 06, 2012, 08:23 PM
irodrigo is offline
Always a noob
Joined Jul 2012
Thank you dear sir!
Old Aug 06, 2012, 11:34 PM
irodrigo is offline
Always a noob
Joined Jul 2012
Originally Posted by MERLIN V16 View Post
If you don't know any better you would think (some newbies still do) the motor mount was bent. It has the most down and right I can remember on an RC Plane.
The Durafly is an easy one to add thrust or take it out of with washers. Besides fighting the climb and left turn problem the hole in the Cowl will be wrong.
MERLIN
Mine (pictured in prev. page) looks more like right and up than right and down... Am I wrong?
Also, what do you mean add or take out thrust with washers? How would one do that?
Old Aug 07, 2012, 01:47 AM
esoteradactyl is offline
Find More Posts by esoteradactyl
United States, CA, Costa Mesa
Joined Jan 2012
Originally Posted by dambit View Post
Also I managed to fix my lost retract rotating pin today. I replaced it with an old busted drill bit of the same diameter. Works like a charm
I had the same thing happen to me today but for the life of me cant figure out how to fix it. What holds the pin in place?
esoteradactyl is offline Find More Posts by esoteradactyl
Old Aug 07, 2012, 02:17 AM
dambit is offline
Find More Posts by dambit
Most people are stupid!
dambit's Avatar
United Arab Emirates, Dubai
Joined Oct 2011
Tension holds it in place. I made sure the drill bit I used was the same size as the hole it slots into so that when the metal split shaft is put back into it's plastic surround it clamps tight.
dambit is offline Find More Posts by dambit
Old Aug 07, 2012, 06:56 AM
013531 is offline
Find More Posts by 013531
Joined Aug 2011
Irodrigo,
As the other guys have said, a longer run out helps build flow over the wings and control surfaces and stabilises the plane. Try for a nice scale take off and you'll do just fine. Just ease the throttle up, get ready with some right rudder then gently pull back.
Darren
013531 is offline Find More Posts by 013531
Old Aug 07, 2012, 09:13 AM
Dangaras is offline
Find More Posts by Dangaras
Dont be divided from the truth
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
On the ground to keep it straight, then in the air your ailerons control the roll of the model much more effectively than the rudder.
Dangaras is offline Find More Posts by Dangaras
Old Aug 07, 2012, 10:03 AM
queadlunnrau is offline
Find More Posts by queadlunnrau
Luck is my skill
queadlunnrau's Avatar
United States, WA, Seattle
Joined Jun 2009
assembly?
1. I do use foam contact glue, but not the one that came with the Corsair, but I'm sure that's the same stuff as what they use in the factories for most foam planes. CA glue is tooo brittle, unless you use the flex type.
2. Not sure, but the stock ones seem to be holding good on my corsair, mine came with an extra one as well.
3. I let me ESC just hang around, am waiting for it to fail to replace it with a larger to run 4s, but it's still going strong!
queadlunnrau is offline Find More Posts by queadlunnrau
Old Aug 07, 2012, 12:50 PM
Joined Jun 2012
Thanks. I'll just use the stuff that came with I guess. Seems a bit more flexible than Ca.
Old Aug 07, 2012, 01:03 PM
irodrigo is offline
Always a noob
Joined Jul 2012
Originally Posted by 013531 View Post
Irodrigo,
Darren
Thanks guys; I think I have a much better idea now. I'll give it a try once my parts are here! Or does anyone know what would happen if I were to fly with a very slightly bent propeller shaft?
Old Aug 07, 2012, 07:46 PM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
Bad juju!
Old Aug 07, 2012, 07:50 PM
irodrigo is offline
Always a noob
Joined Jul 2012
Bad juju!
LOL, I must say tho, it sounds pretty awesome! Like a very large loud prop.
Old Aug 08, 2012, 09:28 PM
Joined Jun 2012
At 100% Corsair throws seem a bit short
Background: Parkzone T-28 using Spektrum DX6i
Fly on high rates always 100% Aileron, Elev, and Rudder
Expo A-+30 Elev +30% Rudder - 0
New Corsair set to Ail- 100% + 30% Expo
Elev-100%+ 30 expo
Rudder 100% expo???
Flaps- level for flight
100% down for Landing
The amount of actual movement of the control surfaces doesn't even come close to the T-28. Is that because it's a low wing, and needs much less input?
Should I be flying on low rates for a while? Suggestions?
Flap servos continue to shudder after returned to normal. Should I replace?
Just want to make sure things are set correct before I maiden
Discussion Durafly 1100mm P-51D Mustang anj4de Electric Warbirds 5282 Aug 12, 2016 03:32 AM
Question ME-109, Spitfire, F4U Corsair, F4U Corsair, or P-51D Mustang, best flyer??? zippiz GWS (Grand Wing Servo) 89 Oct 03, 2015 04:58 PM
Discussion Comparison between FMS 1.4m Spitfire or Durafly HK 1.4 Spitire Fidy$Trainer Electric Warbirds 17 Aug 11, 2015 11:36 AM
Discussion Parkzone f4u corsair VS Airfield f4u corsair Hoopsta17_99 Electric Warbirds 54 Mar 16, 2012 08:11 PM
Discussion HK 1100mm P-47 captjoey42 Electric Warbirds 2 Nov 04, 2011 11:43 AM
