This thread is privately moderated by cudaboy_71, who may elect to delete unwanted replies.
Old Dec 11, 2011, 08:26 PM
cudaboy_71 is offline
Find More Posts by cudaboy_71
Trader Rating: 0
cudaboy_71's Avatar
sacramento, ca
Joined Apr 2005
Trader Rating: 0
For Sale
Trex 250 FB/FBL* w/ upgrades BNF
$985 invested; $550 PP shipped OBO
Currently the heli is BNF flybarred; I took off the BeastX for my 450. Add your own beastX unit (or any other FBL unit*) and it is just a headswap away (head included) from FBL.
Included:
Trex 250 short combo (410 servos, stock motor, 15 amp ESC)
Scorpion HK 2208-3600
16t pinion installed (15t included)**
motor mound modded to take Scorpion motor/pinion
stock motor/pinions included
Stock head:
Helidirect ultra-fast paddles installed
FBL head:
Microheli adjustable (shown)
Microheli CF/Aluminum antirotation bracket
Microheli bottom plate
SE skids
Align metal front tailbox
Align metal front and rear tail shafts
Flawless Canomod canopy (ACT-2X-015 I think...no box at LHS)
Beater Align yellow w/ white lightning canopy; only damage is the dog ears broke off from repeated on-offs of the canopy. I repaired with fiberglass and is functional. But, still shows cracks.
GY520
S3154 tail servo
kevlar tail belt +1 spare
AR6100 receiver
205D CF blades have nicks from inverted blade touches.
NIP H25071 CF blades included
Align metal main bearing blocks (uninstalled/NIP)
Frame screws are the tiny/strippable ones. Many are stripped and dremel-slotted to remove. Included is a complete new set of screws and dress washers NIP.
2 hyperion 3s 850mah packs w/ less than 20 cycles, 1 with 3 cycles
too many spares to list....could probably repair any crash several times over.
here is some video of the heli on beastx v2 with the 15t pinion at 100%
Align Trex 250 FBL Beastx (3 min 30 sec)
*I tried this setup with a 3G and it just would not dial in. It works; but it does not work well. I have the 3G unit for an additional $75 if interested.
** aftermarket pinion grub screw rubs the main gear slightly. you can shim down the motor so it doesn't hit. I never did. It wears in after a flight and is fine afterward. New main gears included since the main is worn from the rub.
cudaboy_71 is offline Find More Posts by cudaboy_71
Sold mint align 700e fbl v2 sk720 bnf w/upgrades ohsnap Aircraft - Electric - Helis (FS/W) 1 Nov 03, 2011 02:13 AM
For Sale WTT: Trex 600N FB/FBL for Trex 600E/550E FB/FBL RCDXER Aircraft - Electric - Helis (FS/W) 0 Oct 01, 2011 07:19 AM
Sold Align TREX 700E FBL w/ Upgrades & Extras GoRgOyL Aircraft - Electric - Helis (FS/W) 3 Aug 16, 2011 07:06 AM
Sold SOLD Trex 250 FBL 3G BNF paulpeffly Aircraft - Electric - Helis (FS/W) 1 Jul 03, 2011 09:09 PM
Sold mint align trex 550e fbl v2 upgrades w/ nip 3gx bnf ohsnap Aircraft - Electric - Helis (FS/W) 1 Jun 30, 2011 07:27 AM
