Old Dec 11, 2011, 05:29 AM
lowkeylaidback is offline
Find More Posts by lowkeylaidback
Custom Crasher
lowkeylaidback's Avatar
USA, FL, Jacksonville
Joined Jan 2010
Detrum 64mm EDF power combo Questions
I have asked this question on RCDiscuss, I have sent you 3 emails all asking this question
Is this a 3 cell or 4 cell setup?
Detrum 64mm EDF power combo set (64mm EDF+40A ESC+4pcs 9g servos+KV4400 brushless motor)
http://www.hobbypartz.com/60p-64mm-edf-combo.html
lowkeylaidback is offline Find More Posts by lowkeylaidback
Old Dec 12, 2011, 02:23 PM
NitroTechnician is offline
Find More Posts by NitroTechnician
Joined Jul 2011
Hello lowkeylaidback,
We recommend using a 3 cell lipo with that combo.
Danny
NitroTechnician is offline Find More Posts by NitroTechnician
Old Dec 16, 2011, 07:44 AM
Custom Crasher
Joined Jan 2010
thank you
Old Nov 22, 2012, 11:09 AM
RPM314 is offline
Find More Posts by RPM314
Tailless fly-hard
RPM314's Avatar
United States, NY, Brooklyn
Joined Apr 2012
This thread has been dead for a while, so I'm probably just talking to a wall here, but what kind of speed should be expected from the 64mm on 3s? 4s?
RPM314 is offline Find More Posts by RPM314
Old Nov 26, 2012, 01:49 PM
RaidenCharlie is offline
Find More Posts by RaidenCharlie
HobbypartZ Support
Joined Jul 2011
It depends on how much the plane weights, so it's sort of hard to say.
-Charlie
RaidenCharlie is offline Find More Posts by RaidenCharlie
Old Dec 16, 2012, 03:32 PM
itsevlam is offline
Find More Posts by itsevlam
plane builder
itsevlam's Avatar
United States, ME, Standish
Joined Mar 2010
type of battery
battery info needed for detrum 64mm edf combo, such as "C" rating, number of cells and ??mah. more interested in lenght of flight rather than speed, but would like info for both speed and flight time.
want to install in 727, 50" w.s. approx 26-30 ounces including servos and rx
itsevlam is offline Find More Posts by itsevlam
Old Dec 17, 2012, 01:19 PM
HobbypartZ Support
Joined Jul 2011
We recommend a 3S 40C pack to be used with the 64mm combo. The flight time will depend on the battery that you used, the Dynam A10 uses a similar setup with a lower KV motor and we got about 5 minutes of flight time on the jet.
-Charlie
Old Dec 17, 2012, 06:40 PM
itsevlam is offline
plane builder
itsevlam's Avatar
Joined Mar 2010
Thanx RaidenCharlie for the fast response. Appreciate the assist... another two questions please, where can I purchase replacement rotors for this combo(will they be balanced), and in theory - the higher mah the longer flight time or two lower mah lipos in parallel.
yeah i'm a newbie to edf's and lipos.
Thanx
Jim
Old Dec 18, 2012, 12:29 PM
HobbypartZ Support
Joined Jul 2011
Dynam doesn't sell the rotors for the combo at the moment, but the rotors from their EDF powered jets should work as well, so you can use the rotor from their A-10, and TurboJet. There's other manufactures that make makes the rotors for 64mm housings and you can use them as well. The higher of the MAH the longer the flight time, but that will also mean the bigger the battery. You can run the batteries in parallel but you'll have to bring weight and space into consideration.
-Charlie
Old Dec 18, 2012, 01:22 PM
itsevlam is offline
plane builder
itsevlam's Avatar
Joined Mar 2010
thanx for the helpful info!
Discussion New Detrum 70mm & 64mm EDF Power Combo Sets hobbypartz Nitro Planes 6 Sep 19, 2015 11:26 PM
Discussion Detrum 70mm EDF Power combo from Hobbypartz.com Trammellc2001 Electric Ducted Fan Jet Talk 0 Oct 10, 2011 09:53 AM
Discussion Detrum 64mm EDF power combo set $39.70 hobbypartz Hot Online Deals 1 Oct 08, 2011 11:29 AM
Video New Detrum 70mm & 64mm EDF Power Combo Sets hobbypartz Electric Plane Talk 1 Oct 05, 2011 03:03 PM
Discussion Detrum 70mm EDF power combo system $49.70 hobbypartz Hot Online Deals 0 Oct 05, 2011 03:00 PM
