Woohoo! The skids are done and I feel really good about how they turned out, thanks Pete for pushing me to do it. I now realize the 3x11s would not have cut it, the skids not only have to withstand landing impacts but they are also an integral part of the landing gear itself so I'm glad I used the bamboo.
I started by cutting wider strips and planing only the insides of them. I then glued the planed sides together but only up to where I wanted the tip bend to start. I finished planing the outside of the strips to true them up then bent the tip over candle flame. This is surprisingly effective and the hotter it gets, the more flexible it gets. It reminds me a little of plastic, wherever it's hottest is where it will bend most. After inducing the bend, the pieces are glued the rest of the way and planed/cut/sanded into final shape. By laminating the bamboo as Pete suggested I have a skid that is even stronger than one solid piece and didn't require a large cane.
I found a generic 5055 700kv brushless outrunner that is a pretty close match to the AXI 4120/12 Pete spec'd out on the plans (they don't make that one anymore BTW). Since the front of the motor box doesn't have enough area to use a cross mount I mounted the motor directly to the front of the box and made this part removeable in case I ever need to service the motor. I tried a Xoar 17x6 wood prop and a 2s lipo drew 32A producing 225W while a 3s drew 30A producing 335W, this is right in the range Pete had planned on flying this plane with. I'm still not sure what the AUW will be so I'm waiting until the last minute to finalize my battery selection based on power and weight requirements.
To further improve access to the motor I also made the front grille removeable by using some toothpicks for alignment and a couple rare earth magnets to keep it in place
Pete,
I have a couple questions regarding finish. Firstly, I started fiddling with some aluminum flashing for the nose and think I can pull off the louvres. My problem is the aluminum is fairly soft so it gets small scratches on it as I'm working with it. I've been experimenting with fine grit sandpaper and small wire wheels to see if there is a way to put a uniform finish on it that looks good but nothing satisfactory so far. The second question invloves covering. I've decided to use dyed medium K&S silkspan and nitrate dope but am unsure what color the model should be. I know many have used tea to obtain a linen color but the plane in the pictures looks darker and none of the underlying structure can be seen. The white lettering on the tail shows quite a bit of contrast as well so I'm contemplating using coffee or something darker than the tea to get the desired finish. Any thoughts on this would be appreciated, Mike |
Norfolk, England
Joined Sep 2001
Mike,
If you can get it ( I got some on ebay a while ago) litho plate is good. The thicker stuff works best because it seems to be less brittle and can be used on its' own because it's strong enough. Whenever I want to apply an 'engine turned' finish I use a small piece of green scourer glued to a small grinding disc in a Dremel. Apply the finish, before cutting or making louvres, by lightly holding the spinning scourer to the metal to form rows of swirls. No doubt random turning could be applied by moving it around the surface. On my Eastbourne Mono, lacking litho plate, I used an aluminium platter - those disposable, thick foil type trays. There were no louvres on that but it does work very well indeed. Maybe the application of a little GRP inside the louvres would toughen up those areas. (about 1/3 the way down this page http://www.rcgroups.com/forums/showt...=389811&page=6) As regards colour, virtually every illustration (drawn) I've seen shows a sort of clear doped linen finish - as per my models. I put ply panels on the first one, but that was just because I liked the way they looked. A cream finish certainly 'feels' right. Pete |
| Thread Tools | |
| Build Log Peter Rake's 60" Pfalz E.1 - 3rd Prototype, yes another one... | 1905Flyer3 | Scale Electric Planes | 40 | Nov 30, 2011 02:04 AM |
| Build Log "The Rooster" Peter Rake's Samolot Kogutek | Prototype Build | hoffboy | Scale Electric Planes | 91 | Nov 21, 2011 02:10 AM |
| Build Log Peter Rake's 60" Pfalz E.1 - 2nd Prototype | Newtron | Scale Electric Planes | 64 | Oct 12, 2011 10:13 PM |
| Build Log Peter Rake's Macchi M16 - prototype build | Redbaron25 | Scale Electric Planes | 82 | Jan 25, 2011 05:27 AM |
| Build Log Peter Rake's Udet Flamingo Prototype Build | uranus456 | Scale Electric Planes | 55 | Dec 01, 2009 08:20 AM |
