Old Dec 11, 2011, 06:06 PM
candy76man is offline
Find More Posts by candy76man
alienfpv, warpquad, goby180
Tampa,FL
Joined Dec 2003
Plastic pinions keep moving on motor shaft?
I have a lm100D02 and everytime it crashes the plastic pinions move on the motor shafts and start grinding into the other main gear or disengage from the main gear. I think this happens mainly because of Walkera's idiotic intentional throttle shutdown delay of 3 seconds which causes the heli to go skittering around and slamming into things everytime I crash even though I shut down the throttle before it hits the ground But thats another story.
Anyone know a good way to secure the pinions on the shaft so they won't slide up and down? I tried ca and hot glue but neither held for even one crash. the shafts are so small that drilling a hole for a pin would not be possible (for me) and I can't think of anything else short of finding some brass pinions of the correct size which would not be easy.
candy76man is offline Find More Posts by candy76man
Old Dec 11, 2011, 07:43 PM
arbilab is offline
Find More Posts by arbilab
Fly Runaway Fans
United States, TX, Fort Worth
Joined Jan 2009
CA won't bond to the gear plastic but it will bond to the shaft and unwaxed dental floss tied above and below the gear. Go around ~3 times. After tying trim closely so it can't tangle.
Intentional shutdown delay? What on earth is the purpose of that, except to sell more blades, heads, ESCs?
arbilab is offline Find More Posts by arbilab
Old Dec 11, 2011, 10:44 PM
Tampa,FL
Joined Dec 2003
Thanks I'll give that a try..I cut a small plastic spacer to go between pinion and motor that keeps them from working up to close to the can but the other way is where I can't seem to stop it.
They claim it is a feature for beginners to prevent the heli from dropping to the ground hard if you accidentally shut off the throttle (and it does do that) ..however much more damage is done by it thrashing around on the ground for 2-3 seconds after every crash than could ever occur from it dropping 5 or 6 feet. No way to defeat it either, it pretty much ruins what is other wise a pretty nice little coax. It also makes me afraid to fly it around any people, since I can't cut power to the blades instantly if it gets to close to someone.
Old Dec 11, 2011, 11:37 PM
arbilab is offline
Fly Runaway Fans
Joined Jan 2009
Have those people never FLOWN a helicopter? They bounce a lot cheaper than they thrash.
That's like selling a car with delayed brakes and calling it a safety feature to prevent getting rearended.
Old Dec 12, 2011, 12:57 AM
Tampa,FL
Joined Dec 2003
I know, thats why I am pissed about it....it's stupid but no one will admit it. Ehirobo where I bought it just says it's a beginners feature like it's a great idea , they won't admit it's a problem...wowhobbies has told people the same thing about it here...I even sent a email to Walkera asking how to disable it and what they were thinking but have gotten no reply after a week.
The worst part is it's not documented anywhere, theres nothing in the manual about it, nothing in ehirobos description or on walkeras website, that I could find anyway, so I had no way of knowing it would be like this and it's not worth the expense of sending it back to ehirobo overseas for a refund, although if they're sticking by the "it's a feature" line I doubt they would refund me anyway.
Old Dec 12, 2011, 03:39 PM
arbilab is offline
Fly Runaway Fans
Joined Jan 2009
That's almost surely burned into the controller firmware so there's not going to be a way to disable it.
Some $20 3ch infrareds have the opposite feature; if the gyro detects an impact it shuts the motors off FOR you. THAT'S a beginner feature.
Old Dec 21, 2011, 12:11 AM
Tampa,FL
Joined Dec 2003
I ordered some brass pinions from a swedish company that makes them to order so that should solve that problem at least...nothing I've tried has kept them from sliding on the shaft after a crash while the blades are slamming into things until the motors stop. I guess I just have to get used to the throttle shutoff delay if I want to get my money's worth out of this thing.
Old Dec 29, 2011, 05:51 PM
Tampa,FL
Joined Dec 2003
brass pinions worked out good, at least I don't have to reposition the pinions after every crash now.
Discussion 70mm EDF on 12s1p: WHICH MOTOR? (keep it light!) Oreo Electric Ducted Fan Jet Talk 36 Jul 29, 2012 05:57 PM
Discussion Drive Shaft Miss Bud, sell or keep? killervette666 Racing Boats - Internal Combustion 3 Sep 20, 2011 02:15 AM
Discussion Moving Motor Shaft Lost Oracle Electric Plane Talk 5 Mar 25, 2011 01:21 AM
Found 8,9,+10 tooth pinions that will fit on park 370 size inrunner motor shaft ddrummer508 Aircraft - Electric - Helis (FS/W) 5 Feb 15, 2011 06:16 AM
Question Shaft collar and the 'old'? plastic spacers on shaft?? markswift Micro Helis 8 Jun 11, 2004 05:49 PM
